Old 08-15-2012, 09:35 PM   #13526
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by auskip07 View Post
You shouldnt be able to press the brakes if your not in the car when it starts. It reads a open door as a voltage drain the same as it reads the brake lights as one. It cant tell the difference.
The point is to have a vehicle up to a comfortable temp when you get inside. Turning off is a safety feature.
You're not understanding....It makes more sense to have it shut off when the brake is applied instead of when a door opens. This way, you won't be in the car when you remote start it, but when you DO enter the car, all you have to do is turn the key to the on position and drive away! And, if someone enters your car to try to steal it, the steering column is still locked because the ignition switch is off, and once they hit the brakes to shift from park, the engine shuts down! How does that not seem more logical and convenient???
If "it can't tell the difference" then it's because THEY designed it that way. Almost every other OEM and aftermarket remote starters operate in the way I described above.
This is straight from the installation instructions for the remote start, at the end during the functional test:
4. BRAKE PEDAL SAFETY - While sitting in the vehicle with all doors and hatch/trunk closed, restart the vehicle
using the remote engine starter, press the brake pedal - The vehicle should shut off.
jsteg is offline   Reply With Quote
Old 08-15-2012, 09:41 PM   #13527
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Technically speaking you can shift out of park without stepping on the brake, just use the shift lock override.
I think the bottom line is that if you don't want the car to stop running when opening the doors, buy an aftermarket remote start. For me, it's almost a moot point, as you are going to have to stick your keys in the ignition ANYWAY, so I don't see a big deal with turning it one extra click to start it.
ST Eye is offline   Reply With Quote
Old 08-15-2012, 09:49 PM   #13528
jsteg
Member#: 329271
Ice Silver Metallic
It's not the one extra click that bothers me. What bothers me is the principal of the matter it defeats the purpose of using remote start. The other thing that bothers me is you're putting extra wear and tear on your starter AND your engine!!! That's what bothers me!
Old 08-15-2012, 09:59 PM   #13529
ocellaris
Member#: 302559
The purpose of remote start is to warm up the car before you want to drive it. If the car stayed running when the door was opened, this would be a safety/theft hazard.
And I wouldn't worry about extra wear on the starter. How often do people complain about starters dying? Really...
ocellaris is offline   Reply With Quote
Old 08-15-2012, 10:02 PM   #13530
Snowdog
Member#: 309541
I have the same gripe with the remote start. I understand your point ST Eye but it would be nice to be able to unlock the car after a remote start and open the door to get an ice scraper out to clean it off instead of having to restart it with the key. My thought is that if the other manufacturers and aftermarket remote start companies make their cars work with the brake lights being the trigger to shut the car down why is Subaru different? Can it be changed? I'll see if I can get an answer tomorrow.
Snowdog is offline   Reply With Quote
Old 08-15-2012, 10:04 PM   #13531
ST Eye
Member#: 73068
Ok got it, it bothers you. So then I would suggest getting an aftermarket one like I just mentioned. Do you have it installed already?
Old 08-15-2012, 10:20 PM   #13532
jsteg
Member#: 329271
Ice Silver Metallic
How is it a safety/theft hazard?? If they use the same technique as every other remote start out there, it is impossible to steal it with it running by remote start! How many times do I need to say that before you get it???
Ok I'll ignore the wear on the starter...how about the engine?!?!
Old 08-15-2012, 10:33 PM   #13533
ocellaris
Member#: 302559
Many other automakers do this too. Like Ford, Mazda, Toyota, and VW.
Starting a warm engine causes about as much wear as just driving down the road normally.
Old 08-15-2012, 10:33 PM   #13534
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Engine wear is negligible. how about the extra .002 ounces of gas it uses?
auskip07 is offline   Reply With Quote
Old 08-16-2012, 03:01 AM   #13535
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
@jsteg - trust me - we all get your point & we all had the same convo 8 months ago when we got our cars. We've all since then gotten used to it... & gotten over it. But like STEye said, if it frustrates you that much, get an aftermarket starter. The OEM starter does function the way IT IS SUPPOSED TO. The range & strength this signal has on the OEM unit far outweighs the annoyance & in about 2 weeks time you'll get used to it. Really.
SleepNMnky is offline   Reply With Quote
Old 08-16-2012, 04:12 AM   #13536
jsteg
Member#: 329271
Ice Silver Metallic
You can take Ford off the list, I know that first hand.
