Old 09-18-2012, 02:19 PM   #14026
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by CLL_OBP View Post
What happened? If you don't mind me asking. I got some old ramps I want to replace with RhinoRamps.
I was using the typical metal ramps to raise the front of my 1981 Honda Accord. Even though I was slipping the clutch as gently as I could, the wheels spun and spit the ramps out toward the rear wheels. The car landed on top of them, putting a nice dent in my rocker panels.
At that point, I swore to never use ramps again to lift the front end of a front-wheel drive car. I know our Subies are AWD, but there's still power going to the front, so I feel better about jacking the front end and then lowering the car gently onto jack stands.
I try very hard to not repeat my mistakes.
This is the jack and jack stands I use:
http://www.harborfreight.com/rapid-p...html-7814.html
http://www.harborfreight.com/3-ton-h...MxIn0%3D%0D%0A
Harbor Freight sells rubber pads for the jack stands; I use those too. And I put a hockey puck onto the cradle of the floor jack, for extra protection.
sgoldste01 is offline   Reply With Quote
Old 09-18-2012, 02:52 PM   #14027
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Oh, and I have 4 of those jack stands, so I can lift all 4 tires off the ground at the same time. Useful when rotating tires, bleeding brake lines, changing the tranny and rear diff fluids, etc.
At $15/pair with coupon, why not buy two pairs?
Old 09-18-2012, 02:55 PM   #14028
CLL_OBP
Member#: 310435
12 Sp Limited
M1 EP 0W20 102,450 miles
Damn, sorry to hear that. Manual tranny's are a little tricky with ramps. I've almost run off the top a few times but never had one spin out.
The metal ramps I have are too steep and I couldn't use them with my last car or this one either. I just need another set, not to replace like I said earlier.
CLL_OBP is offline   Reply With Quote
Old 09-18-2012, 05:32 PM   #14029
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i have some lower profile Rhino ramps I just got when I got this car, they work great. I wish i had them before in my life. there is a 2" tall stopper at the end of the ramp so it is really difficult to go too far.
i just need a low profile jack so i can reach under the car to the jack points when 1 end is already up in the air. my Craftsman 3ton jack is too tall to operate the handle
Old 09-18-2012, 05:42 PM   #14030
CLL_OBP
Member#: 310435
12 Sp Limited
Cool, thanks for the info.
Old 09-18-2012, 07:14 PM   #14031
kenny doggins
Member#: 326540
2012 Impreza MT SP
Originally Posted by sgoldste01 View Post
I buy my Amsoil OE 0W20 from a local distributor, so I don't pay shipping. And as was said earlier, I buy my Subaru oil filters on eBay, in a 3-pack, for approximately $7 each.
fwiw, I usually pay the extra few bucks and buy my oil and filters from the dealer. Then I make notation of mileage and date I changed oil.
That way my service records look all official and *sheet.
kenny doggins is offline   Reply With Quote
Old 09-18-2012, 08:08 PM   #14032
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
See my post above for a good jack and jack stand recommendation.
Old 09-18-2012, 08:17 PM   #14033
kenny doggins
Member#: 326540
2012 Impreza MT SP
i found that if you jack up near the rear of the front jack area it will raise the whole side. pretty rad.
Old 09-18-2012, 08:20 PM   #14034
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Do you do that so that you can rotate your tires on the same side of the car (for example, left front to left rear, and left rear to left front)?
Old 09-19-2012, 12:24 AM   #14035
kenny doggins
Member#: 326540
2012 Impreza MT SP
Actually haven't rotated yet, 3,500 miles currently. I was lifting her up to put on 4 jack stands to install the shifter bushings and while I jacked up the front, up went the whole side. Convenient!
Old 09-19-2012, 05:15 AM   #14036
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I guess where I was going was:
What tire rotation pattern will people be using? I haven't looked at my Yoko Avids closely enough to see if they're bi-directional or uni-directional, which would determine what pattern I will use when rotating my tires.
Old 09-19-2012, 05:16 AM   #14037
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
They're bi-directional
jsteg is offline   Reply With Quote
Old 09-19-2012, 05:21 AM   #14038
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
In that case, I'll be bringing my front tires straight back on same side of the car, and crossing my rear tires to the front, when I do a rotation.
