Old 01-10-2013, 07:36 AM   #15201
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by LGA2011 View Post
I wash the car once a week at 15$ automatic car full cleaning with rain-X along with wax. I already called the dealership for an appointment to look at it. It shouldn't do that from ice. I can see under the car it's missing pins under the front bumper.
I doubt the pins would fall off from the spot of ice I slighly hit. The Canadian Sport Package is lower than the US model. It's annoying sometime for the ground clearance.
I think those empty holes are for the "front lip" option. My car the nothing on either side as well and the factory splash guard/said plate is only in the middle
Old 01-11-2013, 11:59 AM   #15202
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
What is the size/offset of the 17" 15-spoke wheels and/or how can i find out on my own?
Old 01-11-2013, 12:07 PM   #15203
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Should be stamped on the inside of the wheel
Old 01-11-2013, 12:07 PM   #15204
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I believe the offset is 45 mm.
sgoldste01 is offline   Reply With Quote
Old 01-11-2013, 12:15 PM   #15205
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Originally Posted by Rememo View Post
Some videos shot with a Droid Charge:
At high idle (windy parking lot):
2013 Impreza PZEV exhaust - YouTube
After the 30 minute ride home:
2013 Impreza PZEV idle 2 - YouTube
I'm changing my mind, and agreeing with what others have said...
Something may have come loose in the muffler. Yours just seems to have a bit more "putter" than mine.
thanks for the videos good sir!
hmmm ill make note to the bodyshop guy to take a look and keep an ear out for it and to check it out.
Thanks so much Rememo for the video! appreciate that you took the time (twice) to shoot video for me to compare. i love this thread!
Blackmamba24kb is offline   Reply With Quote
Old 01-11-2013, 12:28 PM   #15206
myrt1987
Member#: 323103
2012 Limited 2.0i
Confirmed 17x7 +48
http://forums.nasioc.com/forums/show....php?t=2239019
im guessing 19x8 +45 would fit, along with 245/35zr19 rubber
thoughts? Im kinda worried about loss of mpgs with 245 width honestly.
Old 01-11-2013, 02:22 PM   #15207
Rpresa
Member#: 341172
2012 GP
Well according to this thread the sport wheels are 17x7 +48 which im assuming is the same offset as the 17x7 silver alloys
http://forums.nasioc.com/forums/show....php?t=2319648
thoughts?
^^ This, exactly this - i've been a long time reader and have only recently started contributing, and this is exactly the question I was going to post in the wheel and tire forum (after doing hours of reading, i've learnt a lot, but I still wanted to triple check with the veterans here, to make sure I was spending my money properly).
'12 Impreza sport, and I threw 225/45r17 winter rubber onto my factory wheels (the 15 spoke 17x7 wheels). No issues with rubbing or clearance at all.
The stock rubber was 205/50r17, so I went 20mm wider without issue, but I kept the overall diamter with 1 or 2% of the original stock overall tire height.
Now, the question I have is the same as myrt 1987; would going to a 245 (245/35r19) width tire work? I've crawled under my car and it looks like it could fit- fender well rub with a heavy load would be close, but I can't tell for sure.
Any help is greatly appreciated guys, and apologies if it's a newby question. I've used the search function for many hours, and have learnt lots, but wanted to confirm.
Ryan
Rpresa is offline   Reply With Quote
Old 01-11-2013, 03:13 PM   #15208
myrt1987
Member#: 323103
2012 Limited 2.0i
Ryan
diameter goes from 25.07in in to 25.75in in according to 1010tires.com. and at 60 mph the speedometer would read 58.4 mph with new tires.
i think id be ok with that. and im pretty sure it will fit.
the only issue i have is wondering if it will affect mpg and handling negatively going to a much wider tire.
EDIT: well after more researching i found a few things: wider tires are better in dry conditions but are easier to hydroplane and slide on ice. It may be harder to turn the steering wheel as well. Acceleration takes a hit because of the increased rolling resistance which also hurts mpg. The braking is improved, however increased road noise and less comfortable. Overall, wider tires only benefit performance as opposed to daily driving.
Ill prob pass on em unless i get a good price.
