Old 03-26-2013, 11:08 AM   #17101
Zeeper
Member#: 299286
2017 Legacy Limited
Originally Posted by Reverend_ View Post
In the same way, because of the nature of the Impreza's e-Brake having a simple electronic sensor that's tied to the Impreza's computer that disables Electronic Stability Control, could we just install a toggle switch to tell the computer that the e-Brake is on while leaving the actual e-Brake disengaged?
That is what I suggested, but keep this in mind:
my old and dying nissan altima lost its auto antenna function (antenna in the trunk), so the motor would grind but the antenna was stuck.
No biggie, I went to the trunk and cut the power wire into the antenna motor.
And got an airbag light, so there goes the airbag...
and of course I reconnected the power, but the airbag light did not go off
so be careful with electronics, they are unpredictable sometimes.
Zeeper is offline   Reply With Quote
Old 03-26-2013, 11:56 AM   #17102
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
While seemingly unrelated, I've got an AppRadio in my Impreza. There's a wire that's supposed to connect to the e-brake that will allow you to play video on the screen so you're in "park". Almost everyone I know that has this head unit has bypassed that with a toggle switch instead.
Maybe, it looked like a simple 2 wire switch
Old 03-26-2013, 12:58 PM   #17103
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Originally Posted by KC View Post
Off topic, do the steering wheels controls work with the AppRadio?
yes, some info on aftermarket radio located here
http://forums.nasioc.com/forums/show....php?t=2435877
http://forums.nasioc.com/forums/show....php?t=2312813
aeoporta is offline   Reply With Quote
Old 03-26-2013, 02:32 PM   #17104
Zeeper
Member#: 299286
2017 Legacy Limited
Originally Posted by scoutisimo View Post
I just want to retain access to the cubby mostly
OMG I just moved the Perrin to its highest position (= shortest throw, and also most change in the position of the shift lever) and on my test drive I bashed the crap out of my knuckles smacking them into the dash in 1st, 3rd, and 5th!
Just kidding, the throw is now shorter, and the lever is not close to blocking the cubby. It is moving the lever further away in those three gears, but if you can reach the temperature control dial without moving your back off the seat you will have no issue with the position of the lever, and it took me no learning curve to find the lever while driving without searching for it (proprioception not affected by moving the lever the amount the Perrin adapter does, in its shortest throw position).
I also cranked that allen bolt down because this is the final position, the shortest throw is the best
Old 03-26-2013, 02:52 PM   #17105
ltapawan
Member#: 318332
2012 Impreza 5-Door
1981 Corolla Wagon
Just got an email reply from the people at Rally Innovations regarding light bars for our cars. For those interested, they said expect them late April / early May.
Can't wait!!
ltapawan is offline   Reply With Quote
Old 03-26-2013, 03:21 PM   #17106
KC
Member#: 442
16 SS
00 S2000
Can't wait!!
Thicker/bigger than primitive? Pics?
KC is offline   Reply With Quote
Old 03-26-2013, 03:27 PM   #17107
ltapawan
Member#: 318332
2012 Impreza 5-Door
1981 Corolla Wagon
I'm guessing they look something along the lines of -- https://www.rallyinnovations.com/upl..._Bar_front.jpg
Old 03-26-2013, 03:55 PM   #17108
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Seriously what is so hard about engineering that
scoutisimo is offline   Reply With Quote
Old 03-26-2013, 03:55 PM   #17109
kinger37
Member#: 324423
2012 Impreza Sport
ISM
I was interested in a RallyInnovatin bar as well, however, after reading a number of views I have seen multiple people complain of the flimsyness due to the way they mount.
kinger37 is offline   Reply With Quote
Old 03-26-2013, 03:59 PM   #17110
aeoporta
Member#: 334126
Dark Gray Mettallic
+1 and also about the price, I rather spend the money for a better product, we shall see if this new generation cuts the mustard.
