Old 04-04-2013, 01:54 AM   #17351
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
So I've been playing with tire pressures and I'm currently running 41/39.5 psi. I'm not sure if this is too high and whether there are any risks to running it this way. I am well aware that the recommended pressure is much lower, something like 32/30, but seriously, screw that, no one listens to that anyway. I feel like the steering is a lot more positive and the car handles much better with the more heavily inflated tires, but at the same time, I'm not sure if this is a good idea or not. Today I checked tire pressure and adjusted as I had been running closer to 44 (my previous gauge was a piece of crap), but overall I feel like the car handles better with more air. Maybe the problem is just the crap tires?
Dirt Bringer is offline   Reply With Quote
Old 04-04-2013, 03:34 AM   #17352
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I was totally wondering this as well.
averagewhiteboy is offline   Reply With Quote
Old 04-04-2013, 03:56 AM   #17353
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
Originally Posted by danstheman7 View Post
Looks good! how much did it cost you?
It was pricey, came out to $400 shipped. Way better than a flimsy universal one though!
MCarp22 is offline   Reply With Quote
Old 04-04-2013, 03:58 AM   #17354
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
The tires also act as a spring, and increased air pressure effectively raises the spring rate.
Old 04-04-2013, 06:01 AM   #17355
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
If you really wanted to maximize tire wear, you could spring for a pyrometer. (around 75 bucks at Advance Auto Parts) Recommended tire pressure varies because of the weight of the load the tire carries. If you shoot the tread in the center and edges with a pyro, the temp should be equal. If there is a variance, ie: center is warmer than the edges, that would indicate over inflation. Under inflation would show a higher temp near the sides of the tread than the middle. Either would result in uneven, (premature), tire wear because the contact patch does not have the weight distributed evenly across the width of the tread, which also means less then optimal traction. We're not talking huge differences here , just for clarification. So if you really wanted to be anal about proper inflation, that would be the way to do it.
Note that over inflation may help with mpg's due to reduced friction against the road though, but you're wearing out the middle before the edges.
John
edit: I might also add that an alignment issue would result in unequal readings. Simply stated, friction = heat.
Guzzi 1 is offline   Reply With Quote
Old 04-04-2013, 06:34 AM   #17356
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I found either 36/34 or 35/33 to be best. If I went to 38/36 it was too high and in an aggressive turn the rear tires would lose grip.
Higher isn't always better.
flyboy1100 is online now   Reply With Quote
Old 04-04-2013, 07:27 AM   #17357
Angelus911
Member#: 89967
2012 Impreza Sport
Especially for wet traction, too.
Angelus911 is offline   Reply With Quote
Old 04-04-2013, 10:00 AM   #17358
Dirt Bringer
Member#: 340297
Ice Silver
Better than the front losing grip and understeering into oblivion. I rechecked my pressure after the tires had cooled and it was closer to 40/38.5. Are we supposed to test pressure when the tires are warm or cold?
Old 04-04-2013, 10:07 AM   #17359
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
I run the max psi rating (44 I think) quite regularly. I get better mpgs and the car feels less sloppy. The dealer always sets it to 36/35 and I just head to sheetz for the free air.
I also don't really drive like a madman. I try to baby my little scoob.
scoutisimo is offline   Reply With Quote
Old 04-04-2013, 10:24 AM   #17360
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Understeer is safer than oversteer. You dont want to spin into oncoming traffic, its better to take collision head on for more cushion.
I keep mine a bit higher then spec around 36-39psi.
Old 04-04-2013, 10:54 AM   #17361
Dirt Bringer
Member#: 340297
Ice Silver
It's also a lot more boring.
Old 04-04-2013, 11:21 AM   #17362
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
There's something to be said for control. Not everyone has learned how to control an oversteering car.
sgoldste01 is offline   Reply With Quote
Old 04-04-2013, 11:29 AM   #17363
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Stone cold.
Run what you want, but I tried the higher pressures last summer and was not impressed, the stock tires loose grip easily and even easier yet when you ramp up the pressure higher than 4psi over stock.
I also saw no mpg loss by running them anywhere from 40 down to 34/32.
I still think 35/33 or 36/34 is the sweet spot. I generally drive really hard
Old 04-04-2013, 11:37 AM   #17364
myrt1987
Member#: 323103
2012 Limited 2.0i
Totally bro. If you ain't out of control, you ain't in control.
