Old 09-07-2012, 12:29 PM   #13851
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by sgoldste01 View Post
I disagree. I've seen similar behavior when the engine is stone cold. I wouldn't worry about it.
I've never had the engine, while cold, start, then drop below 1000 RPM's, then shoot back up to 1800.........
Also never seen any fluctuation in RPM's either.
jsteg is offline   Reply With Quote
Old 09-07-2012, 12:36 PM   #13852
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Damnit. Thats not what I wanted to hear....
was hopin more for a "oh yea its a subaru thing. dont worry" lol
damnit!
Old 09-07-2012, 12:51 PM   #13853
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
damnit!
Meh. I've seen this behavior. It doesn't do it every day, but I have seen it from time to time. Clearly the computer is playing with the timing and/or gas mixture when the engine first starts.
There are many variables: gas quality, air temp, humidity, engine temp, and so on. Before you decide to do anything about it, I'd wait a week or so, fill up the tank, and see if it continues.
I predict that you will experience this behavior on some days and not on others. Figuring out which combination of variables causes it will be difficult. So I suggest relaxing, observing the situation over the next week or so, and then deciding if a service call is justified.
Your Impreza gets just about the best gas mileage I've ever seen coming from any 2012 Impreza. Clearly your car is running well. I seriously doubt you have anything to worry about.
sgoldste01 is offline   Reply With Quote
Old 09-07-2012, 01:03 PM   #13854
myrt1987
Member#: 323103
2012 Limited 2.0i
Yea i think its probably nothing, but it does it pretty often and i would imagine it will only get worse with winter.
In a seeming unrelated matter, one time the radio completely shut off for about 2 seconds and turned back on like nothing ever happened.
Maybe my car is haunted.
Old 09-07-2012, 01:09 PM   #13855
jsteg
Member#: 329271
Ice Silver Metallic
Both of these issues could be poor grounds. Just keep an eye on it and if problems persist, have it checked out.
Old 09-07-2012, 01:11 PM   #13856
ocellaris
Member#: 302559
The engine changing RPM while warming up is a PZEV thing, not a Subaru thing. I've had a few PZEV cars and they all did this. My 2012 Impreza normally doesn't vary the engine RPM much when warming up, but it definitely catches my attention when it does.
ocellaris is offline   Reply With Quote
Old 09-07-2012, 01:13 PM   #13857
jsteg
Member#: 329271
Ice Silver Metallic
Originally Posted by ocellaris View Post
The engine changing RPM while warming up is a PZEV thing, not a Subaru thing. I've had a few PZEV cars and they all did this. My 2012 Impreza normalyl doesn't vary the engine RPM much when warming up, but it definitely catches my attention when it does.
Maybe this is why I haven't noticed it on mine and thought it could be a potential problem...I don't have PZEV
Old 09-07-2012, 01:15 PM   #13858
myrt1987
Member#: 323103
2012 Limited 2.0i
Yep, I do. That sucks. It cant be good for the engine to be riding the throttle coaster when its cold.
Old 09-07-2012, 01:37 PM   #13859
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^It's normal for cars to idle high when cold. My Impreza does it. My 2010 VW TDI did it. My 1999 Civic does it. Even old carburated cars idle fast until the engine warms enough to set the choke.
I'm confident that no damage is being done during the fast-idle phase of the warm-up.
Old 09-07-2012, 01:42 PM   #13860
kenny doggins
Member#: 326540
2012 Impreza MT SP
Originally Posted by tomwi53092 View Post
Excellent pix. From the angle of the pix, it looks like the hitch doesn't reduce the ground clearance. True?
False. Pretty much any way you look at it. But if it doesn't affect you personally, that's awesome. It does look pretty high and tight, but definitely much lower clearance than without it.
kenny doggins is offline   Reply With Quote
Old 09-07-2012, 01:51 PM   #13861
kenny doggins
Member#: 326540
2012 Impreza MT SP
I've never seen an engine jump back up in rpms after it settles down below 1k.
And you're just talking cold start like first thing in the morning, not cold like winter obviously cause it's the beginning of september?
I think you're def. haunted. I'd check the grounds personally, even if it's causing no damage it can't hurt to poke around and get more familiar with the wiring/fuses and all that great stuff. This vid will help...
