Old 08-07-2012, 08:42 AM   #13451
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by SleepNMnky
Good call. Someone already ordered an XV front strut bar. This will open up a lot of parts for us.
That's what I'm thinking. I don't want to raise the car up any (looks cool, kinda wish i had bought one, but if i wanted a taller subaru i would have bought a forester)
Maybe the radios well get cheaper too
Old 08-07-2012, 09:09 AM   #13452
WLS
Member#: 316030
Originally Posted by ans2k View Post
hey, will 215/50/17 fit ok on our car? it is 0.4 inches taller than 205/50/17. reason being is that the DWS is 13$ cheaper per tire. is it worth it?
It's going to be wider too and throw off your speedometer by a mile per hour. If your speedometer is a mile too fast as mine is that might be a good thing.
This URL gives some info but can't say if the width will fit but myself I wouldn't go wider
http://www.miata.net/garage/tirecalc.html
I was thinking that 195/55/17 might be a good choice and give more pothole protection but I don't know if you can get them as it is a bit of an oddball size
WLS is offline   Reply With Quote
Old 08-07-2012, 10:14 AM   #13453
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
If you live in an area that is prone to snow and/or slush, probably not a good idea, even though they will fit. There really is not much clearance between the tire and the wheel well on the Imprezas and the slush/snow "gathers" in the wheel well.
G-Omaha is offline   Reply With Quote
Old 08-07-2012, 10:19 AM   #13454
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Dupe posting deleted
Old 08-07-2012, 10:44 AM   #13455
06SE
Member#: 158925
12' Sport LTD
MBP
I'm not sure if it is cheaper but try out 225/45/17 DWS and see if they are as cheap as the 215's. I run the 225 DWS's on my car and they are great. They also don't throw your speedo off as much as the 215 setup would.
06SE is offline   Reply With Quote
Old 08-07-2012, 10:58 AM   #13456
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
06SE, can you post picks of your setup as I am thinking about going the same size on our stock 17x7 or some aftermarket 17x7.5 rims. If you can post a sidewall shot...
Stan
uspopo is offline   Reply With Quote
Old 08-07-2012, 11:03 AM   #13457
ans2k
Member#: 315631
2012 Impreza Sport
can you post pics of your tire on the rim? is there a large bulge?
ans2k is offline   Reply With Quote
Old 08-07-2012, 01:38 PM   #13458
06SE
Member#: 158925
12' Sport LTD
MBP
The 225/45-17 tire fits just fine (no bulges) on my 17x7 BBS Rk's. I actually ran this setup on my previous Legacy and had zero issues.
Onto pictures:
Front wheel/tire -
http://farm9.staticflickr.com/8431/7...27db87f3_b.jpg
Rear wheel/tire -
http://farm8.staticflickr.com/7259/7...3a0f54aa_b.jpg
Full side shot -
http://farm9.staticflickr.com/8293/7...de9ab700_c.jpg
HID retrofit (for fun) shot -
http://farm9.staticflickr.com/8291/7...f96bef55_b.jpg
Old 08-07-2012, 01:50 PM   #13459
uspopo
Member#: 317014
ISM
That looks great! A 1.25 cm (x 2 for the diameter) difference in height but more tread width compared to the oem tire and rim setup. I think I may go that size on some Enkei 17 x 7.5" RPF1s.
Stan
Old 08-07-2012, 02:10 PM   #13460
imcausinmadrukis
Member#: 318978
What is the Max Wattage and Voltage on the outlets of the 2012 Impreza?
I bought one of these the other day and plugged in an air mattress pump and it blew out my fuse.
http://www.pepboys.com/product/details/9319350/
imcausinmadrukis is offline   Reply With Quote
Old 08-07-2012, 02:21 PM   #13461
06SE
Member#: 158925
12' Sport LTD
MBP
Stan
Happy to help and great choice on your wheel selection!
Old 08-07-2012, 02:47 PM   #13462
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
I do recall seeing it in the manual, but I don't have it handy. Regardless of the power rating of the pump, it appears the initial power surge drawn by the pump exceeds the car's capabilities. Motors often have an initial power surge of 2X-3X their rating to get going.
