Old 11-04-2012, 07:16 PM   #14501
ans2k
Member#: 315631
2012 Impreza Sport
Originally Posted by gfxguy View Post
If anybody's curious, I ended up improvizing by using a two-pronged spade connector; one of the prongs fit perfectly into the conducting part of the connector, and there was room for the other prong to the side. I then taped it all up and zip tied the wires together on either side of the connection to absorb any stress. Not the prettiest connection, but it should hold, and will be easy to revert back to stock.
pics?
ans2k is offline   Reply With Quote
Old 11-04-2012, 07:28 PM   #14502
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Originally Posted by ans2k
pics?
Yeah I took a bunch; I'll put them up later tonight probably.
gfxguy is offline   Reply With Quote
Old 11-04-2012, 09:23 PM   #14503
06SE
Member#: 158925
12' Sport LTD
MBP
I too used this same route. I have been running it like this for a couple of months now and so far so good.
06SE is offline   Reply With Quote
Old 11-04-2012, 11:31 PM   #14504
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Started a new thread and posted them there: http://forums.nasioc.com/forums/show....php?t=2428516
Old 11-06-2012, 04:35 AM   #14505
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by BoxerSport2.0 View Post
Here they are installed on my car, prepare to cut a small penetration hole in the inner splash guard for the inner mounting bracket to be available for the rear mudflaps. Give yourself enough time and purchase 3M Stage 2 Mounting Tape (green print) to put the aero splash guard back on.
Let me know if you have any questions. Thanks.
-Brian
Nice pictures, the mudflaps look good. How are you liking the look so far? No issues or problems? Are those rubber as well?
I'm basically debating between these or the rally armor urethane ones.
pkL is offline   Reply With Quote
Old 11-06-2012, 05:27 AM   #14506
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Thank you, I love the look and they function really well considering I work on a muddy job site everyday. No issues other than they bottom out whenever I go up a steep incline with anyone in the back but that is to be blamed on the spring rate of the stock springs. These are the rally armor UR btw I may have misunderstood your request earlier. Thanks.
-Brian
BoxerSport2.0 is offline   Reply With Quote
Old 11-06-2012, 03:16 PM   #14507
kenny doggins
Member#: 326540
2012 Impreza MT SP
-Brian
If you're tired of the rear flaps scraping, you could drill new mounting holes 1/2" or so above the old ones. Works great and looks better IMO
kenny doggins is offline   Reply With Quote
Old 11-06-2012, 03:23 PM   #14508
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Thanks, yea I've contemplated doing that.
Old 11-07-2012, 10:29 AM   #14509
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
-Brian
Looks great! What crossbars did you use (model number?) Do they bolt onto the factory roof rails?
jay25RS is offline   Reply With Quote
Old 11-07-2012, 10:40 AM   #14510
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Thank you very much, it's Thule 450R Rapid Crossroad Feet and ARB47 (47" Cross bars) BUT because of the tapered roof rails I would get ARB50 as there is not enough room from the inadequate length of the crossbars to put the caps on the rail in the front. They strap around the factory rail on the sport and then lock with a key, they are definitely more secure from theft and a better build I believe. I got everything for a good deal, so I could justify the cost. Let me know if you have anymore questions.
Old 11-07-2012, 10:56 AM   #14511
Zeeper
Member#: 299286
2015 WRX CVT
Snow tires!
Went from a sporty car to sounding like a truck! I'm sure mileage will take a bath as well, more than usual in the winter.
These are Nordman 2 (Chinese made snow tires using retired Nokian tire molds) mounted on new rims blacked out with plastidip.
Zeeper is offline   Reply With Quote
Old 11-07-2012, 03:05 PM   #14512
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
can anyone tell me if these will fit the 2.0i impreza?
http://www.cruxmotorsports.com/index...&product_id=71
i want the i badge overlay
Old 11-07-2012, 03:42 PM   #14513
BOOST3DWRX
Member#: 96454
2012 STi Stage 2
@myrt1987 yes as long as you do not have the sport mesh grill
BOOST3DWRX is offline   Reply With Quote
Old 11-07-2012, 03:57 PM   #14514
myrt1987
Member#: 323103
2012 Limited 2.0i
Thank you sir.
