Old 02-11-2013, 12:01 AM   #15801
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
What other parts are you hoping to carry over?
Reverend_ is offline   Reply With Quote
Old 02-11-2013, 02:06 AM   #15802
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Does anyone here suggest the perrin endlinks for the 19mm sway bar for long term durability or is that not really a concern? Are the endlinks used on the impreza different from the WRX stock endlinks by any chance?
Dirt Bringer is online now   Reply With Quote
Old 02-11-2013, 03:16 AM   #15803
MrLebreen
Member#: 344816
2012 Impreza 2.0i
Second that too. Do you need new end links when putting in the RSB or is it just the bushing? Also is there a front sway bar
MrLebreen is offline   Reply With Quote
Old 02-11-2013, 05:25 AM   #15804
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
IE, can we use parts labeled for other Subarus like the battery tie down, oil cap, rad cap, etc?
Also, is the only suspension option so far the H&R Sport springs?
averagewhiteboy is offline   Reply With Quote
Old 02-11-2013, 07:53 AM   #15805
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
I got a nail in my tire, too close to the sidewall to safely patch. The stock Yokohamas are not available aftermarket. (Really?). The tire shop insists that a different brand tire is okay because its within diameter, which makes sense to me according to what I've read. Am I okay for a long time, or should I be diverting efforts to get new tires as quickly as possible?
foghelmut is offline   Reply With Quote
Old 02-11-2013, 08:14 AM   #15806
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
The OEM Yokos are available on TireRack.com.
https://www.tirerack.com/tires/tires...port%20Premium
But I understand that you're in a hurry to get rolling again.
Personally, I would never mix brands of tires (or even a different tire model from the same brand) on the same axle of the car. If I was in your shoes, I'd drive on the spare tire, order one OEM Yoko tire from TireRack, perhaps pay extra for rapid shipping, and then install that one tire. I'd hate to waste the other three perfectly good tires (even though some people on this forum hate them; I think they're fine for summer use), and I don't like mixing different tires on the same axle.
sgoldste01 is offline   Reply With Quote
Old 02-11-2013, 09:13 AM   #15807
Angelus911
Member#: 89967
2012 Impreza Sport
Is there still an issue with AWD and different tread depths? I thought it was always advisable to get all new tires when you had to replace one due to the varying tread depth
Angelus911 is offline   Reply With Quote
Old 02-11-2013, 09:16 AM   #15808
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
You mean the donut right? theres no spare. Either way the donut is a different diameter then the stock tires isnt it? so how is that any better? Ive always wondered this, especially since ive heard horror stories about different diameter tires on awd.
I think those all can carry over. For lowering purposes, i think those springs are the only ones available.
Old 02-11-2013, 09:24 AM   #15809
foghelmut
Member#: 328414
2012 Impreza SP 5MT
The Yokohama's are backordered on TireRack.
From what I've read elsewhere, and from what the tire shop guy said, Subaru allows up to 3/32 difference in tires. I did some quick math, the diameter of a new Yokohama is 25.2". I measured my tread depth and I'm about 8/32 - 9/32 area, which is less than the 10/32 new. The Toyo Extensa that the shop had have a diameter of 25.1" new.
Taking that 0.1" difference, and remember my 7th grade algebra, we have 1/10 = x/32. Solve for x. 0.1" = 3.2/32" Taking all of that together, I am within 1 or 2 32's apart, which is within tolerable spec.
I think my main concern at this point is to monitor the tires for different wear rates.
But these Yokohama's were so bad in the snow I was planning on replacing them for next winter.
Old 02-11-2013, 09:32 AM   #15810
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I'm just trying to buy foghelmut enough time to receive a matching Yoko tire from TireRack. But your question is valid:
Foghelmut, how many miles do you have on the other three original Yoko tires?
If the tire shop he has visited is telling to replace just one tire (and if that's good advice), then I'd prefer to see him buy a matching OEM Yoko tire from TireRack rather than some different brand/model that the shop is trying to sell him because they don't have the matching tire in stock.
Old 02-11-2013, 09:41 AM   #15811
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
It's a tough decision. The only thing I can tell you is that I don't like to see mismatched tires on the same axle.
I guess if it was me, and if I didn't like the OEM Yoko tires anyway, I might replace the entire set of four tires at the same time.
Here's another option which will cost more money up front but would be the ultimate choice in the long run:
Buy a set of dedicated snow tires on a dedicated set of wheels right now. Install them on the car now. When TireRack gets the OEM Yokos in stock, buy one and have it installed on the original wheel. Use the original wheels/tires from mid-April through Thanksgiving, and use the dedicated snow tires the rest of the time.
I'd hate to see you waste three good Yoko tires. If your complaint with them is their snow performance, then save and use them as your summer wheels/tires, and use dedicated snow tires in the winter. I like my Yokos just fine when there's no snow, but I LOVE my Blizzaks in the winter. Two sets of wheels/tires is the best solution, but it is more expensive up front.
Old 02-11-2013, 10:05 AM   #15812
foghelmut
Member#: 328414
2012 Impreza SP 5MT
14950 ish on the originals.