I've used a DC-powered air mattress pump with no problems, with a standard cigarette-lighter car plug. They're pretty cheap, and probably the way to go.
tomwi53092 is offline   Reply With Quote
Old 08-07-2012, 09:36 PM   #13463
Steve Gray
Member#: 302593
2012 PremiumHatchCVT
Gray
I was just wondering, what's the fastest anyone has gone in their 2012 2.0? I've hit 102mph (according to my Garmin GPS) at a location and date that must remain undisclosed. I'm never going to do that again. I don't trust the stock Yoko's that much.
Steve Gray is offline   Reply With Quote
Old 08-07-2012, 09:46 PM   #13464
MattD87
Member#: 126930
2015 Legacy
CGM
If I wanted to drive like an idiot, I would've bought an STi.
MattD87 is offline   Reply With Quote
Old 08-07-2012, 09:50 PM   #13465
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I know of one report on this forum of someone hitting 130 mph, which I wouldn't have guessed was possible unless going downhill. With a tail wind. And a BMW in front towing a very powerful magnet.
sgoldste01 is offline   Reply With Quote
Old 08-07-2012, 11:53 PM   #13466
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Did some testing today on odometer error, looks like mine is either under 3%, but greater than 2.5% or it varies with speed. Most of my driving today was under 60, but longest one way trip with my car, 98.5 miles. Everything i have tested at higher speeds was 3.25%-3.8% off at 75-80. I have a trip in a few weeks that i will be able to test it again and see if i get under 3% at higher speeds or not.
Old 08-08-2012, 03:08 AM   #13467
adanacsman
Member#: 305592
2012 Impreza CVT
5-Door SWP
I was driving today in the rain and got cut off by someone and had to slam on the brakes. I know what ABS feels like and sounds like, and mine activated for sure, but I also heard two very loud thuds from the front of the car. I'm wondering if anyone has experienced this/knows what it is? I know this is not part of the ABS system but it could possibly be part of EBD as I've never had a car with it before.
adanacsman is offline   Reply With Quote
Old 08-08-2012, 07:47 AM   #13468
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Thuds are normal when the car hits ABS, if you can tell it is coming from the brake system
auskip07 is offline   Reply With Quote
Old 08-08-2012, 10:11 AM   #13469
ocellaris
Member#: 302559
I wouldn't worry about it. One of my friends has a Corolla and in that car is sounds exactly like you just ran over a metal trash can when the ABS activates.
ABS systems are not designed for driving comfort.
ocellaris is offline   Reply With Quote
Old 08-08-2012, 12:07 PM   #13470
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I tried to get my abs to activate yesterday, but no joy.
Old 08-08-2012, 12:33 PM   #13471
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Do a few sets of leg lifts and crunches. That should do the trick.
Old 08-08-2012, 01:40 PM   #13472
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
Now, now... no need to stereotype. I am perfectly capable of driving like an idiot in either of my cars, thank-you-very-much.
saabarupp is offline   Reply With Quote
Old 08-08-2012, 02:55 PM   #13473
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
That's... pretty funny. haha
I find the statement "fastest 2012 Impreza" to be highly ironic, by the way. hahaha
Are we calling these "4G Imprezas" yet?
Old 08-08-2012, 04:09 PM   #13474
SZRimaging
Member#: 314053
2012 Impreza
Marine Blue Pearl
Between all the cars I have activated ABS in, I can't think of two that sounded the same. I have had small, soft "pulses" all the way to grinding noises.
SZRimaging is offline   Reply With Quote
Old 08-08-2012, 04:33 PM   #13475
ans2k
Member#: 315631
2012 Impreza Sport
this reminds me of the "medium" speed police chase with a smart car. some idiot was running from the police in a smart car. the top speed is like 85ish mph. some people drive like that cruising. anyways, i find it retarded when people take economy cars and drive weckless and speed like crazy pretending they are race cars. should have bought a wrx.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
