Old 02-07-2011, 10:14 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default n/a heads+trans in a wrx
i posted this in the 02+ section but i think it might fit better here...
might be buying a wrx shell..i have a sti block and a set of ported/cammed n/a heads from a 01 sohc. i know the heads bolt and work on the sti block. can they be wired to work in a 02 wrx? essentially making it a full 2.5 engine setup..i have the ability to tune to make ecu stuff read.
also, just to get it up and running, can a na 5 speed trans from a 01' impreza work in a wrx? as well as my n/a accessories..alt, power steering...?
thanks!
farrell is offline   Reply With Quote
Old 02-08-2011, 08:29 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
So long as you work out the ECU end of things, it should be alright. MAP/MAF signal will only go to 0 at WOT. I'm not certain if the SOHC cam trigger setup will work with the WRX ECU.
Trans should work, but mind your ratios. 01 RS used a 4.11 ratio where the WRX has a 3.54 back in the back. Make the rear match the front and all will be well. Both clutches are hydraulic actuated, so no issue there, other than the slave cylinders being different for push vs. pull setup.
Accessories will bolt on like they belong there.
Jay
Old 02-08-2011, 11:44 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
redo your cam triggers... weld new ones on. Would make a NICE DOHC NA setup.. ohhhHHHH
FuJi K is offline   Reply With Quote
Old 02-10-2011, 08:23 PM   #4
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Keep in mind that combination is going to be low compression and a gutless turd without some form of FI. But it should run.
yamarocket630 is offline   Reply With Quote
05 WRX trans in 02 WRX, won't roll clbd39 Transmission (AT/MT) & Driveline 3 02-04-2011 03:56 PM
2006 wrx trans in 2002 wrx. scoobynoobEMT Transmission (AT/MT) & Driveline 9 12-02-2009 02:21 PM
04 Wagon Trans in 02 WRX Sedan Penguin_02 Transmission (AT/MT) & Driveline 0 10-10-2009 01:52 AM
Legacy Trans in a wrx? Timmay81 Transmission (AT/MT) & Driveline 5 06-16-2008 08:47 PM
legacy fwd trans in a wrx awd1320 Transmission (AT/MT) & Driveline 4 01-29-2003 09:33 PM