And because of that rotation pattern, it's super convenient to have all four tires off the ground at the same time. This was my intention when buying my floor jack and four jack stands.
Old 09-19-2012, 10:12 AM   #14039
skinny557
Member#: 325532
Hello folks, had some question about audio quality and NAV for the sports.
Is there are difference in head unit audio quality for the Sport Premium, Limited non-NAV, and Limited NAV? I really want satellite radio and the best audio quality, but not sure if I want to shell out the $2k for the NAV head unit.
How good is the NAV itself? Any reviews out there?
skinny557 is offline   Reply With Quote
Old 09-19-2012, 10:41 AM   #14040
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
How necessary are winter tires on these cars? They dont have a ton of power, and I never bought winter tires for my other car.
Is awd more dangerous in winter with summer tires then fwd is?
NJ may get snow twice a year, last year none. So i dont wanna shell out $800 unless im at serious risk.
Thx. Im sure Im gonna get drilled for asking.
myrt1987 is online now   Reply With Quote
Old 09-19-2012, 10:44 AM   #14041
Zeeper
Member#: 299286
2015 WRX CVT
For occasional snow the OEM tires work fine (at least when they are new, my personal experience from driving with them in a few snowstorms last winter in upstate NY).
AWD is vastly superior to FWD in the snow, partly because it improves your ability to accelerate and not get stuck in front of oncoming traffic. It does not help you slow down or steer (though regaining lost traction does actually help you steer around things), so drive more cautiously and leave a buffer between you and those in front of you.
The OEM tires are not summer tires, they are all seasons. If you did not switch them to summer tires, which it sounds like you did not do, the OEM are fine.
Zeeper is offline   Reply With Quote
Old 09-19-2012, 10:45 AM   #14042
myrt1987
Member#: 323103
2012 Limited 2.0i
Nope, i got stock tires. Thanks.
Those sti guys are scaring me saying without winter tires youre going to die. lol
Old 09-19-2012, 10:56 AM   #14043
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
STi wheels are generally performance tires, not all-seasons. My stock tires did just fine at the beginning of the year through a few inches of snow.
Reverend_ is offline   Reply With Quote
Old 09-19-2012, 11:49 AM   #14044
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
All of these answers re: snow tires are fine. However, I stumbled across a set of used 16" WRX wheels with young (5k miles) Blizzak snow tires on them. Bought the set for $280. For that price, I'll take the added traction, and will let the Blizzaks take the abuse from salt and potholes, rather than subjecting my nice, lower-profile 17" wheels to that abuse.
No TPMS sensors, but I can live with that.
Old 09-19-2012, 12:00 PM   #14045
Angelus911
Member#: 89967
2012 Impreza Sport
Is there any reason to rotating the tires that way? Just curious, I'll have to rotate mine in about a month or so
Angelus911 is offline   Reply With Quote
Old 09-19-2012, 12:07 PM   #14046
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Book says so
Old 09-19-2012, 12:10 PM   #14047
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
This rotation pattern puts each tire at all four corners of the car, eventually. That way, if one corner of the car wears tires more rapidly than the others, the wear is spread across all four tires, rather than only two of the tires.
Old 09-19-2012, 02:07 PM   #14048
imcausinmadrukis
Member#: 318978
I am planning on doing a muffler delete this weekend and wanted to know if there was some tips on how to remove the muffler. I looked under and noticed that they were held on with some brackets on this oval black thing on the right and left side. Is there any special tool or it just removed with brute force?
imcausinmadrukis is offline   Reply With Quote
Old 09-19-2012, 02:15 PM   #14049
jsteg
Member#: 329271
Ice Silver Metallic
Well said. In addition, most all vehicles especially cars, are set up from the factory with some negative camber in the front, and in many cases the rear as well. If you only do a front to back rotation you will always have premature inner edge wear.
VW recommends a front to back only rotation but I always did as described above.
Old 09-19-2012, 02:43 PM   #14050
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Me too, on my TDI's summer tires (Conti ProContacts). My VW snow tires (General Altimax Arctics) were uni-directional, so I had to keep those on the same side of the car.
I believe the used Blizzaks I bought for the Impreza are uni-directional too. I think uni-directionality has become pretty common for snow tires, as the tread design only allows the tire to fling packed snow out of the treads if the tire is rotating in the specified direction.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
