Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 08-29-2012, 08:23 PM   #13726
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
Originally Posted by jsteg View Post
You can't LITERALLY stack them! You have to put each one in separately but it will show both at final checkout.
I did this the other night and it doesn't work. The stack does show at checkout but they simply send an email later that says "you can't stack discounts and we removed the smallest discount. Do you still want to purchase?"
hemophilic is online now   Reply With Quote
Old 08-29-2012, 09:04 PM   #13727
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
That's too bad, it's worked for me (twice -- this order, and another order in late May/early June) and several others also had it work back in May/June, although someone back then had it rejected too.
One thing to note -- when you get your shipping confirmation email, it'll only show one discount, but if you enter your order number on their site it will show both, and they charge you the correct amount (with both discounts applied).
gfxguy is offline   Reply With Quote
Old 08-29-2012, 09:43 PM   #13728
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Worked for me too. Pretty sure we're the group that prompted them to fix the issue. HA! Lucky us!
SleepNMnky is offline   Reply With Quote
Old 08-29-2012, 09:48 PM   #13729
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
That stinks you can't stack the coupons anymore. I was able to get my spoiler for my sedan for $85.00 off MSRP.
On a side note, has anyone noticed that the spoiler and body side molding have a different metallic flake than the car paint? My car is Ice Silver Metallic. Spoiler was made in Canada.
ST Eye is offline   Reply With Quote
Old 08-29-2012, 10:06 PM   #13730
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
If they fixed it, they fixed it after I ordered on Friday, 'cause it worked for me this time too.
Old 08-30-2012, 12:20 AM   #13731
xltiny
Member#: 319645
2013 Impreza 2.0 Ltd
I was able to stack, I checked out using Paypal and was billed the "stacked" amount. I got shipping confirmation the next day showing only 1 coupon but no additional charges to my paypal.
xltiny is offline   Reply With Quote
Old 08-30-2012, 12:52 AM   #13732
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by xltiny View Post
Stupid question but what Torque settings did you use for your front strut bar? I ordered the same bar and set it at 13.5lbs/ft for the tower points (6bolts/nuts) and 35lbs for the actual bar itself(2bolts/nuts).
Thanks
I had torqued it to similar values as well, I had noticed that if you overtorque the actual bar itself (2bolts/nuts) the bar will be compressed and squished and metal shavings will come off from driving the car with the bar overtightened.
Originally Posted by Zeeper View Post
Keep in mind that the XV is a lifted Impreza, so all of the aftermarket braces, short shifters, etc should also fit.
And aftermarket performance parts! One can only dream.
Originally Posted by sgoldste01 View Post
Here's the set I have, which also works well:
http://www.harborfreight.com/5-piece...set-67021.html
I had ordered a set like that too, it's useful around the house too.
pkL is online now   Reply With Quote
Old 08-30-2012, 02:33 AM   #13733
GTturbo
Member#: 330647
How did you stack it? If I enter a code then delete it, then enter the other code it will only show the last code I entered at check out.
GTturbo is offline   Reply With Quote
Old 08-30-2012, 04:21 AM   #13734
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Duh??? Why would you expect any different? If you delete something obviously it's not going to reappear magically. It was already explained how to stack them it's not science. Type in a code and hit apply and then type in the second code and hit apply.
jsteg is offline   Reply With Quote
Old 08-30-2012, 08:40 AM   #13735
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
"Thank you for your order. Unfortunately only one discount code may be used per order. We have removed the lesser of the two. Please let us know if you would like to proceed with the correct order total of $94.48 or cancel order. Thank you. "
Old 08-30-2012, 09:22 AM   #13736
Ropes4u
Member#: 323526
Originally Posted by uspopo
Hhhhmmm, light bars and skid plate packages too!
I would love a Light bar and rally lights...
Ropes4u is offline   Reply With Quote
Old 08-30-2012, 09:42 AM   #13737
ocellaris
Member#: 302559
They have had that same problem in the past as well. They really need to fix their site to only allow ONE promo code order.
ocellaris is offline   Reply With Quote
Old 08-30-2012, 09:44 AM   #13738
myrt1987
Member#: 323103
2012 Limited 2.0i
Well i canceled the order, because A) this PITA and B) their prices arent that good to begin with.
Old 08-30-2012, 09:58 AM   #13739
GTturbo
Member#: 330647
Okay then they must have changed their site. As soon as you enter a code there is no option to enter another one.
Old 08-30-2012, 01:09 PM   #13740
dubiousmike
Member#: 327473
2012 Impreza Sport L
http://www.ebay.ca/itm/ws/eBayISAPI....m=130682937001
I feel dumb asking, but can someone help me to determine which way this spoiler faces when installed? Is what is orientated toward the back of the car? The curved side or the notched side?
dubiousmike is offline   Reply With Quote
Old 08-30-2012, 01:58 PM   #13741
myrt1987
Member#: 323103
2012 Limited 2.0i
I would assume the flush side goes against the car and the extended points are pointing away from the car.
Old 08-30-2012, 02:11 PM   #13742
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
If it's similar to the '12 imp spoiler (very likely), that would be wrong. Here's a pic of the underside of that spoiler, the top side in the pic is the side that attaches to the car.
Old 08-30-2012, 02:15 PM   #13743
myrt1987
Member#: 323103
2012 Limited 2.0i
haha i probably am wrong. I guess we all know what happens when you assume...
Old 08-30-2012, 03:14 PM   #13744
dubiousmike
Member#: 327473
If you're right, I want it. If GFXGUY is right, I'm not.
Old 08-30-2012, 07:22 PM   #13745
imcausinmadrukis
Member#: 318978
Anyone have any experience with this product?
Does it scratch your paint?
Any recommendations on a towel that works well?
imcausinmadrukis is offline   Reply With Quote
Old 08-30-2012, 07:27 PM   #13746
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Meguiar's Water Magnet Drying Towel - YouTube
I use this one:
The Absorber Synthetic Drying Chamois,27" x 17" : Amazon.com : AutomotiveThe Absorber Synthetic Drying Chamois,27" x 17" : Amazon.com : Automotive
Works great. Won't scratch anything as long as you don't let it pick up any grit.
Old 08-30-2012, 10:05 PM   #13747
ST Eye
Member#: 73068
I used to use that over 10 years ago. It is good at first, then after you use it for a little while it picks up dirt - even if you wash it. Then it puts fine scratches on your paint. FTL.
Old 08-30-2012, 10:58 PM   #13748
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Hmm, that sucks. Mine's only a few months old but I'll be careful with it. What do you use now?
On another note, my check engine light came back on today -- code P000A (slow cam position response) again. Dealership replaced the cam position sensor last time it came on (@ 1100 miles), now I'm a bit over 3000. Frustrating.
Last edited by gfxguy; 08-31-2012 at 11:46 AM. Reason: CPS was replaced at ~1100 miles, not 700.
Old 08-30-2012, 11:25 PM   #13749
ST Eye
Member#: 73068
On another note, my check engine light came back on today -- code P000A (slow cam position response) again. Dealership replaced the cam position sensor last time it came on (@ 700 miles), now I'm a bit over 3000. Frustrating.
I used to use an electric leaf blower which is the best since it doesn't make contact with the car. However I have become lazier over the past couple of years and I just use a terry cloth to gently dry the car.
Old 08-31-2012, 12:20 AM   #13750
pkL
Member#: 313093
2012 Impreza 2.0i
I use this one:
I have something similar to this, is this one more foam/neoprene like? Or is it more like a chamois cloth?
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
