Old 05-25-2012, 10:23 PM   #12251
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
Originally Posted by flyboy1100 View Post
then actually i think i would be ok with polk 651's for the doors. unless they are set to a similar setup. i have time to decide.
Don't know. 8K is a pretty high crossover frequency. Usually it's that high when the slope of the cutoff isn't steep (6db/octave). A better crossover would have a steeper slope (12db/octave or better), then they could do a crossover at 4K or lower and get more music into the tweeter. The stock tweeter is just plain cheap.
I didn't check the capacitor on the upgrade Kicker tweeters before I installed them. If anybody has them on the way, maybe you could post the ohms rating and the numbers on the capacitor before you install them.
tomwi53092 is offline   Reply With Quote
Old 05-25-2012, 11:52 PM   #12252
FastJK
Member#: 317325
2012 Impreza Hatch
Originally Posted by auskip07 View Post
Put Rubber spring spacers in the Rear of the car and raised it 3/4" Looks really good
Pics or it didn't happen.
FastJK is offline   Reply With Quote
Old 05-26-2012, 12:01 AM   #12253
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Charging the camera. ill take them in the morning.
auskip07 is offline   Reply With Quote
Old 05-26-2012, 12:31 AM   #12254
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
oh, i don't have the factory, i ordered my car with the kicker tweeters
Old 05-26-2012, 12:35 AM   #12255
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
got my car torn apart right now in an attempt to install my sirius tuner/forester radio. everything works as advertised, however the old style install kit doesn't work with our setup. with the redesign, i can't place the tuner on top of the radio with the brackets, it interferes with the vents. I might have to do double sided tape or fab up some brackets to get this installed.
i was hoping for easy
Old 05-26-2012, 09:44 AM   #12256
Tjohns
Member#: 314510
2012 Impreza2.0i 5D
Red Pearl
Default Rear suspension
A friend was following me the other day and asked what was wrong with my rear tires. He said they looked like they're tipped in. I looked at the car in the parking lot and the rear tires indeed look like they are canted in at the top. It's as if I have a heavy load in the hatch. Almost a month ago I had measured the clearance between the top of the tires and the wheel arch and responded to a post by auskip07. Well, repeating that measurement today seems to indicate that the rear has settled down by 1/2 to 3/4".
Auskip07, perhaps this is what you posted about originally and I didn't see until there were some miles on my suspension. I'm curious if anyone else has seen this.
Tjohns is offline   Reply With Quote
Old 05-26-2012, 10:36 AM   #12257
brentanthony33
Member#: 321350
2012 Impreza 2.0
Legacv 2.5
Originally Posted by ST Eye View Post
Yup, get SOA involved. This is a documented issue they are aware of. The same issue I had with my first car.
Did you figure out what what causing this? My 2012 impreza isn't doing it but my dad's 2012 is with 7,000 miles. I noticed also when this happens the passenger air bag light switches to OFF when there is a passenger. Obviously not good.
brentanthony33 is offline   Reply With Quote
Old 05-26-2012, 11:25 AM   #12258
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
3/4" rear lift Circular Spring Spacer
New gear shift
Old 05-26-2012, 11:30 AM   #12259
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
New gear shift
You know by changing the ride height you likely changed the geometry of the suspension thus needing an alignment? I know this is the case with the toe adjustment on the front suspension.
ST Eye is offline   Reply With Quote
Old 05-26-2012, 11:30 AM   #12260
ST Eye
Member#: 73068
Check out the thread that I created regarding this issue in the same sub-forum.
Old 05-26-2012, 12:22 PM   #12261
TJMA
Member#: 304306
2012 Impreza-premium
Ice Silver
My 2012 Impreza got its first oil and filter change thursday 5/24. I had reported in an earlier post that when opening and closing the hood it was rubbing the paint off of a part of the drivers side front fender. The dealer looked at it and had their body shop repair it. The fender was too high and needed to be lowered. they repainted the fender and it looks great. The dealership did a great job. I am pleased with them.
TJMA is offline   Reply With Quote
Old 05-26-2012, 12:37 PM   #12262
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
New gear shift
where did you get the knob? i assume you got the Perrin installed?
Old 05-26-2012, 01:22 PM   #12263
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Yes yes im well aware of what lifting and lowering a vehicle does to Camber and how to fix and look for problems. I dont appear to have any negative camber because of how small the lift is. So im going to roll with it and maybe see if i can adjust the spacer a little more when it settles.
Ebay. cheap aluminum. Wished it was heavier but i like the way it feels. The knob came first. 29th (tuesday) for the perrin then my weekends are packed for the next couple weeks. (i thought i already told you that?)
Any advice on removing the center console? If i can find out how that would make the install quicker thus the write up will come quicker.
Old 05-26-2012, 04:19 PM   #12264
ST Eye
Member#: 73068
Not just camber. If you read my post I mentioned toe. It may affect the rear as it certainly does for the front.
Old 05-26-2012, 04:29 PM   #12265
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Alright ill look at that.
Old 05-26-2012, 05:32 PM   #12266
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
do you have the repair manual? it is described in there pretty well. 15.00 on ebay for a pdf copy, well worth it so far when i was doing my radio this weekend.
Old 05-26-2012, 06:23 PM   #12267
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Nah, Ill just figure it out. I wont pay for a manual.
Old 05-26-2012, 06:32 PM   #12268
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Just saw this post. mine has looked low since i got the car so it must have settled on the lot while waiting to get picked up. These spacers have fixed the problem if i was going to do this again i would zip tie the spacers to the Coils to ensure they would stay put.
I can seem to eye suspensions pretty good. Coming from a sports car background ive done my fair share of suspensions so i was less than pleased with the ass down look of my subaru.
First couple of days i snapped this pic and didnt think much of it after seeing it at this angle.
Old 05-26-2012, 07:06 PM   #12269
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Had my car for 3 1/2 days, and the check engine light just came on. It's solid, not blinking, and the service rep told me it was fine to keep driving it until Tuesday when I'll bring it in.
gfxguy is offline   Reply With Quote
Old 05-26-2012, 08:11 PM   #12270
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Blinking are the bad ones. It could just be a simple issue. harness worked its way loose or something of that nature
Old 05-26-2012, 09:05 PM   #12271
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
well, i might be taking all that stuff apart to find the bit hold i just dropped into the depths of my car
Old 05-26-2012, 09:25 PM   #12272
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
I took it to oreilly to get it scanned and got code P000A. According to this site http://www.dtcdecode.com/P000A :
Code: P000A
Category: Powertrain
Definition: A Camshaft Position Slow Response Bank 1
No idea what that means....
Old 05-26-2012, 09:49 PM   #12273
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Code: P000A
Im not sure how well you know the engine but im taking a guess that these sensors are located at the front of the engine on the ends with a circular cap covering them. one is located under the oil filter assembly. you can reach it easily
Old 05-26-2012, 11:33 PM   #12274
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Yup, that's them (I got a copy of the service manual off ebay just now and checked). I checked the connectors for the camshaft position sensors and oil control solenoids and everything seemed fine, but now the light's off! Thanks for your advice.
Old 05-26-2012, 11:54 PM   #12275
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
I'm reading 3.6 ohms for the kicker tweeters. The capacitor is glued in and I can barely see the rating; looks like it's either 4.1 or 4.7 uF (the top is cut off).
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