Old 01-12-2013, 06:51 PM   #15209
doema
Member#: 340222
2013 Impreza HB
This thread is huge!
doema is offline   Reply With Quote
Old 01-12-2013, 09:20 PM   #15210
Wagz87subi
Member#: 343320
Anyone doing anything special with there subi??? I just got a 2013 wrx and I'm open to suggestions.
Thanks
Wagz87subi is offline   Reply With Quote
Old 01-12-2013, 11:55 PM   #15211
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Thanks
Check out this thread:
http://forums.nasioc.com/forums/show....php?t=2294948
Edit: NEVERMIND... missed the WRX part of your statement.
SleepNMnky is offline   Reply With Quote
Old 01-13-2013, 10:21 AM   #15212
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Thanks
This is more of a N/A Impreza thread. You should look into wrx threads for better information. Our cars are quite different. Good choice though, you're going to love it. Check out grimmspeed, cobb, perrin, kartboy, and maybe even cosworth for parts. The wrx has loads of potential. Uel headers would be a priority if I were you.
Good luck man! Congrats on the car.
scoutisimo is offline   Reply With Quote
Old 01-13-2013, 02:40 PM   #15213
abxex
Member#: 295269
I have a set of 205 60 16 winter tires from a previous car. I know they're not ideal but will they work? I have to buy 16" wheels so what width would be best?
abxex is offline   Reply With Quote
Old 01-13-2013, 07:41 PM   #15214
myrt1987
Member#: 323103
2012 Limited 2.0i
stock rims are 17x7 +48mm offset with 205 tire. if youre keeping 205 then stay with 7" wide and 48mm offset
answer: 16x7 +48mm
Old 01-13-2013, 11:13 PM   #15215
abxex
Member#: 295269
answer: 16x7 +48mm
Thank you. Would those 16x7 wheels allow 195/60-16 snow tires if and when I have to buy new snow tires?
Old 01-14-2013, 06:48 AM   #15216
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I would think if you are going to smaller tire width you would want 6-6.5" wide rim, otherwise the tire gets stretched a little and you end up with a wider tire
Old 01-14-2013, 07:42 AM   #15217
abxex
Member#: 295269
That makes sense. Thanks.
Old 01-14-2013, 08:21 AM   #15218
stevehnm
Member#: 329526
2013 Impreza Spt cvt
You're fine with 7" wide rims. The difference between a 195 and a 205 is less than half an inch - unless you're looking for an excuse to buy rims...
http://www.tirerack.com/tires/tirete...sp?techid=200&
stevehnm is offline   Reply With Quote
Old 01-14-2013, 11:08 AM   #15219
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
I've been looking to pick up the Inno fairing for my roof rails. What size fairing is about right for this car? They sell a 43" and a 48"...
Dirt Bringer is offline   Reply With Quote
Old 01-14-2013, 07:14 PM   #15220
abxex
Member#: 295269
Hmmm....now I'm confused. Here's my thinking: I have the limited, so stock 17x7. I want a designated snow tire/wheel combo. I happen to have snow tires (no wheels) from a previous car and they're 205/60/16. I would need to buy 16" wheels. If the wheels could fit both the tires I have laying around and a more ideal size when I have to replace the rubber. I hope that makes sense.
Old 01-14-2013, 07:35 PM   #15221
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
aeoporta is offline   Reply With Quote
Old 01-14-2013, 11:02 PM   #15222
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
I have the 38" Thule Fairing just so you get an idea. Not sure if either would fit but I believe I've seen one installed in the past.
BoxerSport2.0 is offline   Reply With Quote
Old 01-15-2013, 07:26 AM   #15223
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Are you near CT. I have a brand new medium one for sale. It is the same size as the ones pictured in a few of these threads
kinger37 is offline   Reply With Quote
Old 01-15-2013, 09:53 AM   #15224
myrt1987
Member#: 323103
2012 Limited 2.0i
Wink
I dont follow. Are you asking for rims that would fit 16 and 17" tire? Or are you asking if your winter tires will fit onto stock rims?
Btw, you will find your answer in the tire and wheel section. Every question already has been asked on this subject. And you will learn lots more, trust me.
Im not sure myself (about the question or answer actually lol) but i would assume you cannot stretch a 205/60/16 tire for a 17" wheel.
Old 01-15-2013, 12:19 PM   #15225
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
I have a Yakima 38". I think when I measured it, the spacing between the roof rails is about 40".
foghelmut is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
