Old 01-23-2013, 02:32 PM   #15301
doema
Member#: 340222
2013 Impreza HB
The built in EQ can be canceled out with a hidden menu in the stock HU.
http://forums.nasioc.com/forums/show...ht=hidden+menu
I did this yesterday and it helped improve the sound.
Good luck!
Originally Posted by made in china View Post
Take the car to a local stereo shop and get a new system installed.
I agree that the stereo basically sucks, but fortunately Subaru uses a basic double DIN head unit, when most car companies have integrated head units that are darn near impossible to replace.
You could also just try getting better aftermarket speakers installed. Sometimes that'll give good results. I've had cars that needed both replaced, if the stock stereo has too much built in equalization that isn't defeatable, it may not sound good enough with just new speakers.
doema is offline   Reply With Quote
Old 01-23-2013, 07:06 PM   #15302
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
If you cancel out factory EQ and turn off loudness the system will sound better? Is this only with aftermarket speakers/sub?
Old 01-23-2013, 07:29 PM   #15303
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Its with any speakers/sub. It does sound better. Vastly. Of course you will have to adjust your EQ again. Also, when the system is off but the car is on or armed I believe, pressing 1, 4, and tune (the round button/roller to the right) will turn on through mode rather than whatever its tuned to now (for the hatch/sedan model). This levels the frequency through the entire volume range and sounds much better all the time. Try it. 1, 3, tune and 1, 2, tune reset to hatch and sedan modes respectively (they are the same).
Dirt Bringer is offline   Reply With Quote
Old 01-23-2013, 08:33 PM   #15304
myrt1987
Member#: 323103
2012 Limited 2.0i
O.o Can I turn it back on? Does it work on the 4.3"-display stock HU?
Old 01-23-2013, 09:13 PM   #15305
Dirt Bringer
Member#: 340297
Ice Silver
Yes. 1, 3, tune and 1, 2, tune are the preset its already on. Set it to sedan or hatch as per your model, not that it matters, they are exactly the same. 1, 4, tune is the through mode that actually changes how it sounds. That and loudness.
Old 01-23-2013, 09:15 PM   #15306
Rememo
Member#: 340728
2013 Impreza 5-spd
For 4.3" unit:
Credit to original poster...
"Key in ACC position, radio off: Hold preset button #6 while spinning the right adjust knob 4 or 5 notches; release button, then repeat. Now you're in the adjustable presets pages. Spinning the knob or hitting the "back" button will bring up loudness, EQ, and screen brightness settings, which can be toggled with the knob.
Here's the basic setting I arrived at that makes this thing almost sound good: Loudness and EQ both OFF. Back in the regular tone control: Bass -2, Treble +5.
The main problems with this system are that the bass is boomy, and the midrange is attenuated at some very peculiar frequencies. And the frequency where the mid tone control is set makes it useless altogether - leave it flat. As for SRS Labs, no (printable) comment. (I was a sound pro and studio musician in NYC for many years, so I might be, y'know, just tad picky!)
This setting will give the most natural balance generally, and make the mids sound as close to natural as the unit will allow, especially when you turn up the volume. Now you can adjust the bass and treble slightly as needed per tune, i.e. use the tone controls normally - assuming you've defeated the &^%$# motion lockout (see my How-to post)."
Rememo is offline   Reply With Quote
Old 01-23-2013, 09:30 PM   #15307
myrt1987
Member#: 323103
2012 Limited 2.0i
Thanks i just found the thread with this post. Ill try it soon. Thanks guys.
EDIT: Turned off loudness and EQ this morning. There is a definite difference but I didnt mind how it sounded before. Im not much of a sound guy, but if you guys say music should more like that then Ill leave it. I also put the bass to -2 and treble to +5 like that guy said.
Pretty easy and straightforward to do in case anyone is scared to try.
Old 01-24-2013, 08:55 AM   #15308
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Originally Posted by flyboy1100 View Post
i was going to do red. white would be ok for footwells if i decide to have them turn on with the door. I'm not sure i want those on all the time, it will depend on how dim i end up making the lights i guess. amber would be a good choice too, not as harsh as white would be. but for the overhead i'm definitly doing red.
i think i am also going to order 6 LED's and use up to all 6 for additonal lighting in the hatch because it is just way too dim! i don't want to go the led strip route
Nice choice on the red. Let us in on the parts you order. Im not terribly versed on led lighting but figure it cant be too much different than other wiring jobs ive performed.
I was also thinking that theres probably a way to drill a hole to above the cup holder but under the armrest to illuminate the cup holder area as well.. that makes 5 lights.. now where to place the sixth. .
scoutisimo is offline   Reply With Quote
Old 01-24-2013, 10:07 AM   #15309
RXman
Member#: 317181
2012 Impreza Premium
Satin White Pearl
Default Dipstick oil level issue
This is the 3rd time I've gone to a Subaru dealer (twice to the same dealer) for an oil change and all 3 times the dipstick shows, (after the Impreza has sat for 3 hours) a level on the dipstick that is 1/4 to 1/2 inch above the last hole for the full mark. The dealer assured me, they have a machine that is calibrated to fill with the correct amount of oil for my car and this will not cause a problem
My question is - is the dipstick on the 2012 Impreza off (as far as the fill mark) and is the common occurence with other owners?
