Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 05-03-2012, 12:26 PM   #11676
bawoodvine
Member#: 316075
Originally Posted by Angelus911 View Post
Emailed Gary at Manchester Subaru yesterday and my car got on the truck yesterday and should be here in 1-2 weeks...can't wait! Do all of the Impreza shipments come in from the West Coast?
I got my Impreza just north of Boston, and it came in via Rhode Island. I got the impression that all of Subaru of New England cars come in to that port.
bawoodvine is offline   Reply With Quote
Old 05-03-2012, 12:28 PM   #11677
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Default key hole TSB
hey : if any one of you guys go out there and get this addressed, can you report back to us on how it goes.
TSB 12-129-12R Steering Column Cover / Key Lock Cylinder (revised)
interestingly enough, i think this morning i figured out potentially the source of my intermittent rattle* from the steering column area. it seems there is some play between the shroud that goes to other side of the steering wheel and the main dash panel. i was able to move it around and get it to make my creak/ticking sound. my solution (tomorrow) when the car is cold enough, is to stick a piece of cardboard between the panels to see if that can quell the sound. if so, i may do my home solution of something similar but hidden.
i don't want to do anything to permanent, though since it's unclear to me how this whole steering wheel cover fits together (i only played around with this about 3 minutes before my train arrived) as that being properly centered might also help with my problem. all the piece seem loosely connected so that one thing i realize is that by stuffing card stock at one location can create a sound/creak at another location (i sort of was able to generate that response this morning in moving the sound from the left to the right side of my steering column even though there really doesn't appear to be any play on the right side (i wonder if this is like trying to balance a wobbly chair where i'll need to get it just right)
anyway, i digress. i just wanted to see if there is success for people in getting that key hold better aligned and whether their assembly is "stiffer" after this fix is implemented for them.
*it goes away if the car has been sitting in the car long enough presumably because the warm plastic expands and then there is not longer a gap or play which allows the sound/rattle to occur.
nubsub is offline   Reply With Quote
Old 05-03-2012, 12:31 PM   #11678
nubsub
Member#: 313575
Default Rattling passenger head rest...
hey guys, i seem to recall someone else having this issue...
do any of you have a passenger headrest that rattles? i'm pretty sure that is the source of my second annoying rattle (first being the steering column one)...i tried to play with the height and tilt of the headrest but didn't have any luck in mitigating it. then again, it seems to come and go and depend on just how rough/bumpy the road is. it could be coming from somewhere else, but that's where i think my rattle is coming from...something at ear level on the passenger side and i do note there is a lot of play in that head rest in all directions (same is true for driver's side, but my head resting against it probably keeps it from rattling).
any suggestions on what i can do to eliminate this play (without destroying the functionality of an adjustable headrest)?
Old 05-03-2012, 12:34 PM   #11679
nubsub
Member#: 313575
Default Oil level gauge TSB
(yes i have free time here so i'm looking at the tech website)...
anyone else see this:
Service Bulletin # 02-127-12
Pages: 2
Bulletin Description: The purpose of this bulletin is to inform you of a change made to the oil level gauge and guide. On a rare occasion, there is a possibility that the oil level gauge could get damaged if too much force is applied when installing or removing it. As a result, the diameter of the oil level gauge was increased along with the inside diameter of the oil level guide (dip stick tube).
i wonder if this is the issue a few people have been having where the dip stick read one thing and the sensor said that the oil level was low.
Old 05-03-2012, 12:40 PM   #11680
Angelus911
Member#: 89967
2012 Impreza Sport
Interesting, maybe it'll be closer to the 1 week estimate then since its only going to NH. I need to get my a$$ in gear with insurance and loan stuff then!
Angelus911 is offline   Reply With Quote
Old 05-03-2012, 01:38 PM   #11681
Kameha
Member#: 300781
Can anyone confirm if the tilting headrest from '12 impreza would fit in '12 legacy. Thanks
Kameha is offline   Reply With Quote
Old 05-03-2012, 01:43 PM   #11682
subi2.5i
Member#: 236778
08 Impreza
Good question. Ide go to a dealer and test it out if theres one near you.
subi2.5i is offline   Reply With Quote
Old 05-03-2012, 01:44 PM   #11683
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Originally Posted by nubsub View Post
i'm not holding out hope, but that is one accessory i would be willing to pay a fair a bit to upgrade to.
i sort of doubt it though, since i think it's integrated with the HVAC system and other things and would make lots of things in our 2012 impreza controls/dash redundant.
That is correct, the Canadian HVAC does have different controls from the pictures I have seen.
ST Eye is offline   Reply With Quote
Old 05-03-2012, 02:09 PM   #11684
imcausinmadrukis
Member#: 318978
Is there any place that sells any performance parts for the 2012 Subaru Impreza 2.0i Sport Premium??
Headlights
Foglights
Body Kits
Exhaust Systems
Air intake systems
Ect..
It doesn't seem like no one is selling any parts. Please help!!!
imcausinmadrukis is offline   Reply With Quote
Old 05-03-2012, 02:14 PM   #11685
ST Eye
Member#: 73068
Headlights
Foglights
Body Kits
Exhaust Systems
Air intake systems
Ect..
I think you're going to have to wait a bit longer for the aftermarket to catch up.
Old 05-03-2012, 02:17 PM   #11686
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Originally Posted by elkgrovejerry
Part #92177AG07A Small cup mat list $19.94 net $12.67
Thank you!
