Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 08-31-2012, 12:38 AM   #13751
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Originally Posted by pkL
I have something similar to this, is this one more foam/neoprene like? Or is it more like a chamois cloth?
Yeah it kinda feels like neoprene, but soaks up water like a chamois (but better).
gfxguy is offline   Reply With Quote
Old 08-31-2012, 01:55 PM   #13752
imcausinmadrukis
Member#: 318978
Just picked one up. I might end up buying the Meguiar's Water Magnet Drying Towel as well just to see the difference.
imcausinmadrukis is offline   Reply With Quote
Old 08-31-2012, 07:59 PM   #13753
Algreen
Member#: 268369
2012 Impreza Premium
Ice Silver
Has anyone installed the 2012 impreza hood deflector? I'm wondering if it's turned up at the top edge, like a bug deflector, or just a plastic cover for the front of the hood.
Algreen is offline   Reply With Quote
Old 08-31-2012, 10:13 PM   #13754
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Yizzir. Not turned up, just like an elevated cover.
Old 09-01-2012, 07:26 AM   #13755
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
Originally Posted by ST Eye View Post
I used to use that over 10 years ago. It is good at first, then after you use it for a little while it picks up dirt - even if you wash it. Then it puts fine scratches on your paint. FTL.
They want you to buy a new one every 6 months. How can they keep making money if it lasts forever?? C'mon, suck it up and stimulate their economy.
hemophilic is offline   Reply With Quote
Old 09-01-2012, 02:16 PM   #13756
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
You're doing it wrong. You're supposed to use a new one every time you wash your car.
pkL is online now   Reply With Quote
Old 09-02-2012, 09:12 PM   #13757
yet112
Member#: 330989
Sorry to be completely off the topic, but this is my first post (long-time lurker).
I've had my 2012 Sport Limited for about 6 months and just noticed that the steering wheel plastic surrounding the key ignition is very off-centered. Do other people's look like this?
Thanks and hopefully this doesn't get buried in the massive thread.
yet112 is offline   Reply With Quote
Old 09-02-2012, 09:13 PM   #13758
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Yes this is a known issue. If it bothers you, go to the dealer and tell them to fix it. There is a TSB (Technical Service Bulletin) on this exact problem, along with a fix.
ST Eye is offline   Reply With Quote
Old 09-02-2012, 09:14 PM   #13759
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Yeah mine is the same way...not a big deal to me.
jsteg is offline   Reply With Quote
Old 09-02-2012, 09:17 PM   #13760
yet112
Member#: 330989
Edit:Thanks for the quick response. And I found the TSB at subaru's site. 12-129-12R.
It obviously doesn't really bother me (took 6months to notice is), but it's good to know the dealer can straighten it up. Do I need to reference any TSB, or should they just fix it? (Small town middle of no where, so the sales volume is probably me and one other guy).
Old 09-02-2012, 10:45 PM   #13761
pkL
Member#: 313093
2012 Impreza 2.0i
After you had mentioned it, I do notice mine to be off centered too, I guess I'll leave mine as is. Don't want to spend half a day at my dealership waiting for them to fix this.
Old 09-03-2012, 03:16 AM   #13762
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Originally Posted by don1968 View Post
Why is it that the Crosstek has a 1500 lb tow rating and the Impreza has 0 tow rating when they are the same chassis?
its actually its a beefed up chassis.
Blackmamba24kb is offline   Reply With Quote
Old 09-03-2012, 03:38 AM   #13763
Blackmamba24kb
Member#: 330797
Satin White Pearl
Default Fog Light Installation Question
I am looking to purchase the OEM fog lights to install in my 2012 impreza wagon which didnt come with the fog lights.
My question is, I am not buying the kit from the dealer or site which costs $200+, instead ive buying oem assymbly from some guy. But my question is, how will I turn them on? Do i need to buy some switch that will attached to my door arm rest bevel or somewhere under my vents where the traction control button is??
or should I just buy a new turn signal arm that has the fog light switch and replace that, but would the fog light turn on through that new arm if i buy it?
anyone know?? help!!