Old 04-04-2013, 12:21 PM   #17365
Dirt Bringer
Member#: 340297
Ice Silver
"If everything seems under control, you're not going fast enough"
Old 04-04-2013, 12:30 PM   #17366
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
...said the guy who gets the best fuel economy on this forum.
Old 04-04-2013, 12:49 PM   #17367
myrt1987
Member#: 323103
2012 Limited 2.0i
Hey man, Im just living life 1/4 mile at a time.
Old 04-04-2013, 01:23 PM   #17368
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Now, let's just say you run better tires.. The stock Yoko's suck. Can you successfully run a little higher with better ones?
Old 04-04-2013, 01:36 PM   #17369
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Question for the guys with auto climate control...when you turn on the auto setting, is it supposed to turn on to full blast? No matter what the temperature setting, whenever I turn on auto climate control it turns up to full blast and doesn't lower. Is that normal?
gregorz4 is offline   Reply With Quote
Old 04-04-2013, 02:19 PM   #17370
stevehnm
Member#: 329526
2013 Impreza Spt cvt
The higher you run the less the tire will mold to the surface, so the less friction aka traction. Back with higher profile tires the more you ran the less the wear - so checking with an ir thermometer doesn't necessarily tell you that the insides are wearing faster, it could just be the shoulders are wearing more slowly than the centers are.
Pressure ratings on tires are for sea level and very cold so there is a safety margin - if you pump them up to 44 psi in the cold at low elevation then climb to a high elevation and when warm they could be over 50 psi. E.g. If you go from sea level to 9,000 feet that 44 psi turns to 48 psi. Of course you people on the east coast would have to either drive a long way or take the car up in an airplane...
Further then, if you had filled the tires at 30 deg f at sea level then climbed to 9,000 feet and the temperature was 80 deg, you would have 53 psi in them.
stevehnm is offline   Reply With Quote
Old 04-04-2013, 03:45 PM   #17371
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
why does everyone think more pressure = better?
it depends on the tire, load rating, size, etc etc etc. there are too many factors to just say "yes". generally speaking more pressure = less rolling resistance AKA traction. hence if you purely are going for more MPG you increase pressure, but if you are going for traction you drop the pressure.
here is a good article i just read and kinda want to try out in a few months when it is warmer
http://www.autocross.us/forums/lofiv...x.php?t46.html
Old 04-04-2013, 03:48 PM   #17372
Zeeper
Member#: 299286
2015 WRX CVT
I agree, the engineers who designated the tire pressure for the Impreza have access to much more sophisticated measuring devices than I do. Until I build my very own multi-million dollar test track, I will just use the designated pressure and not pretend my seat of the pants observations are as good as their calculated measurements.
I am such a lemming.
Zeeper is offline   Reply With Quote
Old 04-04-2013, 03:58 PM   #17373
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
True, but I'm guessing (like in all large manufacturing companies) that the engineers need to strike a compromise with the marketing folks. So engineering might want higher tire pressure to stiffen the sidewalls which will improve handling, and marketing might want softer tire pressures because their research shows that customers (in the USA) want a softer ride. Then marketing finds themselves painted into a corner because they also want the best MPGs they can get, so on the one hand they want tire pressure to go down, and on the other hand they want tire pressure to go up. "I don't know what to do!"
Marketing Guy =>
So the 32/30 PSI we see on the door jam sticker might be the result of that compromise. I generally prefer a firmer ride, so my practice is to inflate 3 lbs higher than the door sticker (35/33 PSI, in the case of our Imprezas with the 17" Yoko tires).
Old 04-04-2013, 04:10 PM   #17374
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
When you start the car and it is cold, the fan will essentially be off. The when the car warms up, the fan will be at "full blast" and will lower over time. This is normal. Now if it is hot inside the car, the opposite may happen.
G-Omaha is offline   Reply With Quote
Old 04-04-2013, 04:28 PM   #17375
Zeeper
Member#: 299286
2015 WRX CVT
Marketing Guy =>
You have a very active imagination.
Whatever the process is that they use to derive the numbers printed on the door jamb, those are the recommended pressures and what the tires have in them when they test the vehicle for things such as fuel economy, cornering, braking, and stability.
You can alter from it one way or the other, but it is you second guessing the tested pressures.
Go for it, it is your car, but don't think that making up stories about what you think happened when the tire pressure was determined means anything but that you like to make up stories about it, in the absence of any evidence whatsoever, so you can rationalize your decision to use a different pressure.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
