Old 05-27-2012, 12:14 AM   #12276
Blktrax
Member#: 220971
2002 WRX 213K Mi.
Original Motor and Turbo
Originally Posted by gfxguy View Post
I took it to oreilly to get it scanned and got code P000A. According to this site http://www.dtcdecode.com/P000A :
Code: P000A
Category: Powertrain
Definition: A Camshaft Position Slow Response Bank 1
No idea what that means....
Is it still filled with factory oil or has it been changed already?
This is common when the wrong heavier weight or conventional oil is used.
Requires: 0w20 Full Synthetic
Blktrax is offline   Reply With Quote
Old 05-27-2012, 12:52 AM   #12277
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Still has factory oil. Less than 100 miles on the odometer.
gfxguy is offline   Reply With Quote
Old 05-27-2012, 12:56 AM   #12278
adanacsman
Member#: 305592
2012 Impreza CVT
5-Door SWP
Originally Posted by cookcle View Post
Well did some research. $250 for a primered only bumper from subaru. $600 for the bumper, painted, installed from a local body shop. Wondering when the best time to go ahead and replace it would be. Now during summer, or fall. I do a LOT of highway driving weekly so I'm thinking I'd be better off waiting a few months until the bugs die down and do it before winter rolls back around. Sucks driving something new with visible damage, she feels tainted
I have a small two inch crack on my lip as well and I was quoted 600 to fix the bumper, not replace it. Damn expensive Canadian labour
adanacsman is offline   Reply With Quote
Old 05-27-2012, 01:11 AM   #12279
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Old 05-27-2012, 02:56 AM   #12280
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
For the stocker, 8Khz is the -6dB point. Keep in mind it's more of a midrange than a true tweeter. My guess is they chose such a low capacitance to match the woofer's sensitivity.
Commander Keen is online now   Reply With Quote
Old 05-27-2012, 11:28 AM   #12281
Schoolcraft
Member#: 314770
So I have a 2012 sport premium impreza and I have a question about my drivers seat. I was driving one day and started to accelerate and all of a sudden I feel the seat move back slightly and it made a sound like it was clicking into place after being adjusted. It feels more like the lumbar support inside the seat broke off and now I don't feel like there is any support in the seat.
When I sit in the passenger seat to compare, there is a significant difference in the amount of lumbar support so my thoughts are that it broke off. I am 185 pounds so it's not like I should have damaged it but I was wondering if this a problem someone else has had and if the warranty will cover it.
Schoolcraft is offline   Reply With Quote
Old 05-27-2012, 11:43 AM   #12282
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Sat input sounds different than bt or radio, it is somewhere in the middle of the 2. There is a definite lack of bass and the highs are a little harsh.
Going to be trying new speakers for sure now in the future, maybe next month
Old 05-27-2012, 11:51 AM   #12283
Zeeper
Member#: 299286
2015 WRX CVT
There was the same complaint from a WRX or STI owner recently on the General Forum, bring it to the dealer for warranty repair.
Zeeper is offline   Reply With Quote
Old 05-27-2012, 12:23 PM   #12284
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
If your seat is broken it should not be a problem with vetting it fixed under warranty.
ST Eye is offline   Reply With Quote
Old 05-27-2012, 03:47 PM   #12285
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Originally Posted by ST Eye View Post
You know by changing the ride height you likely changed the geometry of the suspension thus needing an alignment? I know this is the case with the toe adjustment on the front suspension.
When do you think they aligned the vehicle? at the factory before the suspension settled? Wonder if this could be causing 1-2 mpg loss if the vehicle is out of spec from dealer.
My vehicle has an 01/12 build date I bought it 04/12
auskip07 is offline   Reply With Quote
Old 05-27-2012, 04:00 PM   #12286
imcausinmadrukis
Member#: 318978
Anybody buy the rear seat back protectors on the impreza hatchback? I have until the end of this month to make a decision before my coupond code expires. If you have it what are ghe pros and cons?
imcausinmadrukis is offline   Reply With Quote
Old 05-27-2012, 04:22 PM   #12287
TJMA
Member#: 304306
2012 Impreza-premium
Ice Silver
I'm thinking about putting the Subaru body side molding on my 2012 Impreza and doing it myself. Has anyone done this? Any things to watch for when doing it?
TJMA is offline   Reply With Quote
Old 05-27-2012, 04:24 PM   #12288
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Make sure its in a straight line. Some thin line striping tape should work as a guide. then attach.