I wouldn't consider the engine to be warmed up in the amount of time it takes to walk 400 feet.
Old 08-16-2012, 04:15 AM   #13537
jsteg
Member#: 329271
Ice Silver Metallic
Yeah I get that but remember, I wasn't just ranting on here. I came with a question that thus far, nobody has given a direct answer for. All anybody has done is wanted to argue about why or why not the system is flawed.
I will take everyone's argument as an answer of "no" to my question.
Old 08-16-2012, 08:58 AM   #13538
Angelus911
Member#: 89967
2012 Impreza Sport
I can see how you're annoyed and I was slightly too when I first found out about it. But in the end, I got it so I can warm up my car in the winter without having to go outside. That's the most important thing to me, and it does/will do that well.
I, for one, am extremely happy with my car thus far. I just got back from a road trip in a family member's 2009 Forester and I can say without a doubt my car is so much more comfortable than hers, and is leaps and bounds better than my old '00 Impreza I was driving earlier this year.
Angelus911 is online now   Reply With Quote
Old 08-16-2012, 10:04 AM   #13539
RXman
Member#: 317181
2012 Impreza Premium
Satin White Pearl
Default Two TSB's finally done
I have to thank all of you who reported those two TSB's for CVT and driveability. If I hadn't copied them from this forum, my dealer would have still been looking at me crazy! I went for an oil change yesterday and told him I'd would like those two bulletins done on my Impreza. At first he said he wasn't aware of any, then he said OH they were probably not needed and probably already have been done - WRONG - the car had a build date of November and nothing was done. I whipped out a copy of the TSB's from the forum and FINALLY had them performed. The engine breaking issue seems to be corrected, as for drivability, I really had no issues previously so I'll have to see with continued driving ,if I notice a difference.
Thank You all again!
RXman is offline   Reply With Quote
Old 08-16-2012, 10:18 AM   #13540
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Awesome to hear.
uspopo is offline   Reply With Quote
Old 08-16-2012, 10:21 AM   #13541
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
That's the power of forums for ya!
EDIT: Hey, I just got promoted to "Scooby Specialist"! I'm so proud!
I wonder what the next promotion is? Senior Scooby Specialist Extraordinaire?
sgoldste01 is offline   Reply With Quote
Old 08-16-2012, 10:30 AM   #13542
uspopo
Member#: 317014
ISM
Congrats to you brother!
Old 08-16-2012, 10:41 AM   #13543
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
With perseverance and hard work, Grasshopper, you too can become a Scooby Specialist!
Old 08-16-2012, 10:47 AM   #13544
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
600 posts or so to get there. It's time for me to go the off-topic forums and post my chocolate chip cookie recipe a few hundred times.
tomwi53092 is offline   Reply With Quote
Old 08-16-2012, 11:08 AM   #13545
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
is the first oil change free? Or is that dealer specific?
Old 08-16-2012, 11:19 AM   #13546
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
It must be dealer specific. My dealership didn't offer any free oil changes, but I know others here have that benefit. My dealership said they would change my wiper blades within the first 2 years, though.
Whatever. I wanted to put Amsoil in the car anyway, and I used the opportunity to teach my son how to do an oil change. So it's all good, except for the $$ I spent for supplies.
Old 08-16-2012, 11:32 AM   #13547
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i hear you, i just ordered some Amsoil Signature for my second change after my 800 mile trip coming in just over a week. It will be replacing the XL i have in there now. will also be putting on the fumoto valve because I made a mess last time and don't expect much better results this time.
I was just curious, my dealer set up my first appt, but i skipped it because i didn't even have 1500 miles on the car.
Old 08-16-2012, 11:43 AM   #13548
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yeah. Hot 0W20 oil comes out FAST!
A tube connected to the Fumoto's nipple will provide much better control.
Old 08-16-2012, 12:04 PM   #13549
uspopo
Member#: 317014
ISM
Thoughts on the Fumoto valve? No chance of the valve opening with vibrations from the engine? Which application model is for our motor? F-108 or F-105?
Old 08-16-2012, 12:11 PM   #13550
CLL_OBP
Member#: 310435
2012 Sport Limited
PUP 5W20 93,516 miles
It sure does! That's one thing I don't like about 0W-20 oil, it so thin it comes out like water.
CLL_OBP is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
