Old 07-01-2012, 01:34 PM   #12951
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Originally Posted by 2012ruimpreza
Yea I'm not worried I'm at 6k and I haven't used a drop, I think people on here are freaking out over a couple of lemons.
While I'm glad to hear that you and others here aren't having any consumption issues, I believe this is a bigger issue than just "a couple of lemons". Not to start anything, but it seems like the only ones saying not to worry about it are the ones who, luckily, haven't experienced any oil consumption problems. I know its not doing any good to get worked up about it, but this isn't something that should just be ignored.
jr0bb5 is online now   Reply With Quote
Old 07-01-2012, 02:26 PM   #12952
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
I'm at 2,300 miles on my car from new and I haven't had any oil consumption issues at all.
subiedude676 is offline   Reply With Quote
Old 07-01-2012, 02:47 PM   #12953
Zeeper
Member#: 299286
2015 WRX CVT
If the engine is broken in and not currently using oil it is pretty unlikely the rings are going to fail and the engine is going to start consuming oil, at least not during the next 150,000-200,000 miles.
Now I have seen some ringland failures in STI's, but in the new 2.0i engine? I doubt it is going to start happening.
If your engine is using oil, sorry, it is not that common. Half the people jumping on the worry train don't even know if their car is using oil. Do you want to know how to discern if yours is?
Do your own oil change, measure the oil you put back in the car, check the dipstick, and see if the level drops over time.
Zeeper is online now   Reply With Quote
Old 07-01-2012, 03:06 PM   #12954
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Default Antenna and car wash
I was looking through the owner's manual for my 2012 Impreza 5-door, and noticed it says that you should remove the antenna rod before driving the car through a car wash.
Do others do this? Golly, that's inconvenient. Makes me wonder why Subaru didn't use one of those shark-fin styled antennas instead.
sgoldste01 is online now   Reply With Quote
Old 07-01-2012, 03:42 PM   #12955
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Cost...
I leave mine on; however, I also go to a touch-less wash facility.
G-Omaha is offline   Reply With Quote
Old 07-01-2012, 07:20 PM   #12956
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
Shark fin antenna, hmm...
Xarthan is offline   Reply With Quote
Old 07-01-2012, 07:43 PM   #12957
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
I saw that too, but I think it's just nonsense to protect themselves from complaints in case the antenna is actually broken by a car wash.
Haunty is offline   Reply With Quote
Old 07-01-2012, 08:31 PM   #12958
thom52
Member#: 309257
2012 Imp 5D Prem CVT
Marine Blue
Cool visual garage shark fin antenna
Elsewhere on this forum, the Visual Garage Shark Fin antenna seems to receive praise.
A bit spendy at $69, but its color matched to your car.
Catch is, I noticed on the site, that they only go up to 2009 Impreza for what they list as available. Not sure if its different for 2012.
http://visualgarage.com/
I am debating something like that. The stock antenna is pretty darn ugly.
thom52 is offline   Reply With Quote
Old 07-01-2012, 11:19 PM   #12959
jr0bb5
Member#: 315353
5MT OBP/DGM
Originally Posted by G-Omaha
Cost...
Same here
Old 07-02-2012, 12:10 AM   #12960
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
The concern in the owner's manual isn't that the antenna will break. It's that the antenna might be bent and scratch the car's paint.
Old 07-02-2012, 03:06 AM   #12961
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
I could be wrong, dosen't the Legacy have a shark fin antenna? Could get a color matching one if so.
Oh wow that's pretty easy (the VG shark) but not sure if it's worth 70 bucks. lol
Old 07-02-2012, 09:42 AM   #12962
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Originally Posted by G-Omaha View Post
Cost...
My car wash facility is "touchless" too, but it still has these big moppy strips that hang down, and the car gets pushed through them. They don't spin, and they don't move side to side, but the antenna would get pressed against them.
Old 07-02-2012, 10:15 AM   #12963
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
Has anyone else noticed their Impreza CVT sounds a bit like a vacuum cleaner when reversing past them ?
Have read in a few areas where the CVT is naturally noisier than normal autos when under load ( it is ) but has anyone listed to one to one reversing past them that the CVT sounds moderately like vacuum cleaner from the outside, just wondering if it's normal ?
