Old 09-06-2012, 10:01 AM   #13826
ans2k
Member#: 315631
2012 Impreza Sport
Originally Posted by uspopo View Post
I believe Rally Innovations and Gorilla are working on one for our cars. Get-Primitive already has skid plates out.
yea, i have already emailed them. thats is why i said yet. and im looking for a light bar/skid plate combo.
Originally Posted by sgoldste01 View Post
I like my tires slightly harder than spec, so I'm inflated to 34 at all four corners. Does anyone see a problem with that? Or is is really necessary to inflate 2 lbs harder in front than in the rear?
didnt think so, since some people's imp came with 36-38psi.
ans2k is offline   Reply With Quote
Old 09-06-2012, 10:11 AM   #13827
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
OK, I was mainly curious as to how important it is to make the front tire pressure 2 lbs higher than the rears, since I used the same pressure (34 lbs) all the way around. I suppose I could do 36 front/34 rear, or 34 front/32 rear, or something like that.
sgoldste01 is offline   Reply With Quote
Old 09-06-2012, 10:11 AM   #13828
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
I might actually add a few psi's over spec to my tires as well, to help with mpg.
Old 09-06-2012, 11:10 AM   #13829
Zeeper
Member#: 299286
2017 Legacy Limited
higher pressure in the front is probably due to the extra weight from the engine and transmission over the front axle.
I run the factory recommended pressure. The car has been tested by Subaru at that pressure.
I think it is pretty dumb to mess with it to either try to save gas (over inflation) or add traction (under inflation), as any gas saving from tire inflation is probably more easily accomplished by using a softer application of the accelerator, or just buy a Prius.
If the car came with higher tire pressures it is not because it is good for the car, it is because they are shipped with 40+ PSI and the tech doing the initial prep checked off the box on your car saying they adjusted the pressure when in fact they didn't do what they were supposed to do.
Keep in mind I asked before driving off the lot if they had adjusted the pressure, the sales rep said "of course, it is part of the prep" and I needed to bleed about 10lbs per tire the next day after I got home and checked it (don't check it when it is hot, it will always be higher).
But it's your car, if you want to mess with the tire pressure, have at it. Just do it from an informed position.
Zeeper is offline   Reply With Quote
Old 09-06-2012, 11:30 AM   #13830
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I don't inflate at higher pressures to increase gas mileage. I increase pressure because I like my tires to have a stiffer side wall for improved handling.
Engineering and marketing consists of compromises. I can imagine the suspension engineers wanting higher pressure for better handling, and the marketing guys wanting lower pressure for a ride that will appeal to more people.
I like a firmer ride than most people, so I increase pressure.
Old 09-06-2012, 11:40 AM   #13831
ans2k
Member#: 315631
2012 Impreza Sport
^^^ agreed
Old 09-06-2012, 11:47 AM   #13832
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Well said! You're exactly right about engineering and compromises. I see it all the time not only in automotive, but aviation as well.
jsteg is offline   Reply With Quote
Old 09-06-2012, 11:47 AM   #13833
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I went from 38/36 to 34/32 and the handling drastically improved, and no impact at all on mpg
Old 09-06-2012, 11:57 AM   #13834
Angelus911
Member#: 89967
2012 Impreza Sport
The TPMs also come on at 4psi +- the recommended pressure, so thats always something to keep in mind
Angelus911 is offline   Reply With Quote
Old 09-06-2012, 12:27 PM   #13835
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Originally Posted by imcausinmadrukis View Post
I used carwoo.com to buy my 2012 Subaru.
I saved about 2-3k on negotiating from my own home.
Secret tip: create multiple fake emails (write down all login in)
I was able to get two different offers on the same car from the same salesperson and saved 700 dollars by pretending the two emails were two different people.
same here...i did the exact same thing.
Blackmamba24kb is offline   Reply With Quote
Old 09-06-2012, 01:12 PM   #13836
kenny doggins
Member#: 326540
2012 Impreza MT SP
Originally Posted by jasonz34 View Post
Where did you get the bar?
that was just a google image search, not my car. and yeah that's totally over the top! I do want a skidplate though.
kenny doggins is offline   Reply With Quote
Old 09-06-2012, 01:17 PM   #13837
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Get off your high horse dude
maybe your the one who should go buy a prius...