Old 09-07-2012, 02:15 PM   #13862
myrt1987
Member#: 323103
2012 Limited 2.0i
Well it will settle down immediately after ignition down to 1000ish, then shoot up. So its not like its warmed up when it starts revving.
I know high rpms are normal for cold start, but its the fluctuation that scares me. The fact that sometimes it sounds like the engines about to just shut off before its given more gas.
...or maybe im just paranoid and being dramatic
Old 09-07-2012, 02:19 PM   #13863
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
we are still talking about the new 2012 imprezas right? i think ive seen mines do similar but generally in the early mornings here in LA (not really cold in the early mornings), i leave for work around 530am, but i just start it and go back in the house to get ready so the car can warm up.
ill take a look next time i start it up and confirm if mines does the same.
Blackmamba24kb is offline   Reply With Quote
Old 09-07-2012, 02:31 PM   #13864
Blackmamba24kb
Member#: 330797
Satin White Pearl
what car do you have? year and model? the new 2012 one? im confused, if its the new one it isnt a pezv?
Old 09-07-2012, 02:37 PM   #13865
kenny doggins
Member#: 326540
2012 Impreza MT SP
is it a CVT? Limited means it has to be CVT right?
Old 09-07-2012, 02:46 PM   #13866
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
During every cold engine start, the rpms fluctuate pretty drastically about 600 rpms or so. Does anyone else encounter this?
After i turn the key, the rpms will peak and settle down a bit, and settle, and settle, until it sounds relatively quiet almost like its about to shut off (around 1000 rpms) then shoot up to about 1800. Then hover around there until warm.
Temps havent been near freezing or anything. Should i look into this further?
Seems normal to me, moreso if you have the AC on.
tomwi53092 is offline   Reply With Quote
Old 09-07-2012, 02:54 PM   #13867
jsteg
Member#: 329271
Ice Silver Metallic
That's correct, he does have CVT if it's a limited...but what does that have to do with anything?
Old 09-07-2012, 03:35 PM   #13868
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Agreed, I don't see how the tranny could make a difference. I have a 5MT in my Sport Premium, and my car behaves the same way.
I like the idea that it could be a PZEV-specific behavior. I also agree that having the A/C on could make a difference too. But tranny? Not relevant.
Old 09-07-2012, 03:39 PM   #13869
jsteg
Member#: 329271
Ice Silver Metallic
True, however, it seems that it would be more "normal" if it didn't go below 1000 after startup, then shoot back up to almost 2k....that seems odd to me, however, like I said, I don't have PZEV.
Old 09-07-2012, 03:40 PM   #13870
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
My 19mm rear sway will be here next Tuesday, i think it will be installed next Saturday when i change my differential oil. Can't wait!
Old 09-07-2012, 03:51 PM   #13871
kenny doggins
Member#: 326540
2012 Impreza MT SP
Yeah high rpms is one thing, but this yo-yo deal can't be right.
And as far as cvt vs mt I don't know, maybe things are wired differently in regard to TPS and whatever pzev specific crap is in there.
Just identifying what we're dealing with was the point.
Old 09-07-2012, 03:55 PM   #13872
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
I believe the rpm bounce behavior is probably the computer shooting a quick burst of fuel into the engine, causing a rich exhaust, in order to warm up the cat converters. It might even open the exhaust valves a little early too. The momentary rich afr probably boggs the motor for a sec. I wouldn't worry unless it actually stalls out on you.
saabarupp is offline   Reply With Quote
Old 09-07-2012, 03:58 PM   #13873
kenny doggins
Member#: 326540
2012 Impreza MT SP
seems legit
Old 09-07-2012, 04:03 PM   #13874
kenny doggins
Member#: 326540
2012 Impreza MT SP
Along these startup lines.. Did anyone else notice super shaky startups for the first couple hundred miles? I was about ready to clean the injectors or something but it smoothed itself out.
Old 09-07-2012, 04:20 PM   #13875
ocellaris
Member#: 302559
Normal. It doesn't always go away either. Boxer engines are not quiet or smooth on cold starts. Its been this way since I had a 1993 Legacy through 4 Subarus.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