SleepNMnky is offline   Reply With Quote
Old 05-03-2012, 10:57 PM   #11687
2007imprezi
Member#: 199120
2012 Impreza 2.0i
Obsidian black pearl
Well goods new.....Air bag light came back on again tonight with 4888 miles.Emailing Subaru here in about a minute.This is the 3rd time they need to fix it instead of resetting the light.Just because I took a short video for Subaru. http://www.youtube.com/watch?v=fn9kX...ature=youtu.be
2007imprezi is offline   Reply With Quote
Old 05-04-2012, 12:23 AM   #11688
ST Eye
Member#: 73068
Yup, get SOA involved. This is a documented issue they are aware of. The same issue I had with my first car.
Old 05-04-2012, 02:47 AM   #11689
brockd
Member#: 235571
2012 Impreza 2.0i
FINALLY found an annoying rattle i was having. i thought it was in the dash, was driving me nuts, turns out it was the visor... right where the cloth wraps around the part that clips in... if that makes any sense. i pushed that part and the "rattling stopped" praise the lord!
brockd is offline   Reply With Quote
Old 05-04-2012, 08:44 AM   #11690
ammo_umb
Member#: 316152
2012 Sport Limited
Camellia
Good to hear the rattle is gone! For me noises like that were rarely where I thougt they were. My Wrangler rattle pretty bad and I thought it was a dash vent so I pulled the vent out, put a little rtv around the edge and stuck it back in. I took it for a drive and the rattle was still there. I sold the Wrangler to buy a Titan and noticed right away that it rattled too, this time the noise was coming from the visor. I checked the retaining clamp, the mirror cover, the mount and they were all good.
It turns out that it was a loose button in my garage door opener that I had clipped on the Wrangler visor then the Titan visor...
ammo_umb is offline   Reply With Quote
Old 05-04-2012, 09:23 AM   #11691
nubsub
Member#: 313575
Congrats! I'm jealous. I thought stuffing some card stock in a crack would get rid of a rattle but I was wrong. Back to the experimenting. ...
Old 05-04-2012, 01:10 PM   #11692
make_light
Member#: 317017
2012 Impreza CVT
Dark Gray Metallic
Same problem here, both front seats. It is incredibly annoying, plan on taking my car in next week. Granted, these aren't the only rattles I have but they are the most consistent. Holding the headrest in place fixes the problem, but alas it is a rather impractical solution
make_light is offline   Reply With Quote
Old 05-04-2012, 01:22 PM   #11693
ST Eye
Member#: 73068
I was able to raise the headrests up a bit to get rid of the rattle. That in conjunction with the position of the seatback fixed the problem (originally the passenger seatback was vertical at like 90 degrees).
Old 05-04-2012, 01:34 PM   #11694
nubsub
Member#: 313575
thanks for sharing: please report back on what you get out of the dealer. i don't know if there is a simple solution. i have trying to come up with some creative solution myself that is a bit better than removing the headrest until i have a passenger
hopefully, the dealer can do something and if so, i can have my dealer do something similar or duplicate the effort myself if it's a simple fix/solution.
Old 05-04-2012, 01:35 PM   #11695
nubsub
Member#: 313575
ah...i knew i wasn't imagining reading that someone had posted on this. i think it was you i haven't figured mine out yet using your method...
raising the headrest up (it seems to only have 3 settings total) doesn't seem to help my problem. i haven't tried all angles of tilts yet, but the few i've tried don't seem to help either. there is just a lot of play in these headrests. i don't think my driver side is an issue both because my head is resting on it when i'm driving and also it seems to have a little less play than the passenger seat one.
Old 05-04-2012, 02:00 PM   #11696
SleepNMnky
Member#: 302491
My head rests have little to no wiggle room & no rattles. I have mine down all the way, tilted forward with no issues. My seat is reclined, but for comfort more so than rattle issues. How are your back head rests? Do they fit the same way?
Old 05-04-2012, 02:09 PM   #11697
nubsub
Member#: 313575
this is good information: both of my front head rests have a fair bit of play. i haven't heard any rattle from the driver's one so i'm guessing that the "play" has reached the critical point on the passenger one, or my head is responsible for keeping the driver's one from rattling. (my driver's headrest is at the lowest setting (all the way down) and with no tilt)
so you tilt your headrest forward? how far? quite honestly (and no offense is intended towards anyone who likes it with an extreme tilt!) i thought the tilting headrest was a peculiar "feature" that i've never had in any car before. are you really tall such that the head rest nests into your neck? or do you just like having your head forced slightly forward?
i haven't played with my rear ones at all. that's a good thing to check out. i'll check this weekend.
it seems like this should be a simple problem to fix, but i haven't come up with a simple solution to remove the play in the headrest (i'm guessing it's more the posts that allow vertical adjustment than the tilt feature, but i could be wrong)
Old 05-04-2012, 02:43 PM   #11698
SleepNMnky
Member#: 302491
I have it two clicks forward but my seat is reclined quite a bit. It actually sits about a half inch behind my head. I can "rest" my head if I want but out of habit I don't. It was intended & noted as a safety feature to prevent whiplash in some article I read about being number one safety pick in its class.
Old 05-04-2012, 06:22 PM   #11699
nubsub
Member#: 313575
interesting. i'll try two clicks and see what it does for the passenger seat as well as experiment with it for my driver seat.
Old 05-04-2012, 10:07 PM   #11700
ammo_umb
Member#: 316152
2012 Sport Limited
Camellia
I finally got a VIN and a delivery date so as long as the planets stay aligned right my car will be here on May 22nd!
My thanks go out to all those that offered advice, sent PM'S to tell me where there were other cars and wished me luck. All of it was very hepful!
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
