Old 02-07-2013, 04:08 PM   #15701
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Originally Posted by tspunk View Post
damn that sucks.
how do you get to the fog lights to change the bulb? do you pull out the fog covers and then just pull the fog light out from the front? or do you have to go under the car and remove some things to get to it?
You have to take off the black fog covers first. Then you'll see a black "ring" bracket that holds the fog lamp in place. The bracket has 4 tabs with a hole in the center of each tab. 2 on the right, and 2 on the left. There is a bolt that goes though one of the lower tabs that holds the bracket to the bumper. It's easier to get to the bolt from under the car. To do this you have to remove the two push clips that hold up the black trim piece under the bumper just below where the fogs lights are. Then pull down on the trim piece until you can squeeze your hand between it and the bumper to get to the head of the bolt which is facing toward the rear of the car. i beleive the the bolt is a 10mm. Once you take out the bolt, you'll be able to remove the fog lamp and bracket from the front of the car. Pm me if you have any questions.
jr0bb5 is offline   Reply With Quote
Old 02-07-2013, 04:27 PM   #15702
WStrembitsky
Member#: 323877
2012 Impreza Limited
If you're just looking to change the bulb you can open up the trim piece below the fog light and change it from there. You don't need to pull the light out to change the bulb. I believe there are two clips and a screw that need to be removed to open the bottom up enough to change the bulb.
WStrembitsky is offline   Reply With Quote
Old 02-07-2013, 04:34 PM   #15703
WStrembitsky
Member#: 323877
Originally Posted by ans2k View Post
Go under the car. There is a clip and two screws. If I remember correctly
I didn't read this until after my last post. He might be right. You definitely have to remove three thing to open it up and the definitely are both screw(s) and clip(s).
Old 02-07-2013, 08:15 PM   #15704
jsteg
Member#: 329271
Ice Silver Metallic
I've noticed a lot of people changing their horns to the hella supertones, but has anybody done a swap to "regular" horns? I can't stand the tinny sound the stock, or supertones make.
jsteg is offline   Reply With Quote
Old 02-07-2013, 08:39 PM   #15705
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't see how it would be different than supertones, which I have and like
Old 02-07-2013, 08:39 PM   #15706
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Overhead leds look pretty awesome.....
Old 02-07-2013, 08:50 PM   #15707
jsteg
Member#: 329271
Ice Silver Metallic
I don't know maybe connections might be different, or maybe someone that's done it has a suggestion on a specific horn?? I was just curious.
Old 02-07-2013, 09:04 PM   #15708
scoutisimo
Member#: 315759
2012 Impreza 5 Door
Obsidian Black Pearl
I'm slow, between planning, figuring out how to snake wires into the doors, and installing speakers at the same time (soldering every connection) it has taken a lot of time. If I didn't solder everything I would have been done hours ago, lol
Soldering is the way to go though. Ive been actually waiting for you to snake wires first so I can get a scheme. Hopefully you got inner door card pics. None the less, center cubby idea is great. Cant wait to see it.
scoutisimo is offline   Reply With Quote
Old 02-07-2013, 09:36 PM   #15709
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
Big project underway. Got a steal of a deal on an SPT Exhaust for a '13 WRX 5-Door. Couldn't help but explore the possibility of installing it on my '12 Impreza. A trusted local Subaru shop is helping me make this a reality!
We test fit everything today. The pipe bolts up to the Impreza just fine. It's the hangers and tailpipes on the muffler portion that require some adjustments. I'll be cutting out two spots for the tailpipes in the rear and the hangers will be modified to attach to the existing mounting points for the old muffler. We're shooting for a February 21st installation.
Reverend_ is online now   Reply With Quote
Old 02-07-2013, 09:57 PM   #15710
Unknown77
Member#: 332289
2012 Impreza Premium
Dark Gray Metallic
Video Link: http://youtu.be/VlbFx4sEzoU
Had this idea awhile ago when I got a deal on an '08 STi hatch axleback but just couldn't bear cutting into a perfectly good rear bumper lol. Can't wait to see the results!
Unknown77 is offline   Reply With Quote
Old 02-07-2013, 10:36 PM   #15711
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Hey I just sent you a PM with some questions. Also is this the same exhaust that you have? The pipe looks a little more bent than yours so I'm not sure. Thanks for the help
http://hartford.craigslist.org/pts/3597713879.html
kinger37 is offline   Reply With Quote
Old 02-07-2013, 10:45 PM   #15712
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Won't be done until tomorrow night or maybe Saturday afternoon. I only got a few pics with the cards off, I could get more in the future when I do dynamat, but that is at least 6 weeks away.
