Old 06-14-2012, 04:38 PM   #12651
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Originally Posted by Haunty
The sport is only 0.2 inches higher ground clearance which is pretty insignificant. But I do wonder what it is that gives it the extra 0.2 inches.
I for one am grateful for the extra clearance even if it is just .2 inches. Wish it was more actually. I drive up and down some pretty scary roads and driveways and have even scraped my front sub frame on a driveway that was humped in the middle. Probably should of held out for the XV for max clearance.
jr0bb5 is offline   Reply With Quote
Old 06-14-2012, 04:42 PM   #12652
Furiousd1983
Member#: 295099
2013 Not so Hot HB
Took the car to the dealer. Couldn't get the airbag warning to replicate but they went ahead and documented the issue. Just in case it ends up being more than one time thing.
Furiousd1983 is online now   Reply With Quote
Old 06-14-2012, 05:58 PM   #12653
WLS
Member#: 316030
Doesn't the Sport (and the impreza Limited) have the 17inch tires? I'm thinking of eventually replacing the 205 50's with 205 55's for a few tenths gain in height.
WLS is offline   Reply With Quote
Old 06-14-2012, 07:04 PM   #12654
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Yep you found it.
auskip07 is offline   Reply With Quote
Old 06-14-2012, 07:27 PM   #12655
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Never could find the .2 inch difference on the 2012 Sport and also the 2008 OBS over the other models with the same tires. For 2012, the Limited and the Sport have the same tires, so that can't be it.
G-Omaha is offline   Reply With Quote
Old 06-14-2012, 07:34 PM   #12656
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
So the extra height is from the struts then?
Old 06-14-2012, 09:21 PM   #12657
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Originally Posted by Furiousd1983 View Post
I know you dealt with this with your first Impreza. Did the light come on and just stay on? Mine was on last night but not this morning.
No, the light went off when I power cycled the car. The code is stored though. It happened to my car twice in ~500 miles.
Did they scan the car for a code? If so, they should have seen it.
ST Eye is offline   Reply With Quote
Old 06-14-2012, 09:24 PM   #12658
ST Eye
Member#: 73068
I just installed a backup camera in my car. Check it out in another thread I posted:
http://forums.nasioc.com/forums/show...7&postcount=42
Old 06-14-2012, 10:07 PM   #12659
DaveM
Member#: 4503
2012 Imp Sport Ltd
Camellia Red
Isn't it obvious where the .2" difference comes from?
Q: What does the Sport have that other models don't have?
A: Helium filled roof rails (provides a .2" suspension lift).
DaveM is offline   Reply With Quote
Old 06-14-2012, 10:24 PM   #12660
Furiousd1983
Member#: 295099
2013 Not so Hot HB
No code came back but The tech went ahead and documented everything for when SOA calls to follow up. Just in case it happens again. I'm glad I happened to think to snap a pic of the dash while it was on.
Old 06-14-2012, 10:27 PM   #12661
ST Eye
Member#: 73068
Furious, that is what they said the first time I brought my car in. TBH, I think the guy just cleared the code because SOA said that airbag lights (even if they go off) store a "hard code" and won't erase unless you clear them.
At any rate, at least they documented it. However if it persists, I would reference the TSB and have them replace the module.
Old 06-14-2012, 10:38 PM   #12662
CLL_OBP
Member#: 310435
2012 Sport Limited
PUP 5W20 93,516 miles
Originally Posted by jr0bb5 View Post
Interesting. I'd be afraid of deforming the plastic using a torch or even a heat gun, but I guess it worked out fine for you. The grille really just snaps out? I thought there were also 4 screws that need to be removed? Or did you just take off the silver parts of the grille?
As long as you wave the heat back and forth, it won't deform. You have to take out all those plastic rivets on the top in order to get your hand down there and have a good view. Then you have those 4 things at the bottom that you have to pinch to remove. Those 4 screws are holding the piece on each side of the emblem, 2 each.
CLL_OBP is offline   Reply With Quote
Old 06-15-2012, 10:43 AM   #12663
Furiousd1983
Member#: 295099
2013 Not so Hot HB
While I was at the dealer yesterday with the airbag light issue. The tech gave me a copy of the TSB that was released on 5/29/12 regarding issues with the passenger seat airbag issue for models built prior to Feb 2012. It covers the faulty sensor and the Ipod/Iphone/Ipad interference issue that some have experienced. Until the airbag warning lights up again. I'm going to write mine off as the latter.
