Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-31-2012, 12:53 PM   #15026
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Originally Posted by flyboy1100 View Post
i can't decide if i should change my speakers or not. after changing eq settings they are ok, especially with the little amp I added, not sure how much more I will gain from the speakers.
what kind of amp did you add? what do you mean by little? i think if you add a good amp to power the speakers, then the sound would be better also. but not sure what you mean by little amp you added.
Blackmamba24kb is offline   Reply With Quote
Old 12-31-2012, 02:38 PM   #15027
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Alpine 445u, 45x4 rms.
The sound is worlds different than stock, especially now that I have the eq disabled. Just not sure if I could get a little more punch from some different speakers or not. Overall I'm pretty happy with the sound, just there are times I find it lacking and I assume it is the speakers more than the source now
Old 12-31-2012, 02:40 PM   #15028
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Which speakers do you have? If it's the non-Kicker system, you have a whole lot to gain.
Commander Keen is offline   Reply With Quote
Old 12-31-2012, 02:51 PM   #15029
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Do you have the Kicker upgraded tweeters? They make a huge difference in the high frequency sounds.
ST Eye is offline   Reply With Quote
Old 12-31-2012, 03:36 PM   #15030
Blackmamba24kb
Member#: 330797
Satin White Pearl
maybe find a store where you can return the speakers if they dont make a difference? i guess that would be the only way to truly tell....however if the amp makes it sound better (which it should compared to stock) i think you are good...unless you are a audiophile then i can see why you want to change it out. but i know for sure changing the HU will make a world of difference alone...i just dont want to do that since i like my wheel controls and rather not mess with aftermarket stuff even though i know there are harnesses to make some of the wheel control work but i want to keep all of the wheel controls functioning.
i might add amp like you did.
Old 12-31-2012, 04:07 PM   #15031
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I ordered the car with the Kicker Tweeters, but not the door speakers
Old 12-31-2012, 04:09 PM   #15032
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
and I already put in a similar HU from a Forester so I could add the OEM Sirius Tuner a new HU is not an option unless it is the 4.3" LCD model
i posted pics of the AMP install somewhere, can't remember where right now.
Old 12-31-2012, 04:57 PM   #15033
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i think i have decided to buy speakers. I will probably get the Polk 6501 component unless someone can recommend something better with similar pricing. I will sell the kicker tweeters i have now.
for now I will leave the rears alone as they are mainly fill anyway.
anyone know where the stock wiring comes from for the stock tweeter location?
Old 12-31-2012, 05:44 PM   #15034
Commander Keen
Member#: 319157
The 6501s are great, I think you'll enjoy them. It's easier to leave the stock tweeter wiring in place and drop the aftermarket tweeter wires through the dash.
Old 12-31-2012, 05:59 PM   #15035
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
is it pretty easy to snake it through the rubber into the door? (sorry i don't know the official name for that part)
Old 12-31-2012, 06:14 PM   #15036
Commander Keen
Member#: 319157
It's tricky because the tube is made of two long overlapping sleeves so the wire can get stuck between them. It's easier to fish them through in one direction than the other. Armor-All helps.
Crossovers are in the door where a block of foam used to be, though I don't have pictures of them.
Old 12-31-2012, 06:54 PM   #15037
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
thanks
I placed my order
Old 12-31-2012, 10:56 PM   #15038
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Whats the rattle like on the interior panels with the component speakers? Ive been wanting to change to components but have been afraid of the endless rattle fixes that seem likely to spring up. The plastic panels seem like they would a tinge of "snare" if you will.
scoutisimo is offline   Reply With Quote
Old 12-31-2012, 11:37 PM   #15039
motorace
Member#: 339003
what speakers come in the limited sport? do they suck?
motorace is offline   Reply With Quote
Old 12-31-2012, 11:42 PM   #15040
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by motorace View Post
what seakers come in the limited sport? do they suck?
they aren't horrible, but they aren't good either
Old 12-31-2012, 11:58 PM   #15041
motorace
Member#: 339003
when building an impreza online, the options for better speakers, do those come in the limited standard or are those options an upgrade from the limited?
Old 01-01-2013, 12:11 AM   #15042
06SE
Member#: 158925
12' Sport LTD
MBP
The speaker upgrades are options - even on the limited.
06SE is offline   Reply With Quote
Old 01-01-2013, 02:16 AM   #15043
Commander Keen
Member#: 319157
I didn't notice any additional rattling after installing components. The grilles in the door cards are fairly open, so I'm not concerned about them coloring the sound. If you get rattles, it seems like foam or felt tape where plastic meets steel would take care of it. It's hardly a reason to be afraid of components.
The head unit is mostly at fault, due to its seriously warped EQ curve, which will make even good components sound like a walmart boombox. You can disable it through a secret button combination, and I strongly recommend doing this.
Old 01-01-2013, 05:00 AM   #15044
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
So, what is this button combination and what does it do exactly? Does this apply to the standard bluetooth head unit rather than the upgraded nav head unit?
Dirt Bringer is offline   Reply With Quote
Old 01-01-2013, 05:28 AM   #15045
Commander Keen
Member#: 319157
Yes, it applies to the non-nav unit. The info is in this post.
There are built-in EQ curves based on body style that you can see here.
Then there is the loudness feature, which varies your EQ curve based on the volume.
If you want to hear the music as it was recorded and have good speakers, turn both of these off.
Old 01-01-2013, 10:46 AM   #15046
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Commander,
Did you set your tweeter level to -3db? that is what I'm thinking of doing, not sure though
Old 01-01-2013, 01:30 PM   #15047
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i'm installing my other christmas present and I'm a little dissapointed. I got a COBB short shifter instead of a Kartboy thinking i could adjust it up taller than I could a kartboy and it doesn't look like i can
Old 01-01-2013, 02:06 PM   #15048
Commander Keen
Member#: 319157
I run mine at 0dB. I don't find the tweeters harsh at all with a flat head unit EQ.
I'll keep that in mind about the shifter since I'm planning on getting one.
Old 01-01-2013, 02:48 PM   #15049
Dirt Bringer
Member#: 340297
Ice Silver
I'm unsure as to what exactly this does for me. Would you mind explaining it?
Old 01-01-2013, 04:29 PM   #15050
Commander Keen
Member#: 319157
It defeats the electronic compensation in the head unit intended to make the awful stock speakers sound less awful. When you step up to better speakers, this compensation will make them sound worse, and some think it makes the stock speakers sound worse.
There's no harm in trying this and seeing how you like the sound. It's 100% reversible.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