I would definitely be all about that if I had a place to store the extra set of tires.
Old 02-11-2013, 10:21 AM   #15813
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Does anyone know if the annoying hillstart assist can be disabled on the 5 manual transmission? I feel like it is more of a hindrance that a help and it cant be helping my clutch either.
scoutisimo is offline   Reply With Quote
Old 02-11-2013, 10:21 AM   #15814
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
foghelmut,
I have oem tires 17" if you want them I can give you all four for cheap, they have a whole 9miles on them
aeoporta is offline   Reply With Quote
Old 02-11-2013, 10:23 AM   #15815
aeoporta
Member#: 334126
Dark Gray Mettallic
hill assist can be disabled check manual
Old 02-11-2013, 10:27 AM   #15816
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Originally Posted by aeoporta View Post
foghelmut,
And if Foghelmut doesn't take them, send me a PM. Maybe we can arrange a meeting sometime when I'm on my way to/from LI to visit my daughter at Stony Brook University.
Old 02-11-2013, 10:32 AM   #15817
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Will do. Thank you!
Old 02-11-2013, 10:37 AM   #15818
aeoporta
Member#: 334126
Dark Gray Mettallic
sgoldste01 I am actually road tripping past you to buffalo ny on saturday, I might be able to stop off at your city and you can have them, will be leaving from schenectady so its just me and 90W. I have 2 sets so foghlemut I can still accomodate you , I will test pack the car and make sure everything fits I will then pm you sgoldste01.
1 set of 4 tires have 9 miles off my dgm which got picked up in dec
1 set of 4 tires has 5359 miles off the red which got picked up in sept, (will use them up if no one wants them,
fire sale)
Old 02-11-2013, 10:50 AM   #15819
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Originally Posted by scoutisimo View Post
Will do. Thank you!
Please report back to the forum on this. If I recall correctly, you can disable the Hill Hold feature, but it's a temporary disable, and would be re-enabled again the next time you start the car.
But I might be remembering this incorrectly (it's been 7 months since I read through the owner's manual ), so let us know what you find out.
Old 02-11-2013, 10:59 AM   #15820
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
I just looked in the manual. Page 7-34 for anyone interested.
The hillstart assist when deactivated lights a light on the instrument panel which shows that it is deactivated. I find this incredibly annoying and while I didnt deactivate it yet as I looked in the manual after I got home the light feature seems to hint at it. Next time im out there ill deactivate it and let you know.
Old 02-11-2013, 02:42 PM   #15821
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
This may sound like a stupid question, but why would anyone want to disable the hill assist feature?! I personally feel that it is the best feature, besides AWD, the the Impteza has. Its extremely helpful and I wish that all of my past manual cars had this feature!
jr0bb5 is offline   Reply With Quote
Old 02-11-2013, 02:49 PM   #15822
Sub!eDr!ver
Member#: 88924
2007 Tribeca Limited
05 LGT (98 LGT, 88 Justy)
Some have reported that the hill-holder causes a delay in starting off from a stop - it doesn't release quick enough and you feel some resistance.
Probably just an annoyance, but some don't like little annoyances like that.
Sub!eDr!ver is offline   Reply With Quote
Old 02-11-2013, 02:52 PM   #15823
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Originally Posted by jr0bb5 View Post
This may sound like a stupid question, but why would anyone want to disable the hill assist feature?! I personally feel that it's an excellent and very helpful feature and I wish that I had it on all of my past manual cars!
It appears that the member who requested disabling the feature feels that he needs to use more gas, and needs to slip the clutch more, in order to get the Hill Hold feature to release and allow the car to roll forward.
This Impreza is my first car with the Hill Hold feature (my 2010 TDI didn't have it, but VW added that feature starting in 2011, IIRC). The first time I used the feature on the Impreza, I too wasn't sure if I liked it because it did seem like I had to rev the engine and slip the clutch quite a bit before the feature would release the car. But now that I'm used to the feature and the clutch, I like it.
I'm glad that my 1999 Civic doesn't have the feature. That's the car I use to teach my teenage kids to drive a stick, and I wouldn't want them to rely on the Hill Hold feature as a crutch. Driving a car well without that feature requires more skill, which my kids are getting on the Civic. They don't even know that my Impreza behaves any differently (because I don't let them drive the Impreza yet). By the time I let them drive the Impreza, they will be very skilled at using a clutch without the Hill Hold feature.
I would hate to see someone who relies on the Hill Hold feature get into a manual-tranny car without that feature, and then be forced to start the car on a hill.
Old 02-11-2013, 03:07 PM   #15824
jr0bb5
Member#: 315353
5MT OBP/DGM
You do have a very good point there. I'm glad that I also learned to drive stick without this feature. I'm not sure how long this feature has been around, but I'm pretty sure it wasn't available when I was learning to drive.
Old 02-11-2013, 03:23 PM   #15825
Zeeper
Member#: 299286
2015 WRX CVT
Nah, just toss them on a motorcycle, send them to a steep hill, and have them figure it out. After they master that trick starting on a hill from a stop with any car will be a piece of cake.
Zeeper is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