This is probably a stupid question, whats the difference between spark silver and silver? metallic flake?
Old 11-07-2012, 04:37 PM   #14515
n00b on demand
Member#: 158355
2012 Sport 5MT
Just took the car out in the snow for the first time. I'm not impressed at all. I'm guessing its the tires but this car does not feel as stable as my other subarus have felt in the snow. My 06 impreza 2.5i felt like a tank. My '12 impreza sport feels like it constantly wants to go from side to side.
n00b on demand is offline   Reply With Quote
Old 11-07-2012, 04:58 PM   #14516
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
I am right there with you. The Yokohama' s are HORRENDOUS in the snow. It was a rough ride home, it might as well have been a FWD car.
Old 11-07-2012, 05:26 PM   #14517
BOOST3DWRX
Member#: 96454
2012 STi Stage 2
Originally Posted by myrt1987 View Post
Thank you sir.
Correct the normal silver is just a plain silver no flake if you look at the picture of the I badge that is a spark silver it has a heavy metal flake in it.
Im going to try and get pictures up of all the vinyl colors in the next few weeks.
Old 11-07-2012, 06:30 PM   #14518
myrt1987
Member#: 323103
2012 Limited 2.0i
Thanks again boost3d!
Same here. It was super fun but not much traction, i was kinda surprised. and afterwards my tpms light was on. any ideas why? am i leaking air? cold temps to blame?
Old 11-07-2012, 07:12 PM   #14519
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
In this segment, buyers on the fence choose one car over another to save a few hundred bucks. Be glad Subaru chose to cut corners on the tires rather than somewhere else.
Anyone serious about tires, batteries, speakers and head units treats the stockers as place holders.
Commander Keen is offline   Reply With Quote
Old 11-07-2012, 07:40 PM   #14520
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
he he you mean everyone doesn't love 330cca batteries. last time I said battery change had a whole bunch of ppl that were fine with the oem bat in the mtl. hmm lets see interstate mtp 35, pioneer avh 4400bh, kumho ecsta 4x aka cheap pirelli knockoffs, general altimax arctic for winter aka cheaper than blizzaks, hmmm speakers if your gonna upgrade um might as well add a sub and a good amp. I would add wipers to that list also but
then again i am picky.
aeoporta is offline   Reply With Quote
Old 11-07-2012, 08:08 PM   #14521
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
I'm glad to hear I'm not the only one that thinks that! Had to drive on snow covered roads tonight and the car was sliding all over the place. I know tires have a lot to do with it, but so far I'm also not impressed.
jr0bb5 is offline   Reply With Quote
Old 11-07-2012, 08:30 PM   #14522
WStrembitsky
Member#: 323877
2012 Impreza Limited
Get winter tires! Had 8" of snow today, drove past multiple accidents and watched people sliding all over the place. My car was a tank, the only things I had to worry about were the other cars, I now have compete confidence in mine.
WStrembitsky is offline   Reply With Quote
Old 11-07-2012, 10:28 PM   #14523
n00b on demand
Member#: 158355
2012 Sport 5MT
Check your pressure obviously...but it could be something simple like packed snow in the wheel. When i had my previous impreza the ABS light would always go on when the front wheels were packed with snow. Used to go away once the snow was gone after a little driving.
Old 11-07-2012, 10:30 PM   #14524
n00b on demand
Member#: 158355
2012 Sport 5MT
I think I might need to. Thats a 500 dollar expense I didn't want to have to make.
Old 11-08-2012, 02:46 AM   #14525
pkL
Member#: 313093
2012 Impreza 2.0i
-Brian
Sorry just wanted to confirm, you have Rally Armors and not the ones from Pierre? I'm really liking the look.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