Old 03-26-2013, 04:03 PM   #17111
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Are light bars like this purely aesthetic or do you plan on taking these cars off road?
Old 03-26-2013, 04:16 PM   #17112
ltapawan
Member#: 318332
2012 Impreza 5-Door
1981 Corolla Wagon
both.
Old 03-26-2013, 04:27 PM   #17113
aeoporta
Member#: 334126
Dark Gray Mettallic
i plan on driving through all the polluted areas in NJ with my lights glaring ,
I will probably use them when I am traveling my usual back country roads with some light off road usage. I also like the look and plan on painting mine my car color and etc
Old 03-26-2013, 05:07 PM   #17114
kinger37
Member#: 324423
2012 Impreza Sport
ISM
I don't plan on taking my car on heavy off road but back dirt roads. And I would like something to offer protection from snow/ other drivers parking. If you look at the rally innovations bar you will notice it bolts into the license plate. Have you felt how flimsy the bumper is there?? Not to mention if you bump something with the bar you are likely going to damage your bumper. I want something that is aesthetically pleasing yet functional. Until I find that I don't see the need to spend a few hundred bucks on the bar
Old 03-26-2013, 05:25 PM   #17115
Ropes4u
Member#: 323526
Starting April 19th I will rip through twenty miles of dirt road a day, on the way to work. I plan on blinding deer and rabbits before ripping past them at speed haha
Ropes4u is offline   Reply With Quote
Old 03-26-2013, 05:26 PM   #17116
aeoporta
Member#: 334126
Dark Gray Mettallic
I am hoping I don't end up having someone custom make a bar for me, this waiting to see whats going to be available aftermarket is killing me. The xv one is freaking already available why why why does the xv get theirs first.
Old 03-26-2013, 05:29 PM   #17117
kinger37
Member#: 324423
2012 Impreza Sport
ISM
I contacted the company and they said the XV bar will fit on our cars. You have to buy the skid plate too. I just don't like the looks of it. I assume you are talking about Primitive
Old 03-26-2013, 05:30 PM   #17118
ltapawan
Member#: 318332
2012 Impreza 5-Door
1981 Corolla Wagon
They do? Maybe it'll fit ours? lol
Old 03-26-2013, 05:31 PM   #17119
aeoporta
Member#: 334126
Dark Gray Mettallic
yep, especially annoying given when the reg imp was released in comparison to the xv, i also don't need the skid plate so that also deal breaker for me
Old 03-26-2013, 05:38 PM   #17120
kinger37
Member#: 324423
2012 Impreza Sport
ISM
I contacted Primitive. For our car $255 for the bar and $239 for the skid plate plus whatever shipping is. Yeah, no thanks. You need the skid plate because the bar bolts to it. They sent me pictures of it mounted on an XV, I think it looks pretty lame.
Old 03-26-2013, 05:47 PM   #17121
aeoporta
Member#: 334126
Dark Gray Mettallic
I guess I will hold out to see what gorilla does, otherwise
Old 03-26-2013, 05:57 PM   #17122
ltapawan
Member#: 318332
2012 Impreza 5-Door
1981 Corolla Wagon
I wonder how much to get one custom fabricated...
Old 03-26-2013, 06:12 PM   #17123
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Since we're talking about fabrication and things not out yet, any word of anyone making a WRX style hood for these? That dark grey test mule had one and it looked great on the car. I'd love one.
averagewhiteboy is offline   Reply With Quote
Old 03-26-2013, 06:19 PM   #17124
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
That'd be cool... but to me, if your hood scoop isn't functional, it's rice. Cept for older scoobies like the 99 Legacy and such.
Reverend_ is offline   Reply With Quote
Old 03-26-2013, 07:12 PM   #17125
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Exactly. Even the old gen 1 Imprezas and such had the scoops and vents that were closed. To me, I just think the front would benefit from it. I love the back of the wagon, but the front is just so "there". And I'm not talking a giant STI style scoop, just the clean one from the newer WRX and Leggy turbo.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