John451 is offline   Reply With Quote
Old 07-02-2012, 10:20 AM   #12964
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
I have the same type of touch less wash with the big, mop-like strips at Delta Sonic. I've gone through several time without removing my antenna & it's fine. I don't mind the look of the little antenna but wish it had a hinge so it could be bent downward like the 08-11 models have.
SleepNMnky is offline   Reply With Quote
Old 07-02-2012, 04:03 PM   #12965
jr0bb5
Member#: 315353
5MT OBP/DGM
The touchless car wash near me uses only high pressure water to clean the car so its truely touchless. It also uses filtered water for the rinse and forced air to dry so you get minimal water spots. It works surprisingly well.
Old 07-02-2012, 04:16 PM   #12966
Furiousd1983
Member#: 295099
2013 Not so Hot HB
Took the car back in to do the 2nd 1200 mile mark of the consumption test. The car went thru 1qt of oil in 2367 miles. Also while I was there I showed them the squeaky driver seat. Instead of waiting 3-4 months for a new seat back. They are going to give me a loaner when I go in for the final mark of the consumption test. They are going to open the seat up and fix the squeak with the DIY fix.
Furiousd1983 is online now   Reply With Quote
Old 07-02-2012, 04:29 PM   #12967
jr0bb5
Member#: 315353
5MT OBP/DGM
Did the techs make any comments about your oil consumption? When I brought my car to the dealer because of oil consumption, they told me there was no test that they could perform to measure oil consumption. Guess they just really wanted me out of their hair.
Old 07-02-2012, 04:34 PM   #12968
Furiousd1983
Member#: 295099
2013 Not so Hot HB
I'm 2400 miles into a consumption test. SOA ordered it. The dealers hands are tied as the car only burn about 1/2qt of oil per 1200. That's about 1/2 what it needs to be for SOA to do anything about. As much as it blows. I'm going to have to carry extra oil with me or change it every 3000 miles to keep the low oil light off. (which aint happening!) In all honesty I'm not really sure what is my next move.
Old 07-02-2012, 05:20 PM   #12969
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
i would start running a higher weight oil and see what that does for your consumption. I know people say it voids your warrenty but if it fixes the problem and they wont find out i dont see what the deal is.
auskip07 is offline   Reply With Quote
Old 07-02-2012, 05:35 PM   #12970
nubsub
Member#: 313575
2012 Impreza 2.0i HB
assuming SOA is not going to do anything to help you saying 1 qt for 2400mi is ok, i agree with this suggestion. first try would be to just go for a heavier viscosity when cold, oil like 5w20 or 10w20. hopefully that will cure your problem. if not, step it up to a 5w30.
nubsub is offline   Reply With Quote
Old 07-02-2012, 06:01 PM   #12971
jr0bb5
Member#: 315353
5MT OBP/DGM
I know how you feel. Personally, I may end up getting a different car. I like the Impreza and all, but I don't like it enough to keep it if its going to continue to consume oil at the rate it is. I will contact SOA eventually and see what they have to say, but if they tell me I just have to live with it, then I'll be shopping at one of their competitors.
Old 07-02-2012, 06:04 PM   #12972
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
You would rather get a whole new car than to try out a higher weight oil?
Old 07-02-2012, 06:28 PM   #12973
Furiousd1983
Member#: 295099
2013 Not so Hot HB
Well, I was gonna type out a message about waiting to see what SOA had to say and Chris @ SOA called me.
As I fully expected "something something within tolerances. Something something keep an eye on the dipstick.". Frustrating. Ill talk to the dealer about running a 5w in the next cycle if that won't dick with my warranty. I'm not going to take a hit by dumping the car just because of this. I'll just be unhappy until something comes along in the future.
Old 07-02-2012, 06:30 PM   #12974
TObject
Member#: 320185
2012 Impreza 2.0i
There is also RedLine 0W20 motor oil, which is officially 0W20, but is more like light 30-weight oil.
TObject is offline   Reply With Quote
Old 07-02-2012, 06:39 PM   #12975
Furiousd1983
Member#: 295099
2013 Not so Hot HB
For the time being. I'm not doing anything outside of subaru's normal recommendations. That way there's nothing they can say when/if a warranty claim pops up.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
