Old 02-06-2013, 03:13 PM   #15676
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by myrt1987 View Post
Is there a manufacturer-recommended OCI for these oils? is it 7500?
I believe Amsoil's recommendation for OE (which stands for "original equipment") is to use the car manufacturer's guidelines. So for our cars, that would be 7500 miles unless your driving conditions are severe. Living in upstate NY, some might consider my driving conditions "severe" due to the freezing temps. But I'm not an aggressive driver, and Blackstone said my oil was good for at least 6500 miles.
I believe Amsoil's recommendation for Signature is 15k miles or 1 year, whichever comes first.
So my OCI with Amsoi OE is 6.5k, and I pay $6.10/qt. Signature is $10.55/qt, so if Flyboy's UOA indicates that Signature would be good for more than 11k miles, then the upcharge to Signature would be worth it.
sgoldste01 is offline   Reply With Quote
Old 02-06-2013, 03:16 PM   #15677
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
25k..
Old 02-06-2013, 03:28 PM   #15678
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Originally Posted by flyboy1100 View Post
25k..
OK, so I just visited Amsoil's web site, and Signature is good for 25k miles for normal driving, and 15k miles for severe driving.
I would want to see UOA data to verify that extreme numbers like these are acceptable. Your 8k mile UOA on Signature is a good starting point. I'm hoping to see really good TBN numbers with only 8k miles on the oil.
Amsoil also claims that Signature isn't consumed as quickly as other oils. I'd be curious to see what Signature does in an Impreza that's showing consumption. But that would be an expensive experiment if the Impreza consumes Signature too (although not as expensive as replacing an otherwise good car).
With extended OCI numbers like Signature is claiming, I'd probably change the oil filter half way through the interval (and then add a little oil to make up for the lost oil that was in the old filter).
Old 02-06-2013, 04:26 PM   #15679
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
that was my original plan, but now I think I am going to run with OE until the warranty is nearly up.
Old 02-06-2013, 05:17 PM   #15680
n00b on demand
Member#: 158355
2012 Sport 5MT
Just installed my k&n filter. Would I be an idiot to put the sticker on the airbox?
n00b on demand is offline   Reply With Quote
Old 02-06-2013, 05:22 PM   #15681
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
No, why would that be idiotic?
Am I an idiot for putting an Amsoil sticker on the underside of my hood?
Old 02-06-2013, 05:30 PM   #15682
n00b on demand
Member#: 158355
2012 Sport 5MT
I'm asking because sometime within the next month i'm due for an oil change and i don't want subaru saying anything stupid.
Old 02-06-2013, 05:33 PM   #15683
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I put mine on the air scoop. haha Eff it.
averagewhiteboy is offline   Reply With Quote
Old 02-06-2013, 09:02 PM   #15684
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by Dijm8 View Post
just a standard T10 wedge LED, 6500k 2W has 9 LED's per wedge...alot of fiddling around, very very tight space to get your hand in there like i said above long nose pilers came in handy
ill try get a front on pic over the weekend
Edit:
heres what i got Click here
Thanks, have ordered a pair for myself.
gregorz4 is offline   Reply With Quote
Old 02-06-2013, 11:12 PM   #15685
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
nearly done with my LED's in the:
1. door cubbies
2. footwells
3. cubby under radio.
4. overhead
pics tomorrow, I need to figure out a way to adjust the aim of the drivers side cubby though, it is slightly too high. maybe it won't be noticeable with the footwells turn on, time will tell i guess.
Old 02-06-2013, 11:33 PM   #15686
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
1. door cubbies
2. footwells
4. overhead
Can't wait to see!
SleepNMnky is offline   Reply With Quote
Old 02-06-2013, 11:42 PM   #15687
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by SleepNMnky View Post
Can't wait to see!
also need to figure out what camera settings show it as it is rather than overexposed
i'm really happy with the door cubby though as it is the perfect brightness. Very subtle and not overpowering at all. I don't like lots of interior light at night and I'm happy with them
Old 02-07-2013, 12:27 AM   #15688
hi5.0
Member#: 340456
2013 Impreza
Originally Posted by ans2k View Post
i rather get the aem which is owned by k&n and it is basically the same filter but it is a dry flow filter that does not need to be oiled like the k&n. it can be cleaned and reuse like the k&n. the good side of not needing to oil is if you happen to over oil the k&n it will not only restrict air flow but also get oil on the maf sensor and mess it up.