Old 05-27-2012, 04:40 PM   #12289
03Indigo
Member#: 87505
2012 WRX Hatch Black
2012 5door 2.0i red
When you buy the kit, it comes with templates, huge thick tag board with instructions and marker lines...you can't mess it up. I will be doing it on both my cars when they come in.
OK, in searching, and the nearly 12,300 posts in this thread, and not having any luck after over an hour.....any information on the sway bar and suspension on the new body style Impreza? Are they the same dimensions as the last gen model? I have both a 2012 Impreza 2.0i and a 2012 WRX coming in next month, and I have coil overs and a 25mm sway for the WRX, but want to put the stock wrx suspension on the Impreza to make it more responsive and sporty, along with the 19mm STi sway bar I had on my 2011 Outback. Has anyone seen a comparison of those parts? If not, I will figure it out by June 18th when the cars both come in . I'm just excited and and trying to figure it out now. Sorry if this has been covered, but I did search, and there are an awful lot of posts and replies in this thread...an nothing specific that I could see about the suspension and sway bars. Thanks in advance to anyone that can help.
03Indigo is offline   Reply With Quote
Old 05-27-2012, 04:45 PM   #12290
03Indigo
Member#: 87505
2012 5door 2.0i red
only thing I could find is this quick vid, poor quality, but in pause mode, the sway looks to be the same.
http://www.youtube.com/watch?feature...&v=MD-BAqFfywU
Old 05-27-2012, 04:59 PM   #12291
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
Pros- it basically makes your cargo tray longer with the protection.
I don't see any cons, it was pretty dang cheap, like 40'ish bucks. I got it to protect my rear seats when I put my bikes in there.
Xarthan is offline   Reply With Quote
Old 05-27-2012, 05:04 PM   #12292
ST Eye
Member#: 73068
The only thing that is known is the 08+ STI Rear Sway Bar will fit in the new Impreza. It is a direct fitment.
Old 05-27-2012, 05:10 PM   #12293
ST Eye
Member#: 73068
While cars will settle over time, I'm not sure that it would cause too much issues with regards to the alignment. The only problem you could potentially have is the fact you modified the rear suspension, that in itself could change your alignment numbers.
Do you have a set of toe plates? That will allow you to check your total toe. Positive or negative toe can affect your fuel efficiency, camber has less of an effect on MPG and more on tire wear.
Old 05-27-2012, 05:44 PM   #12294
03Indigo
Member#: 87505
2012 5door 2.0i red
Thanks. Once both cars are here, and I put the coil overs on the WRX, I will then try to fit the WRX suspension into the 2.0. I'll keep you all up dated. Gonna toss the 19mm STi sway I have on the 2.0 and go from there.
Old 05-27-2012, 06:24 PM   #12295
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i want to know if the front bar fits
Old 05-27-2012, 06:24 PM   #12296
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
mine are ordered and should be in next week.
Old 05-27-2012, 06:42 PM   #12297
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
First, it doesn't make sense to me to get the seat back without getting the companion trunk floor protector.
No cons, other than the plastic doesn't look quite as nice as the carpeting. I have hauled buckets of compost and don't worry if I scuff it a bit. Also, clean up with a shop vac is very fast.
I'll be hauling landscaping bricks this fall, I wouldn't want to worry about trashing the carpeting doing this.
tomwi53092 is offline   Reply With Quote
Old 05-27-2012, 06:48 PM   #12298
tomwi53092
Member#: 316315
DCP
It comes with cardboard template for each door to line it up. However, if you want to get it really right, I suggest a four foot (or longer) straightedge (I used a four foot metal ruler) to make sure the top edges of each door template are perfectly aligned.
Just triple-check your alignment and you'll be fine. The moldings just stick on.
Old 05-27-2012, 06:51 PM   #12299
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
No i dont have a set of toe plates. I dont believe there to be an issue with the toes in the rear only with the front since i adjusted the strut angle with adjusting the rear.
If i modified it closer to where it was before it settled then i dont believe i have done anything wrong. If you could give me measurements of your non settled car i could get an idea of how much it has changed with my modifications. care to help out? Then again your alignment could be more off than mine if it has settled.
Old 05-27-2012, 09:13 PM   #12300
ST Eye
Member#: 73068
Are you looking for the rear camber angle?
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
