Old 03-05-2012, 02:18 AM   #10376
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
Originally Posted by subie0303 View Post
Need a little advice on the aero splash guards for the sport limited. Is it worth it? Is it more functional or more for looks? Thanks!!
I was thinking the same thing, I was thinking perhaps I should get Rally Armor Mudflaps instead. They are cheaper and more functional...
Xarthan is offline   Reply With Quote
Old 03-05-2012, 12:16 PM   #10377
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
Originally Posted by FourOhFour View Post
Oh, I'm impressed with the quality of my car. In fact, my only complaint is one about almost every hatchback on the planet: Why the hell is the cargo area light so low down? My grocery bags are above it, so it's impossible to find the soda I bought that, no matter how much I try to pay attention to grab it before it is bagged, always gets put in a bag when I'm not looking. Fixed that one with some LEDs in the tailgate trim.
Quite honestly, I think stupid complaints are a great complement to a car. I hope all the problems people have are minor, easy fixes... or at least easily ignored.
(I still don't think a squeaky seat is a stupid complaint, though... if mine was doing that, I'd be at the dealer making them fix it)
care to share the DIY LED project for the tailgate....assume it was more than a simply LED bulb swap.....saw one back in another thread where a led strip was added to the trim panel...individuals mounting holes drilled out for the bulbs..and hard wired to the side cargo light.....did you do something similiar??
PAO56 is offline   Reply With Quote
Old 03-05-2012, 01:14 PM   #10378
FourOhFour
Member#: 309509
2012 Impreza
It was based on a mod on scoobymods.com that I can't seem to locate again right now... Anyway...
Ingredients:
  • 6 white 5mm LEDs, I used these
  • 6 5mm LED holders
  • resistors, what ones depend on how many and what LEDs you picked. Use http://led.linear1.org/led.wiz to figure it out for your needs.
  • a switch
  • wire. I used 13 feet of two conductor 24 awg
  • 2 pairs of quick connects
  • 2 wire taps. I used the crappy kind from walmart, but if I were doing it again, I'd use
    thesethese
Open the tailgate, remove all the trim starting with the piece nearest the hinge, then the sides. The piece near the hinge pulls towards you, the sides pull diagonally in and towards you. With the side pieces revealed, loosen the two screws and pull out the clips they are attached to, then pull down the big trim piece. If you're like me, you'll end up breaking one of the standoffs, but whatever.
The rest is just drilling, inserting the holders, inserting the LEDs, soldering, and some swearing. Wire them up following the diagram the LED wizard gave you. Put your quick disconnects so you can take the big trim panel back off the car if you ever need to without having to pull all your wiring out. Since you'll be tapping the cargo light on the driver's side, you might want to run your wires that way. Or you might decide it'd be easier to go the long way around... the grommet to the driver's side has the washer hose and the passenger side has a bunch of wires, don't know which'd be easier to snake through. If you're careful, you can snake the wires through without taking down the headliner. Also, the explosives for the side airbags is in the area, be careful of that. Disconnecting the battery would be a good idea.
When you tap the cargo light, pink is positive.
IMG_0304 by FourOhFour, on Flickr
FourOhFour is offline   Reply With Quote
Old 03-05-2012, 01:19 PM   #10379
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Ingredients:
[*]6 white 5mm LEDs, I used these[*]6 5mm LED holders[*]resistors, what ones depend on how many and what LEDs you picked. Use http://led.linear1.org/led.wiz to figure it out for your needs.[*]a switch[*]wire. I used 13 feet of two conductor 24 awg[*]2 pairs of quick connects[*]2 wire taps. I used the crappy kind from walmart, but if I were doing it again, I'd use Video Link: http://www.amazon.com/gp/product/B00389UT3I/
Pic of the final result?
SleepNMnky is offline   Reply With Quote
Old 03-05-2012, 04:18 PM   #10380
Zeeper
Member#: 299286
2015 WRX CVT
Ingredients:
  • 6 5mm LED holders
  • a switch
  • 2 wire taps. I used the crappy kind from walmart, but if I were doing it again, I'd use these
That is a realy cool mod, but I won't do this one personally -- I would probably just stick an LED tap light on the side of the car if I needed more light back there -- it just hasnt been an issue for me.
Amazon.com: Fulcrum 30010-301 LED Battery-Operated Stick-On Tap Light, 3 Pack: Home ImprovementAmazon.com: Fulcrum 30010-301 LED Battery-Operated Stick-On Tap Light, 3 Pack: Home Improvement
Zeeper is online now   Reply With Quote
Old 03-05-2012, 04:42 PM   #10381
brockd
Member#: 235571
2012 Impreza 2.0i
That's a pretty clean mod. Has anyone thrown a roof rack on the '12 impreza yet? I was looking at the roof rack thread last night and I'm feelin them.
brockd is offline   Reply With Quote
Old 03-05-2012, 06:04 PM   #10382
FourOhFour
Member#: 309509
2012 Impreza
Had to wait for it to get dark, during the day it doesn't do much.
Before:
IMG_0305 by FourOhFour, on Flickr
After:
IMG_0306 by FourOhFour, on Flickr
Old 03-05-2012, 06:26 PM   #10383
SleepNMnky
Member#: 302491
Before:
After:
Wow! Quite the difference. Thanks!
Old 03-05-2012, 06:35 PM   #10384
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
That's AH-mazing.
Old 03-05-2012, 07:01 PM   #10385
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Good for you FourohFour, that looks great!