Thanks!
RXman is offline   Reply With Quote
Old 01-24-2013, 11:10 AM   #15310
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Thanks!
This is common, and shouldn't cause an issue unless egregiously overfilled.
foghelmut is offline   Reply With Quote
Old 01-24-2013, 11:37 AM   #15311
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Thanks!
The high mark is 1/4" to low. I have done 2 oil changes on my car, measured out exactly 5.3qts and it is always above the mark
Old 01-24-2013, 11:40 AM   #15312
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I was thinking 2 per footwell, 1 in the cubby under the radio, and 1 or 2 near the map light, that makes a total of 6-7. Plus 2 total more for the door cubbies, so up to 9 total. I don't plan to try and light the cup holders because I think the 2 overhead should be adequate, they are in the jetta
Old 01-24-2013, 02:08 PM   #15313
RXman
Member#: 317181
Satin White Pearl
Thank you soooo much - hearing from someone who did their own oil change and knows the exact amount of oil put in , eases my concerns about the crankcase NOT being overfilled even though the dipstick shows otherwise
Old 01-24-2013, 02:42 PM   #15314
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Ya, I've just gotten used to it.
Old 01-24-2013, 11:12 PM   #15315
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
Originally Posted by aeoporta View Post
Part Number(s): DCOLICBRKIMP12
subaru front bumper mount specifically for the 2012 and up impreza. still had to pop two screws through bumper to attach it. comes in handy when parking aka bumper wars in nyc.
about $26/27
I can't find it anywhere online, the real OEM originals DCOLICBRKIMP12
All I keep getting is the fake plastic ones.
Where you bought yours?
subaru604 is offline   Reply With Quote
Old 01-25-2013, 06:48 AM   #15316
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I believe that one is the plastic one, I have a metal bracket and it doesn't have that part number, but I don't know it off to of my head either
Old 01-25-2013, 08:43 AM   #15317
Rememo
Member#: 340728
2013 Impreza 5-spd
This one?
http://www.subarupartsforyou.com/cp_...p?partid=13069
This one is probably plastic:
http://www.subarupartsforyou.com/cp_...p?partid=21501
Old 01-25-2013, 08:58 AM   #15318
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by SleepNMnky View Post
It's listed under a TSB... so it's a known issue & will be covered by warranty.
fwiw, I've noticed that my car downshifts/engine brakes a lot less after getting my transmission TSB done on Tuesday. I'm used to it always downshifting down a hill, and now it only seems to do it from time to time. My car was built after the first TSB for engine braking, so this is something totally different.
Angelus911 is offline   Reply With Quote
Old 01-25-2013, 09:35 AM   #15319
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
It is plastic but gives you a cushion for someone to hit instead of your bumper
http://www.subarugenuineparts.com/
Parts lookup
aeoporta is offline   Reply With Quote
Old 01-25-2013, 12:04 PM   #15320
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Rememo View Post
Yup, I have the first one you linked to
Old 01-25-2013, 08:28 PM   #15321
Rice & Gravy
Member#: 39569
'14 Honda Accord
V6 Coupe
Anyone autox theirs? Mt or cvt.
Rice & Gravy is offline   Reply With Quote
Old 01-25-2013, 08:36 PM   #15322
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Moving to Phoenix soon. Anyone know any autox events in that area since we are on the topic?
Old 01-26-2013, 01:31 AM   #15323
Dirt Bringer
Member#: 340297
Ice Silver
On the topic of sway bars, a question. I really want to upgrade the sway bar at the back to reduce body roll and understeer. My question is this, there is the perrin option at 22mm, and the STI option at 19mm. Is 19mm a significant enough difference to seriously improve the performance of the car? Is 22mm going to be too much and unbalance the handling in some form? Also, has anyone been able to or felt the need to put a thicker sway bar on the front?
Old 01-26-2013, 08:32 AM   #15324
Rice & Gravy
Member#: 39569
'14 Honda Accord
V6 Coupe
The bigger the bar the less body roll obviously and greater the oversteer. But with the body rolling less that energy has to be transferred somewhere - and that is to the tires, so a bigger bar is going to make your tires work that much harder. A slightly larger front bar will help offset some of that, but again, that energy has to go somewhere in the front too. In my experience all that is fine in the dry but in the wet and the snow a huge rear bar could make things a little squirrelly if you are not careful.
Old 01-26-2013, 08:39 AM   #15325
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
^ This is why I haven't upgraded my stock front sway bar. If I wanted to make the car drift, I would do this upgrade, but right now I'm most interested in predictable behavior in slippery conditions.
sgoldste01 is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