Do you have a PN for the AEM version? IIRC, I've seen OE replacement air filters for the 2012+ 2.0 Impreza cross referenced with other earlier Subaru models.
Also have had both styles, but prefer the "dry" air filter from AEM.
hi5.0 is offline   Reply With Quote
Old 02-07-2013, 12:28 AM   #15689
tspunk
Member#: 345444
2013 Impreza 5-door
can anybody tell me how to get the fog light cover off? someone told me i can just grab it and pull outwards but my hand slips before i can get it out. there's really no place to grip it with my fingers.
tspunk is offline   Reply With Quote
Old 02-07-2013, 12:37 AM   #15690
ans2k
Member#: 315631
2012 Impreza Sport
man, i dorve throve the snow and it popped off. really not the hard. you either need an interior trim tool removal or tape over a thick flat head. it quite literally pulls forward of the car. i had to install one, so i know. get a the flat head under the cover at the front and make a little get for finger tips. PULL FORWARD. not down, not up, not to the side. forward.
ans2k is offline   Reply With Quote
Old 02-07-2013, 06:41 AM   #15691
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I would think that you'd want to somehow use a tripod and take a no-flash picture. A flash would wash your LED lighting out.
I'm most interested in your overhead lighting solution. It's the cup holders that I most wish had some light shining on them....
Old 02-07-2013, 09:29 AM   #15692
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Ive been waiting for this
scoutisimo is offline   Reply With Quote
Old 02-07-2013, 10:15 AM   #15693
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm slow, between planning, figuring out how to snake wires into the doors, and installing speakers at the same time (soldering every connection) it has taken a lot of time. If I didn't solder everything I would have been done hours ago, lol
Old 02-07-2013, 10:17 AM   #15694
SleepNMnky
Member#: 302491
I used a little plastic pry tool from a blackberry tool kit I have to pry the corner up slightly (a plastic butter knife would work too so not to scratch anything) & once I got my fingers under the corner (outside bottom corner) it lifted right out for me. Pull straight towards you. Snapped back in no problem.
Old 02-07-2013, 12:34 PM   #15695
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Originally Posted by jr0bb5 View Post
Hey man, check THESE out. I just ordered them the other day. Can't wait til they come in. These should be plenty bright.
I was thinking of going with yellow over-lays, but I would rather have the appearance of a clear lens with a yellow light. I'll be sure to post pictures once I get them installed.
Here's an update up on these LEDs for anyone interested.
After having to shave off 4 tabs on the base of each LED, I installed them only to be severely dissapointed. The color of these LEDs look nothing at all like they do in the pictures on this guys eBay page. Instead if a bright, light yellow, they are more if a dim, amber turn signal color. I feel completely ripped off and probably won't be able to return them because I already shaved the tabs.
I would recommend staying far away from these unless you feel like wasting over $50 of your hard earned money.
jr0bb5 is offline   Reply With Quote
Old 02-07-2013, 01:18 PM   #15696
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Sorry to hear that man. It sucks when you order stuff and it sucks.. The white LED's are always nice, but never messed with the colored ones..
Old 02-07-2013, 01:54 PM   #15697
ans2k
Member#: 315631
2012 Impreza Sport
pic? if you want some led ones. mine maybe up for sale. i have these. they dont have the best coverage in front of the car but they do have a great projection forward.
Old 02-07-2013, 02:52 PM   #15698
jr0bb5
Member#: 315353
5MT OBP/DGM
Yeah, you live and you learn. I took a chance on an fleaBay item and lost. I'm going to reserve final judgement until I see them in the dark, but I have a feeling they're not going to look much better.
Thanks, but no thanks. I think I'm just going to stick with the stock bulbs and buy some yellow overlays this time.
Old 02-07-2013, 03:23 PM   #15699
tspunk
Member#: 345444
2013 Impreza 5-door
damn that sucks.
how do you get to the fog lights to change the bulb? do you pull out the fog covers and then just pull the fog light out from the front? or do you have to go under the car and remove some things to get to it?
Old 02-07-2013, 03:50 PM   #15700
ans2k
Member#: 315631
2012 Impreza Sport
damn that sucks.
Go under the car. There is a clip and two screws. If I remember correctly
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