KartRacer3 is offline   Reply With Quote
Old 09-06-2012, 01:36 PM   #13838
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I had a skid plate on my TDI, but don't plan to put one on the Impreza. The Impreza's clearance is higher, and the oil pan doesn't hang down unprotected like it did on the TDI.
Old 09-06-2012, 02:20 PM   #13839
Algreen
Member#: 268369
2012 Impreza Premium
Ice Silver
My car came with 42 psi at all corners. I reduced the pressure to the factory recommended 32 f, 30 r, and the handling improved noticeably. Specifically, more oversteer and better bump absorption. Less pressure allows tires to heat more for better traction. Good question about increasing pressure for less rolling resistance though, might lead to increased fuel economy.
Wondering if anyone is running a hitch-mount bumper guard of some sort? I usually leave my ball in the receiver to protect against bumpers touching during parking.
Algreen is offline   Reply With Quote
Old 09-06-2012, 02:37 PM   #13840
kenny doggins
Member#: 326540
2012 Impreza MT SP
sweet. yeah i wonder why anyone would even make them
Old 09-06-2012, 03:01 PM   #13841
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Well, the Subaru rally folks could certainly use a skid plate.
But if you look at the oil pan on your Impreza, you'll see that it isn't hanging in the breeze like on the TDI. It's pretty well protected. With the TDI, I'd worry about tire treads, ice chunks that fall off of cars in front of me in the winter time, etc. I'm not worried about those things with the Impreza.
Old 09-06-2012, 03:19 PM   #13842
Zeeper
Member#: 299286
2017 Legacy Limited
You know what they say, everyone on the internets (sic) is an expert and also has a black belt.
I don't personally know any of the engineers who worked out the optimal tire pressure that is printed on the door frame of my car. I just follow it, I guess I am a lemming that way.
As for your theories, they are worth nada to me. Do what you want, but don't pretend you know better than the engineers, unless you do, in which case pump up your pressure as high as you desire.
Also, when you get a chance, invite me to your multi-million dollar test track so I can see if 79's reported 130mph is possible (in your test car, not mine). I know no one here is relying on their "seat of the pant's observations" when it comes to the optimal tire pressure, you've tested it scientifically, right?
Old 09-06-2012, 03:56 PM   #13843
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
You know what they say, everyone on the internet's is an expert and also has a black belt.
As for your theories, they are worth nada to me. Do what you want, but don't pretend you know better than the engineers, unless you do, in which case join the internet's experts club and pump up your pressure.
Just keep going dude, this is hilarious.
Old 09-06-2012, 04:40 PM   #13844
kenny doggins
Member#: 326540
2012 Impreza MT SP
There are loads of other benefits besides protecting the oil pan. That's all, I get what you're saying.
Old 09-06-2012, 11:28 PM   #13845
Algreen
Member#: 268369
Ice Silver
For those interested, I installed the draw-tite hitch tonight and it was super easy. Less than an hour and you don't even need to drop the muffler, as it is a bit smaller than the 2011 muffler. The fit is very snug and well positioned. Got it from etrailer.com
The pics are a bit dark, but you get the idea.
Old 09-07-2012, 03:34 AM   #13846
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Looks great Al.
uspopo is offline   Reply With Quote
Old 09-07-2012, 11:30 AM   #13847
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
Excellent pix. From the angle of the pix, it looks like the hitch doesn't reduce the ground clearance. True?
tomwi53092 is offline   Reply With Quote
Old 09-07-2012, 12:23 PM   #13848
myrt1987
Member#: 323103
2012 Limited 2.0i
During every cold engine start, the rpms fluctuate pretty drastically about 600 rpms or so. Does anyone else encounter this?
After i turn the key, the rpms will peak and settle down a bit, and settle, and settle, until it sounds relatively quiet almost like its about to shut off (around 1000 rpms) then shoot up to about 1800. Then hover around there until warm.
Temps havent been near freezing or anything. Should i look into this further?
Old 09-07-2012, 12:24 PM   #13849
jsteg
Member#: 329271
Ice Silver Metallic
Doesn't seem normal to me...I'd check it out!
Old 09-07-2012, 12:28 PM   #13850
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I disagree. I've seen similar behavior when the engine is stone cold. I wouldn't worry about it.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
