Old 02-12-2013, 06:40 PM   #15851
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Dirt Bringer View Post
I'm more worried about over torquing as I don't have a torque wrench and don't want to over torque or under torque as it does provide an important function to the handling of the car.
let me bring you in on a little secret...
the dealer won't use a torque wrench either.
Old 02-12-2013, 06:54 PM   #15852
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Exclamation
Maybe in ND they don't; however, in NE they do...
G-Omaha is offline   Reply With Quote
Old 02-12-2013, 06:55 PM   #15853
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
In addition to the post about winter steelies, is the 16 inch size recommended for doing such a swap just going 16x6.5? Will that allow enough room for the brakes? I'm not sure if the base model wheels are 6.5's or 7's..
averagewhiteboy is offline   Reply With Quote
Old 02-12-2013, 07:10 PM   #15854
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have never seen a dealer use a torque wrench on anything not important, I e head bolts.
Wheel lugs are the worst offense along with any suspension parts..
Granted never really watched much work done at a Subaru dealer.
Old 02-12-2013, 07:13 PM   #15855
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
15X6.5 I think. All the brakes are the same. Unless I can find a killer deal on 16", I will be getting 15" wheels for snow tires
Old 02-12-2013, 07:14 PM   #15856
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Does our 12/13's have WRX brakes? I noticed the fronts are dual pot..
Old 02-12-2013, 08:26 PM   #15857
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
[edit]
Commander Keen is online now   Reply With Quote
Old 02-12-2013, 09:30 PM   #15858
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
I was on perrin's website today ordering a brz antenna and wanted to share.. if you ask the live help for a discount code they give you a code for ten percent off.
scoutisimo is offline   Reply With Quote
Old 02-12-2013, 11:09 PM   #15859
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Tomorrow I will try to get up a thread on the ambient lighting, the more I drive in the dark the more pleased I am with it.
Old 02-13-2013, 04:30 AM   #15860
leonyuen
Member#: 330720
2013 2.0i Sport 5dr
Originally Posted by uspopo View Post
19mm RSB upgrade is must....Best 100 bucks spent for our cars...
Even if we already have the stock RSB?
leonyuen is offline   Reply With Quote
Old 02-13-2013, 07:42 AM   #15861
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Definitely yes.
Old 02-13-2013, 07:52 AM   #15862
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Where are you finding the RSB for $100? Everyone I have found is around $200
kinger37 is offline   Reply With Quote
Old 02-13-2013, 07:54 AM   #15863
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I look forward to seeing this info. I'm especially interested in your overhead lighting solution, with wiring details, component details, and so on. I can live without footwell lighting and cubby lighting. The main thing I want is to illuminate the cup holders.
sgoldste01 is offline   Reply With Quote
Old 02-13-2013, 07:58 AM   #15864
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Maybe, but I don't blame Dirt for being concerned. An experienced tech has a good idea of what 50 foot-pounds feels like. An amateur doesn't.
FYI, I see Harbor Freight coupons in the car magazines, where they advertise torque wrenches for $10. Now I know that a $10 torque wrench isn't going to be perfectly accurate, but for tightening the bolts on a sway bar, or for tightening your wheels' lug nuts, it'll do just fine.
Old 02-13-2013, 08:00 AM   #15865
Zeeper
Member#: 299286
2017 Legacy Limited
FYI, I see Harbor Freight coupons in the car magazines, where they advertise torque wrenches for $10. Now I know that a $10 torque wrench isn't going to be perfectly accurate, but for tightening the bolts on a sway bar, or for tightening you wheels' lug nuts, it'll do just fine.
I have one of their torque wrenches and it works great. If you do any sort of work yourself invest in one, it only takes on sheared bolt to make you regret not having the correct tool (don't ask me how I know).
Zeeper is offline   Reply With Quote
Old 02-13-2013, 08:12 AM   #15866
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yeah. For me, it wasn't a sheared bolt, but rather it was stripping the threads out of an aluminum oil pan.
Another torque wrench tip (regardless of where you buy it): NEVER use a torque wrench to remove nuts/bolts. For that job, use a regular socket wrench or a breaker bar. Only use the torque wrench to tighten nuts/bolts. Using a torque wrench to loosen a stubborn nut/bolt will throw off the accuracy of the torque wrench.
Old 02-13-2013, 09:34 AM   #15867
n00b on demand
Member#: 158355
2012 Sport 5MT
Would 15's be better for snow tires opposed to my stock sized 17's?
n00b on demand is offline   Reply With Quote
Old 02-13-2013, 09:50 AM   #15868
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Many would say "yes" because:
  • 15" tires are usually narrower, which cuts through the snow better
  • 15" tires will have taller sidewall, so potholes and other irregularities that you're likely to hit in the winter time won't bend your wheels
  • 15" tires are cheaper to buy/replace
I'd say the only disadvantage to 15" snow tires is cosmetics--most people like the look of a lower-profile tire than that. Oh, and the car won't handle as crisply on a 15" tire, again because of the taller sidewall. This is why I compromised on a 16" wheel/snow tire. I still have more sidewall than 17", but the tire is low-profile enough that I don't mind the appearance or handling.
Old 02-13-2013, 10:45 AM   #15869
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
I know I've asked this before, but out of interest in case I do this myself when the sway bar arrives, what are the torque specs on the bolts when tightening?
Dirt Bringer is offline   Reply With Quote
Old 02-13-2013, 12:11 PM   #15870
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
http://item.mobileweb.ebay.com/viewi...d=110921987742
Comes in handy for lots of things
Old 02-13-2013, 01:30 PM   #15871
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
This is my first AWD, but the previous few cars that I have ran dedicated snow tires on I ran them on 16x6.5's. One reason being that I couldn't go under 16's to clear the brake calipers. But generally, as agreed on, 16's just look better with a mild sidewall than 15's do. But once I put Brembo's up front on my one, I had to go full out 17's for winter. lol I will probably just go 16x6.5 steelies if it came to that.. But with this AWD, it seems like just keeping 17's, going wider 17's, or getting 18's with BETTER all-season tires will be fine. The stock tires seem to be this cars' one minor downfall.
Old 02-13-2013, 01:35 PM   #15872
Zeeper
Member#: 299286
2017 Legacy Limited
wider is better on dry pavement (e.g. racing slicks) but not for snow tires. Tirerack suggests narrower tires for snow.
Old 02-13-2013, 01:35 PM   #15873
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
In relation, can anyone tell if we have WRX brakes on these cars? The fronts are dual pot's and look quite similar. Not sure if the rotor size is the same though..
Also, don't know if anyone has thought of this yet or tried, but what's the possibility of running STI Brembo's on these? Can this be done using the STI calipers and brackets with bigger 5x100 WRX rotors? Not necessary, just curious. I've seen it done on a BRZ..
And, what's the chances of our seat mount points being the same as a WRX/STI? I think a pair of front seats from one would be awesome.. Especially if you got one with the factory heated seats so everything still worked. I actually really like my stock Sport seats, but again, just a thought. haha
Old 02-13-2013, 01:37 PM   #15874
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
The one way I bypassed that with wheels I had was I ran a set of 17x8's but ran 215's on them. It worked pretty well for FWD in PA winters..
Old 02-13-2013, 01:42 PM   #15875
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
finally found one!
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