Old 09-03-2012, 09:28 AM   #13764
jsteg
Member#: 329271
Ice Silver Metallic
It depends on if you want it to look factory or not. Obviously if you do then you'll want the new stalk. I will say this though, the fog lights are mostly for looks. When I'm driving down a dark road and turn them on and off I can barely tell.
Old 09-03-2012, 09:36 AM   #13765
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
I have the fog lights that were added later. They ran a switch to them on the small panel where the traction control button is. They're only on the signal arm on the Limiteds & others that came factory installed.
I have to disagree with this. I find they help tremendously. They light the area between the road & the normal headlight beams. Also fill in the sides nicely. They definitely help to light the road directly in front of you during rain & snow which helps. Do they help during actual fog... not really. None of them do. But they light the road more & flood the ground so there's no gaps. I have yellow overlays on mine & love the extra light they put out.
SleepNMnky is offline   Reply With Quote
Old 09-03-2012, 09:43 AM   #13766
Zeeper
Member#: 299286
2015 WRX CVT
Not true, they are on the signal arm for my 5 speed sport, which is not a limited. Maybe if you get them installed at the port they put the switch on the dash, but for trims that include Fog Lights the switch is on the stalk.
I also think the light output sucks. I have PIAA 55watt lights on my motorcycle that are 10 times brighter and a lot more useful.
Zeeper is online now   Reply With Quote
Old 09-03-2012, 10:46 AM   #13767
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Best use is for seeing potholes and ice patches. These are fog lights and not driving lights. They are not supposed to have a long range.
G-Omaha is offline   Reply With Quote
Old 09-03-2012, 11:17 AM   #13768
jsteg
Member#: 329271
Ice Silver Metallic
Originally Posted by Blackmamba24kb View Post
8.7" of ground clearance is pretty impressive considering a stock jeep wrangler has 9.0"
Old 09-03-2012, 11:21 AM   #13769
ST Eye
Member#: 73068
If you have foglights from the factory they are on the stalk (as the others have said), else they are a switch on the side. The light output and beam pattern are comparable to every car I have owned with a factory foglight option. People are expecting a radiant beam of light which factory fogs don't give. The are NOT supposed to cover the same area as the headlights.
Old 09-03-2012, 11:26 AM   #13770
JackZ
Member#: 330076
2012 Impreza Sport
Ice Silver
In regards to the whole off center thing, would this affect the key at all in terms of difficult to put in? I have noticed my key is a bit hard to get in at times.
JackZ is offline   Reply With Quote
Old 09-03-2012, 11:28 AM   #13771
jsteg
Member#: 329271
Ice Silver Metallic
I understand that, but I can barely tell a difference switching them on and off down a dark road, even directly in front of the car. Yes, you can see it, but its so unnoticeable, I can't help but think the lights are more for looks.
Old 09-03-2012, 11:31 AM   #13772
myrt1987
Member#: 323103
2012 Limited 2.0i
This is my first car with fog lights. I just assumed they were for looks because they dont help that much. If im that close to a pothole or something, im running over it. I keep mine off actually, not sure why. lol
Old 09-03-2012, 11:32 AM   #13773
jsteg
Member#: 329271
Ice Silver Metallic
^ Exactly what I'm talking about! I do keep mine on though. I paid for em, by god I'm using em!
Old 09-03-2012, 11:37 AM   #13774
myrt1987
Member#: 323103
2012 Limited 2.0i
True, Im gonna turn mine on
Old 09-03-2012, 01:02 PM   #13775
Blackmamba24kb
Member#: 330797
Satin White Pearl
hi guys thanks for the great responses on the fog light question. hmm i think ill need to buy a switch to then.
i looked into buying the stalk which isnt too expensive (approx 70 usd) but the issue is having to take apart the steering wheel setup (remove air bag etc to get to the stalk). I would love to do it with the stalk but sounds like more trouble than I want to deal with.
I guess ill just install a switch even though its not something I really want to do since its not like factory.
anyone ever take off steering wheel airbag? is it as bad as it seems on the factory service manual?
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