ST Eye is offline   Reply With Quote
Old 03-05-2012, 07:11 PM   #10386
Zeeper
Member#: 299286
2015 WRX CVT
From the Owners Manual, I just noticed this in addition to the 4 warnings printed at the end of the manual...
8-16
Driving tips
Trailer towing
Your vehicle is neither designed nor intended to be used for trailer towing.
Therefore, never tow a trailer with your vehicle.
SUBARU assumes no responsibility for injuries or vehicle damage that may result from trailer towing, from any trailer towing equipment or from any errors or omissions in the instructions accompanying such equipment. SUBARU warranties do not apply to vehicle damage or malfunction caused by trailer towing.
Old 03-05-2012, 09:27 PM   #10387
T Wrecks
Member#: 305111
2012 Sport Premium
Obsidian & Dark Grey
Default 2300 RPM Whine
Has anyone heard a "whine" or slight squealing sound around 2300 rpm? I kept hearing it today on my drive home, and it was easily reproducible.
It was in a Sport with a manual trans and 175 miles on the odo.
T Wrecks is offline   Reply With Quote
Old 03-05-2012, 10:09 PM   #10388
ST Eye
Member#: 73068
I have the CVT and I hear a while when I'm on partial throttle, I always thought it was because of the CVT. If it concerns you, have the dealer check it out.
Old 03-06-2012, 07:39 AM   #10389
pxpaulx
Member#: 306218
2012 Impreza CVT
DarK Grey Met. Sport Prem
I've come to assume that the whine is the PZEV during the first 5 miles or so of driving. In order to curtail emissions during warm up it runs differently and curtails a lot of power output in order to keep the emissions low. I could be wrong, but that is what I've gathered from reading/discussing here in the forums.
pxpaulx is offline   Reply With Quote
Old 03-06-2012, 08:56 AM   #10390
bg18947
Member#: 300604
2012 Impreza Spt Ltd
2008 Infiniti G35xS
Originally Posted by RxMPLS View Post
I ordered some but haven't paid for them or installed them yet. I was going to get them because I drive on a lot of gravel roads and thought it would help prevent dinging up my paint near the rear end...do you think they'd work, or is it just not worth it?
Get yourself some 3M or Xpel paint protection film. You should be able to use the 4" size for the rocker section and bottom sides of the rear bumper. Personally, I don't think the splash guards/strakes/spoiler look good at all, but that's just my personal taste. That's why I didn't go for any of them. I was also thinking about getting 1" film for the wheelwells. I don't like black plastic trim, I prefer to see paint. It's funny how the XV gets the painted fog light area and rear bumper bottom painted, but not on the regular Impreza. I think the black plastic trim looks more appropriate on the XV.
bg18947 is offline   Reply With Quote
Old 03-06-2012, 10:03 PM   #10391
ST Eye
Member#: 73068
So I floored the car for the first time yesterday (after the 1000 mile break-in period) and I must say, it was.............. rather uneventful!
I didn't expect any more though. Not too bad with all things considered.
Old 03-06-2012, 10:10 PM   #10392
Steve Gray
Member#: 302593
2012 PremiumHatchCVT
Gray
I hear you ST EYE, I downgraded from a V6 Acura TL and I really miss the power a lot. But that's life.
Steve Gray is offline   Reply With Quote
Old 03-06-2012, 10:21 PM   #10393
ST Eye
Member#: 73068
The car this replaced was a 2000 Infiniti G20, so no loss in power. I do still have my 2008 STI
Old 03-06-2012, 10:43 PM   #10394
brockd
Member#: 235571
2012 Impreza 2.0i
Ya this car has some nice bottom end but once you get on it you're like... Meh. Haha. But man this car is sexy every time I walk out of my house and see it I have a smile on my face.
Old 03-06-2012, 10:52 PM   #10395
subarUW
Member#: 308572
Question about the navigation system. Has anyone been able to register the DivX player?
subarUW is offline   Reply With Quote
Old 03-06-2012, 10:57 PM   #10396
timmahsan
Member#: 291512
Has anyone been able to get the BT audio screen on the limited model lcd screen to output music info with an android phone? (I have a Samsung Galaxy Nexus.) I do not get any, I used to get it with my old Motorola Droid. Usually just end up turning off the screen.
Edit: found out that the latest version of the OS doesn't support metadata, AVRCP 1.3+, hope it gets implemented soon! Maybe a custom rom will support it...
timmahsan is offline   Reply With Quote
Old 03-07-2012, 09:19 AM   #10397
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
I've got the same phone and have the same problem! Were you able to get your phonebook synced with the car? None of my contacts came over, so if I need to make a call while driving I either have to do dial by number, or make the call from my phone.
imprzya is offline   Reply With Quote
Old 03-07-2012, 09:28 AM   #10398
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by BoxerSport2.0 View Post
I don't have the newest blades but I have last year's model.
I have to say that this car looks pretty damn good, nice color choice.
Angelus911 is offline   Reply With Quote
Old 03-07-2012, 11:01 AM   #10399
79letour
Member#: 302570
2013 XV
DGM!
For any of you fellow '12 beta testers need to call SOA Customer Service, ask for Desiree. Shes been very helpful in handling my issues with the car and dealer. Fwiw
79letour is offline   Reply With Quote
Old 03-07-2012, 11:15 AM   #10400
MINIz guy
Member#: 305218
I don't want to be a beta tester...
MINIz guy is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
