Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 02-08-2011, 01:43 PM   #1
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
Default maybe someone can help me
my 98 obs auto is throwing a p1101 and starts very hard only when the engine is warm. where i have to pump the gas to get it to turn over.
where is the neutral position switch located so i can check it out? and my car does have new plugs wires coil and all that and wasnt having a problem starting until this light came on. i did try to clear the code but came on 15 mins later
any help would be great.
thanks
thegonz is offline   Reply With Quote
Old 02-08-2011, 02:15 PM   #2
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Not sure if is different on an auto but it's usually on the top of the trans in the middle so you might need take the trans out or see if you can tilt it back enough to get up there. I hope that a auto is different and they put it on the side or close to the shifter so you can get to from inside the car. I'd check the wiring first you might get lucky and find out you just had a bad connector or a short.
aclver1 is offline   Reply With Quote
Old 02-08-2011, 03:37 PM   #3
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
ill check the wiring when the snow melts
maybe you can help me mbaker Brakes, Steering & Suspension 10 08-24-2010 06:54 AM
maybe someone can help me on this mofu Newbies & FAQs 8 02-22-2005 06:41 PM
I NEED some stock Parts, Hopefully someone can help me out. MannySoobia Legacy Forum 2 09-18-2003 01:29 AM
Maybe you can help me out... canis STi Forum Archive 3 08-08-2003 03:00 PM
Maybe you can help me out! WRX4me Mid Atlantic Impreza Club -- MAIC 6 09-03-2001 04:11 PM