Old 06-15-2012, 11:08 AM   #12664
An owned guy
Member#: 313318
2012 Impreza
Deep Cherry Pearl
Originally Posted by TObject
Why? They are scraping speed humps as is. The slightly raised Sports seem to be more desirable here.
Somebody complained his suspension sagged and he had to install spacers.
Yeah i can't Imagine going any lower. I already hit curbs when parking if not careful (use to other cars being taller then curb) and have alot of trouble getting my jack under the car.
An owned guy is offline   Reply With Quote
Old 06-15-2012, 11:19 AM   #12665
thom52
Member#: 309257
2012 Imp 5D Prem CVT
Marine Blue
The real question should be, has anyone LIFTED their Impreza yet, getting a jump on the XV release, and making all those waiting future XV owners jealous?
thom52 is offline   Reply With Quote
Old 06-15-2012, 11:24 AM   #12666
SZRimaging
Member#: 314053
2012 Impreza
Marine Blue Pearl
Not yet, but I was curious about adding an inch or so for the winter. Pretty sure that would give you a handling and MPG penalty though.
SZRimaging is offline   Reply With Quote
Old 06-15-2012, 11:26 AM   #12667
nubsub
Member#: 313575
2012 Impreza 2.0i HB
funny (and not so funny) that i bottomed out the first time in my car (after 2.5 months and 2400 miles) yesterday coming out of a shopping center. really surprised me.
i can just get my jack under the car and hit the front jack plate...as i have noted elsewhere, this clearance isn't as bad as my wife's prius whose front bumper is extremely low...i'm guessing the Impreza has an extra 1.5+ inches of clearance than the Prius.
nubsub is offline   Reply With Quote
Old 06-15-2012, 01:03 PM   #12668
chanomatik
Member#: 159474
SNOSLO
There's a huge speed hump in my neighborhood that I can drive over with my WRX without scraping, but once when I had the Impreza I completely smacked the bottom, which REALLY surprised me! After that I just took the alternate route home (two ways to get in, only a couple hundred feet distance difference between them).
This car would look good lowered, according to the ricer in me, but probably not necessary unless you're putting skid plates under it to help with airflow and drag... Hmmm... That gives me and idea...
Old 06-15-2012, 01:28 PM   #12669
BigVoxjammer
Member#: 319171
2012 Impreza Spt Ltd
Sky-Blue/Gray
Raise it! I bet you don't take too much of an mpg hit, and the handling on a 148hp shouldn't be a factor. Roof racks and Bike carriers would drag more. Let the ricers and the WRX crew worry about that. Imprezas need to get those groceries home without resorting to skid plates! I'd like to see pics of owners who visualize their Sport Impreza as a mini-Outback, as opposed to those who see their Sport Imrpeza as a WRX-lite. Go mini outback, go!!
BigVoxjammer is offline   Reply With Quote
Old 06-15-2012, 01:38 PM   #12670
dorkbert
Member#: 309901
2012 Impreza 2.0i 5D
Dave Dave Dave... you're not even close. The volume of hollow roof rails cannot store sufficient Helium to generate enough lift to account for that .2". The truth is that Subaru is quietly fielding the experimental gravity drive in the new Impreza. The vehicle felt underpowered at times because the gravity drive is diverting power the engine. The extra .2" is there because the existing design has not yet reach functional requirement of supporting the entire vehicle weight.
dorkbert is offline   Reply With Quote
Old 06-15-2012, 02:09 PM   #12671
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
anyone have a picture of the kicker upgraded speakers? I'm curious if they are a coaxial or just a woofer
Old 06-15-2012, 02:34 PM   #12672
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
I've had the hood deflector on my car for a couple weeks now, but I really have not noticed any reduction in bug impacts on the hood and windshield. Maybe only 5,000 bugs a week get smacked instead of 5,500, but not enough to be useful it seems. I might take it off.
Haunty is offline   Reply With Quote
Old 06-15-2012, 02:42 PM   #12673
ISportLTD
Member#: 316677
Is it the OEM? Isn't that one affixed to the hood with screws or bolts?
How does it look? I have been thinking of getting one myself, but have been on the fence...
ISportLTD is offline   Reply With Quote
Old 06-15-2012, 03:17 PM   #12674
Haunty
Member#: 319378
Satin White Pearl
Yes the OEM. It looks OK, but IMO looks better without. It is affixed to the hood with clips, and screwed into the clips. Installation isn't too difficult.
Old 06-15-2012, 04:05 PM   #12675
jr0bb5
Member#: 315353
5MT OBP/DGM
I say ditch it and get a clear bra if you're worried about chips. The hood deflector is crazy ugly IMHO.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
