Old 10-13-2012, 09:57 PM   #14351
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Originally Posted by pkL View Post
So what would be the best way to proceed with this? The service manager did mention though that he would be present to instruct and supervise the polish job. So would that make it okay?
Yea id take it. You can always complain if its bad and then who knows what theyll give you next. lol
Old 10-13-2012, 10:01 PM   #14352
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
The fact he has to instruct makes me wonder the skill of the detailers. If they screw it up more than ask for them to pay for a professional detail job.
ST Eye is offline   Reply With Quote
Old 10-13-2012, 10:53 PM   #14353
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Well its scheduled for the 26th, so I will definitely keep you guys posted, I'm hoping all goes well.
pkL is offline   Reply With Quote
Old 10-13-2012, 11:42 PM   #14354
ST Eye
Member#: 73068
Tell the manager that you're very particular when it comes to your car, and that you want it done right. Good luck, I'm sure you'll be fine.
You said that it was a hairline crack. Can you explain more?
Old 10-14-2012, 12:43 AM   #14355
pkL
Member#: 313093
2012 Impreza 2.0i
That's true I am very particular about my car.
I had my car in for some warranty work and they had washed and detailed my car for me afterwards and when I arrived home I had discovered a lot of hairline scratches. It seems that whoever washed my car had dropped his mitt and had continued to wash it after s/he had picked it back up (at least that is what it looks like).
Old 10-14-2012, 02:25 AM   #14356
ST Eye
Member#: 73068
So like swirl marks? I have always been anal with not having swirl marks, and didn't have them for 3 and a half years. Then I had to get some minor bodywork done and it looks like the guy took a dirty shop rag and wiped the whole car down. Swirl marks EVERYWHERE. That pissed me off.
Old 10-14-2012, 07:43 AM   #14357
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
After being the first to go through the local (reputable) car wash one morning when they first opened, I later found one single scratch on my hood going straight from front to back of the hood, about 1/3 the length of the hood. Spoke to the manager, who had their detail shop buff it out with his orbital buffer (I was watching through the window). Came out perfect.
I make sure I'm not the first person to go through the wash anymore.
sgoldste01 is offline   Reply With Quote
Old 10-14-2012, 10:45 AM   #14358
Zeeper
Member#: 299286
2017 Legacy Limited
LED strip lights in the rear hatch:
I have a strip of lights on order, but decided to prewire them so I am good to go when the strip arrives.
It is pretty simple to add lights that operate off the hatch light (comes on when the hatch is open, after a while reduces to 50% light output, and later will shut off which is how the trunk/hatch light seem to work).
I popped out the rear hatch light to expose the wiring. The Pink wire is hot. I tapped into the pink wire which operates off the hatch switch (goes hot when the hatch is open).
The plastic at the rear of the hatch (that the shade locks into) has an "airbag" emblem. I was a little nervous about messing with it but removing the one black screw in the shade lock area and prying it back reveals that the airbag is not in that area anyway, and provides room to route the wiring easily.
For a ground I did not tap into the switch ground wire, but instead just ran a wire to some bare metal and did my own ground (tested).
I routed both hot and ground wire around the rear hatch washer fluid tube and other wiring and out at the top near the headliner(roof lining).
My plan is to mount the strip inside the car on the headliner. This keeps all the wiring inside the car, and means you don't need to route new wiring through the flexible tubing attached to the hatch.
That area the headliner can be pulled down slightly to hide wiring and also I may add a few holes through it and use twist tie type wire to mount the LED strip (and the strips own adhesive).
The LED strip I ordered is 6 ft long and can be cut, so I plan on figuring out the optimum amount when it arrives and connecting the wires.
The wire I used was from a garage door opener, solid copper core, easy to route. Should be more than sufficient to power an LED strip. I don't plan on adding a fuse because the current draw from the LED should be negigible, but it would be easy to do behind the trim panel (there is a lot of room there to work with).
Zeeper is offline   Reply With Quote
Old 10-15-2012, 03:46 PM   #14359
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
Cool
Originally Posted by PAO56 View Post
has anyone been able to get auto message function to work on the Nav HU?....I havent been able to get either a iphone4 or a droid razor to work......apple states the iphone has the HPF and MAP profile as listed in the Impreza owners manual.....it pairs fine just doesnt seem to want run the auto message function...
any ideas
response back from SOA:
Thank you for taking the time to contact Subaru of America, Inc.
Through our research and testing of the iPhone 4, the MAP profiles in the iPhone 4 do not allow for this function to perform. It cannot read nor send text messages through the Bluetooth hands-free system in your 2012 Impreza. I am sorry, Paul, as there are no modifications we offer for this functionality of the Bluetooth hands-free system in your vehicle.
This functionality seems to have been changed with the iPhone 5. With the iPhone 5, it seems as if text messages can be received and read through the Bluetooth hands-free system; but, not send text messages. We have not yet performed this testing on the iPhone 5 yet. But, from customer contacts, it seems to operate in this manner.