I also decided to further dim the footwell and door leds, each is only getting 6mA now as that is plenty bright. They are rated for 30mA (1200mcd), which would be blinding in the dark.
For the overhead the glue is still drying so I don't have them installed yet. Instead of 1, I went back to the original plan of 2 LEDs but they will only be getting 4.5mA of power (rated at 30mA, 2400mcd each). The beam is only 15 degrees and will either cover the shifter or the cupholders, not both, hence 2 LEDs now. If the shifter light is bright enough to light the cubby as well I will be skipping that light as I don't feel like taking the radio out again (see my sat/amp install to see why I don't want to do it again)
I will post pics when I get on a real computer, I also plan to make a thread on this.
Old 02-07-2013, 10:48 PM   #15713
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
Originally Posted by kinger37 View Post
Is this the same exhaust that you have? The pipe looks a little more bent than yours so I'm not sure.
2 reasons I don't think this is the same exhaust as the SPT one I'm using. First, the pipe has bends in it that are much more extreme than the one I just test fit. Second, the dual exhaust layout is different. The SPT one has both coming off each side of the muffler whereas the one you linked has one coming off each side with a branch for the second tip.
Old 02-07-2013, 10:59 PM   #15714
kinger37
Member#: 324423
2012 Impreza Sport
ISM
I figured it was too good to be true! Looks like this is the one i'll need...but a grand is quite pricey... I suppose ill wait and see how yours turns out to see what i want to do. Right now I have the muffler delete with the exhaust turndowns and i love the way it sounds, but those quad tips are just awesome
http://www.ebay.com/itm/Subaru-Impre...vxp=mtr&_uhb=1
Old 02-07-2013, 11:08 PM   #15715
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
I've been thinking about doing this for awhile but price killed it for me too. The only reason I'm able to do this is the steal of a price I got on my SPT Exhaust. Couldn't pass it up!
Old 02-07-2013, 11:09 PM   #15716
Unknown77
Member#: 332289
Dark Gray Metallic
I have an axleback off an '08 STi hatch if you're interested and located in SoCal lol
Old 02-07-2013, 11:15 PM   #15717
kinger37
Member#: 324423
2012 Impreza Sport
ISM
I'm in CT haha
Old 02-07-2013, 11:17 PM   #15718
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
I'm in CT haha
My WRX wheels came from SoCal. That's what I love about NASIOC... it kinda connects you to everything.
Old 02-07-2013, 11:25 PM   #15719
Unknown77
Member#: 332289
Dark Gray Metallic
I'm in CT haha
Aww boo lol. I wonder how much shipping would be though.
Old 02-08-2013, 12:01 AM   #15720
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
8 years ago I got a set of mufflers and the y pipe shipped from socal to ND, it was 70 for shipping and 30 for the mufflers
Old 02-08-2013, 10:27 AM   #15721
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Has anyone got much experience with the Cusco strut tower brace? I know a couple of people have used them but do they do much for the car...anything noticeable? Is it even worth it?
Dirt Bringer is offline   Reply With Quote
Old 02-08-2013, 10:35 AM   #15722
uspopo
Member#: 317014
2012 Impreza Sp Ltd.
Dark Grey Metallic
I have the Cusco brace but I haven't driven my Impreza like my my 84 Corolla GTS or 99 GTI-VR6 (both with strut tower braces) so I can't say if it is worth the 200.00. I've heard the Subaru front end is pretty stiff already so unless you Auto-X the money may be better spent elsewhere. I could never keep my cars bone stock...uugghhh.
uspopo is offline   Reply With Quote
Old 02-08-2013, 10:42 AM   #15723
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
So basically not worth it for the average joe shmo
myrt1987 is online now   Reply With Quote
Old 02-08-2013, 10:54 AM   #15724
Dirt Bringer
Member#: 340297
Ice Silver
That's my problem. I've already got the sway bar on its way. After that I want to upgrade the shift knob (don't like it), and add the sti pedal plates. Beyond that though I can't think of anything worth upgrading...
Old 02-08-2013, 11:32 AM   #15725
uspopo
Member#: 317014
Dark Grey Metallic
19mm RSB upgrade is must....Best 100 bucks spent for our cars...
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
Message Board Statistics All times are GMT -4. The time now is 10:05 AM.
