Old 05-27-2012, 09:26 PM   #12301
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
The check engine light came back on while driving around today. Not surprised, there's probably a loose connection somewhere. Not gonna fiddle with the wiring again so that the dealer can hopefully diagnose the problem and fix it permanently.
gfxguy is offline   Reply With Quote
Old 05-27-2012, 09:28 PM   #12302
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Good idea, I wouldn't mess with anything. If they are open tomorrow, I would give them a call. Perhaps you can get a loaner in the meantime.
ST Eye is offline   Reply With Quote
Old 05-27-2012, 09:41 PM   #12303
79letour
Member#: 302570
2013 XV
DGM!
Originally Posted by Schoolcraft View Post
So I have a 2012 sport premium impreza and I have a question about my drivers seat. I was driving one day and started to accelerate and all of a sudden I feel the seat move back slightly and it made a sound like it was clicking into place after being adjusted. It feels more like the lumbar support inside the seat broke off and now I don't feel like there is any support in the seat.
When I sit in the passenger seat to compare, there is a significant difference in the amount of lumbar support so my thoughts are that it broke off. I am 185 pounds so it's not like I should have damaged it but I was wondering if this a problem someone else has had and if the warranty will cover it.
My car did/does the same thing. I was told it would be fixed under warranty, but the seats are on backorder. Seems there is very little in the way of replacement parts availaible. Call SOA and ask for Desire'.
79letour is offline   Reply With Quote
Old 05-27-2012, 09:46 PM   #12304
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
I called them yesterday and have an appt for Tuesday morning (they said they'd have a loaner ready for me). I just couldn't resist trying to diagnose and fix the problem myself last night though.
Old 05-27-2012, 09:50 PM   #12305
SJwagon
Member#: 309056
2012 Impreza 2.0
Satin White Pearl
OMFG... me too.. and now when I drive above 70mph something rattles in the engine bay or something.
SJwagon is offline   Reply With Quote
Old 05-27-2012, 10:23 PM   #12306
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Are you looking for the rear camber angle?
Height. But dont worry about it. With the Coil Spacers im 1/8" over of what new car sitting on the lot is. (i was cruising around and saw a subaru dealership so i pulled in and went over to what looks like a newly delivered subaru) So looks like the coil spacers fixed the rear settlement. If i hadnt fixed the rear im sure i would need an alignment more since i would be almost 3/4" lower than it should be
auskip07 is offline   Reply With Quote
Old 05-27-2012, 10:55 PM   #12307
ST Eye
Member#: 73068
Just measured, on my limited it is 26.5" from floor to the rear quarter where it curves inward.
With regards to the alignment, there isn't much you can do with the rear suspension. Perhaps a toe adjustment only. There isn't a rear camber adjustment (there isn't on my STI, so I assume not on the new Impreza).
Old 05-27-2012, 11:04 PM   #12308
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I would need to know where so i could compare measurements. We talking center of the wheel? Far rear side of the wheel well. Lots of curves on the car.
Something definite like where the tail light forms a V or the bottom most part of the rear wheel well. A point on a curve is very hard to put a definite location on.
Old 05-27-2012, 11:09 PM   #12309
ST Eye
Member#: 73068
Center of the wheel/wheel well. I took the measurement from the outer curve, not the inner part of the fender lip. That measurement would be lower.
Old 05-27-2012, 11:17 PM   #12310
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Thanks ST Eye, i am at 26.5" or very very close. with my spacer.
Old 05-27-2012, 11:19 PM   #12311
ST Eye
Member#: 73068
No problem. Do you happen to have a before and after pic of your car?
Old 05-27-2012, 11:21 PM   #12312
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I do but the angle isnt the greatest for comparing. i didnt have a straight side view before only a skewed angle from the corner. Do you have a pic of your vehicle. after reading your last post im not sure that we are measuring to the same area. I was center of the wheel from the ground to the wheel well lip (where the body starts) Your measurement point sounds like its to the second arc above where i measured?
Old 05-27-2012, 11:23 PM   #12313
ST Eye
Member#: 73068
These spacers you did, did you install them on top of the tophats?
Old 05-27-2012, 11:31 PM   #12314
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
No they are in between spacers.
Link:
Amazon.com: Superior 18-1901 Donut Style Coil Spring Spacer: AutomotiveAmazon.com: Superior 18-1901 Donut Style Coil Spring Spacer: Automotive
I do have an exterior coil compressor so if i needed to i could install a spacer on top or bottom but it was much easier. Jack up the side, pop them in and, position them in the same spot on both sides then lower and repeat.
Old 05-28-2012, 02:00 AM   #12315
Jakesnake113
Member#: 319615
So i got a $50 giftcard to my local dealer for accessories and i was thinking about getting either the cargo organizer or the cargo nets, but from the pictures online i can't really see what the cargo nets even do for the hatchback. Anybody had any experience with either of these?
Jakesnake113 is offline   Reply With Quote
Old 05-28-2012, 02:29 AM   #12316
brockd
Member#: 235571
2012 Impreza 2.0i
Wish my dealership would give me stuff like that.
brockd is offline   Reply With Quote
Old 05-28-2012, 02:37 AM   #12317
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
I personally have the rear seat back cargo net. Puts it at the seat backs instead of the hatchback so it doesn't impede on the hatch space/functionality much. It's perfect for rain jacket, scarves, hat (in the winter) etc. & I tuck my wiper fluid, etc between that & the seat back to keep it from sliding rolling around. I have the cargo tray & those nets & it keeps everything I need organized & out of the way.
SleepNMnky is offline   Reply With Quote
Old 05-28-2012, 08:38 AM   #12318
Zeeper
Member#: 299286
2015 WRX CVT
I have the side cargo nets, they don't really impede on the space in the hatch but probably because they are pretty small. I have the organizer and I like it a lot.
However, $50 isn't enough to buy the subaru one (or barely enough depending upon what they discount it as). FYI I was in Target and there is a rubbermaid version that I think also folds for under $30.00.
Zeeper is offline   Reply With Quote
Old 05-28-2012, 09:41 AM   #12319
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Also think about things you need like touch up paint Its not quite 50. If you have nice wheels or plan on getting them Wheel Locks are a good addition.
Old 05-28-2012, 10:40 AM   #12320
Jakesnake113
Member#: 319615
Is this touch up paint something i could apply myself without any additional equipment? Im assuming id just use it as little scratches/chips appear with time?
Old 05-28-2012, 10:51 AM   #12321
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
usually a pen/marker/brush
Old 05-28-2012, 01:34 PM   #12322
ST Eye
Member#: 73068
Subaru's touch-up paint is identical to the Duplicolor ones that you can find at the auto parts store - that is the bottle and applicator. However the paint is specific to your color car. I think Duplicolor makes the touch-up paint for Subaru.
Old 05-28-2012, 11:09 PM   #12323
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Those of you with the fog light films, how are they holding up? I was thinking about trying out headlight armor drive they make them for our cars. I do only own to use them in crappy weather otherwise they are off
Old 05-28-2012, 11:19 PM   #12324
ST Eye
Member#: 73068
Mine are holding up fine. Look the same as when I put them on.
Old 05-28-2012, 11:54 PM   #12325
SleepNMnky
Member#: 302491
Mine are the same too... no signs of any wear. Only had them on a month or so but they've seen their share of rain & rocks from some country roads with no issues.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