Thank you, Paul, for the opportunity to be of service.
Sincerely,
John J. Mergen
Customer/Dealer Services Department
1-800-SUBARU3 (1-800-782-2783)
Service Request #1-2248093215
now as an update with the ios6 update the iphone 4x and 5 will retrieve message, read them...but not allow you to send one back thru the HU.....so its half functional.....you also must set the notification tab to On under the bluetooth function on the phone....hope this helps some!
PAO56 is offline   Reply With Quote
Old 10-15-2012, 07:59 PM   #14360
MattD87
Member#: 126930
2015 Legacy
CGM
Does anyone know if the brakes are upgraded in the sport from base?
I'm wondering if 15" steel rims will fit a sport.
MattD87 is offline   Reply With Quote
Old 10-15-2012, 08:04 PM   #14361
Zeeper
Member#: 299286
2017 Legacy Limited
Brakes are the same
Old 10-16-2012, 03:23 AM   #14362
pkL
Member#: 313093
2012 Impreza 2.0i
Not so much swirl marks per say but just a lot of scratches, I hope they do a good job polishing or I'll be pissed.
Old 10-16-2012, 09:26 AM   #14363
ST Eye
Member#: 73068
I'll come buff your car to a shine if you retrofit my headlights!
Old 10-17-2012, 12:00 AM   #14364
pkL
Member#: 313093
2012 Impreza 2.0i
Why do you have to be so far? I'm on the West Coast and you're all the way on the East Coast.
Old 10-17-2012, 03:15 PM   #14365
mforce712
Member#: 333201
2013 Impreza sport l
Thumbs up Husky Weatherliner available!
Hi guys-
I was going to buy some weathertech digital fit but found this instead:
http://www.autoaccessoriesgarage.com...r-Floor-Liners
I got it for $91.00 with a coupon I found: EM73GH24
You get $10.00 off so I paid $91.00 vs $101.00
Weathertech's are $170 and have a 10yr warranty vs Husky's Lifetime. Thought I would share this with you guys as I have had weathertech's in my last two cars. The Husky's are also digital fit with the two inch overlap. I just bought it for my 2013 Impreza sport Limited DGM! I love this car!
Cheers!
mforce712 is offline   Reply With Quote
Old 10-17-2012, 11:38 PM   #14366
ans2k
Member#: 315631
2012 Impreza Sport
just did this mod. great thing about having a hatch was it was raining while i did it. i just climbed into the back of the hatch and shut the door and continued. anyways, i was pretty simple. i bought the led strip off ebay. i bought 2 feet but if i were to do it again, i would used 3 feet. i extended the wires using 18 gauge wire and butt connectors. then i used T taps to tap into the light wiring. the light is held on to the roof by velco. holds pretty tight enough. I just wanted the light to turn on and off when i open the hatch. i thought about a switch but i just wanted something simple.
ans2k is offline   Reply With Quote
Old 10-18-2012, 06:05 AM   #14367
pkL
Member#: 313093
2012 Impreza 2.0i
Originally Posted by mforce712 View Post
Hi guys-
Cheers!
Too late, I've ordered the WeatherTech for around $160, so its not too bad. Thanks though.
Old 10-18-2012, 09:25 AM   #14368
ans2k
Member#: 315631
2012 Impreza Sport
Hi guys-
Cheers!
thanks man!! just bought a set!!!
Old 10-18-2012, 09:52 AM   #14369
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Hi guys-
Cheers!
Nice find! Thanks. I just ordered a set! Much cheaper.
SleepNMnky is offline   Reply With Quote
Old 10-18-2012, 03:25 PM   #14370
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Someone needs to post pics after they get them
flyboy1100 is online now   Reply With Quote
Old 10-18-2012, 03:44 PM   #14371
53x12
Member#: 206332
Hi guys-
Cheers!
How do these fit/latch into place with the factory floor mat tabs?
53x12 is offline   Reply With Quote
Old 10-18-2012, 05:47 PM   #14372
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
looks like it, but the pin doesn't go through the mat
http://www.huskyliners.com/WeatherBe...r-floor-liners
their x-act fit liners look comparable to weathertechs, i think that is what i'm still going to get.
Old 10-18-2012, 09:21 PM   #14373
jwilson592
Member#: 333273
2012 Impreza Sport
Marine Blue Pearl
As requested. Sorry for the dirt. :P
jwilson592 is offline   Reply With Quote
Old 10-18-2012, 10:00 PM   #14374
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Those look better than the sample pics. How much of a hassle is the fuel door release?
Hmm, decisions
Old 10-18-2012, 10:25 PM   #14375
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Thanks for the pics, they look good! Looks like they cover up the fuel door release lever, is that right?
gfxguy is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
