Old 04-04-2013, 08:10 PM   #17376
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Originally Posted by G-Omaha View Post
When you start the car and it is cold, the fan will essentially be off. The when the car warms up, the fan will be at "full blast" and will lower over time. This is normal. Now if it is hot inside the car, the opposite may happen.
Yep, and as the target temperature nears, the fan should slow down in speed. Has anyone noticed the A/C turn on automatically (Not with defrost) when you have the temperature towards the cold end of the climate control? I noticed this even when it is not warm in the inside of the car. I always prefer to be in full control of the A/C, but what can you do.
Originally Posted by Zeeper View Post
You have a very active imagination.
Whatever the process is that they use to derive the numbers printed on the door jamb, those are the recommended pressures and what the tires have in them when they test the vehicle for things such as fuel economy, cornering, braking, and stability.
You can alter from it one way or the other, but it is you second guessing the tested pressures.
Go for it, it is your car, but don't think that making up stories about what you think happened when the tire pressure was determined means anything but that you like to make up stories about it, in the absence of any evidence whatsoever, so you can rationalize your decision to use a different pressure.
I think he mainly over inflates because of the firmness, not for any other gain. I personally always stick with the stock pressures. You can't go wrong!
ST Eye is offline   Reply With Quote
Old 04-04-2013, 08:12 PM   #17377
ST Eye
Member#: 73068
And also, I don't know why people are stock Yoko haters? Sure they don't perform like snow tires, and perhaps not the best in the all-season category, but they have low rolling resistance which gives you better gas mileage - which we all want and some complain about not getting!
Old 04-04-2013, 09:59 PM   #17378
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
That's right.
sgoldste01 is offline   Reply With Quote
Old 04-04-2013, 10:01 PM   #17379
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
My only real complaint about them is noise
Old 04-04-2013, 10:05 PM   #17380
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
And I got my headlight armor headlight overlays installed last night, not real happy with them. They look good, but optical clarity is kind of crap. They put lines in the headlight pattern close to the car, w/in 20ft, it isn't noticeable anywhere else, but it is annoying. I might be contacting them to complain. Looking at them you would never guess, until the lights are on anyway
And I got my last door done, overall noise in the car is less, but not gone obviously. Footwells are next which should help with the road noise I hope. I wish I could do something for wind noise but I don't think I can
Old 04-05-2013, 12:36 AM   #17381
nubsub
Member#: 313575
2012 Impreza 2.0i HB
me too.
nubsub is offline   Reply With Quote
Old 04-05-2013, 09:09 AM   #17382
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
The Yoko's are embarrassing in the snow. They shouldn't have an "All Season" label on them.
foghelmut is offline   Reply With Quote
Old 04-05-2013, 09:19 AM   #17383
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
I've been completely satisfied with the traction from the stock tires. However, we had a weak-ass winter hear in southeast Pennsylvania, so I can't say too much about how they did in the snow.
When the tires do wear out, I intend to replace them with something a bit quieter and grippier, but I've got no real complaints at this point.
soobie doo is offline   Reply With Quote
Old 04-05-2013, 10:11 AM   #17384
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
I have a 2nd set of the yokos ready when these are done. If anyone wants to get rid of theirs Ill take em.
Getting mpg in the high 30's I cant complain.
Old 04-05-2013, 10:24 AM   #17385
Angelus911
Member#: 89967
2012 Impreza Sport
I just swapped the stockers back on and took off my winter tires - probably a good thing too, cause I found a sidewall bubble in one of my winter tires. From what I've read this isn't a good thing and I'm going to have to buy new winter tires come November.
Angelus911 is offline   Reply With Quote
Old 04-05-2013, 10:36 AM   #17386
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
hmmmm I have my last set of 4 oem yokos used 9miles aka car was transported with them up for sale. cheaper than tire rack
aeoporta is offline   Reply With Quote
Old 04-05-2013, 11:03 AM   #17387
myrt1987
Member#: 323103
2012 Limited 2.0i
Yea... but Im not gonna waste your time with my low-balls. lol Those are practically brand spankin new.
Plus if I do get new wheels, I may need to change tire sizes anyway.
Old 04-05-2013, 11:21 AM   #17388
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
Well, it looks like I have no choice but to stick with my 5-Door Impreza. The new WRX is only offered in a 4-Door Sedan. Nothing against 4-Door Sedans aesthetically, but I need my functionality. With the gear I haul, I require a Hatch. Amps, Keyboard cases, Trombone cases, Music Stands, and the occasional Laser Tag haul. Trunks don't work for all that loading.
Now the real question is... do I take that money that I potentially save from NOT getting a WRX and continue my car's steady transformation into a WRX-ified 4th Gen Impreza? (insert evil smile here)
Reverend_ is offline   Reply With Quote
Old 04-05-2013, 11:22 AM   #17389
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
I tried mine at 36/36 for a while. The ride is definitely more busy! I like the softer ride of stock pressure. There seems to be a small hit to mpg but meh.
hemophilic is offline   Reply With Quote
Old 04-05-2013, 12:34 PM   #17390
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
My tires are at 37/35 now beside haven't adjusted them in the last week for the slightly warmer temps. I managed to break all 4 tires loose on the on ramp last night at about 45mph....need to drop them back down so I can have better traction again...
Old 04-05-2013, 12:41 PM   #17391
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Got my "new" wheels on. Gotta figure out what pressure works on them since the tires are a little more sporty and stiff than the stocks. They're not new, but they'll be fine for the time being until I get my others.. I'm gonna take some pics this weekend. Just sucks about the springs not being out yet because there's definitely a little more fender gap now.. lol
averagewhiteboy is offline   Reply With Quote
Old 04-05-2013, 12:50 PM   #17392
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Leave the Impreza stock and sock away want you were intending to put into the WRX and wait a year or so. I'd be willing to bet that a 5-Door WRX will be offered in the near future. Remember in 2008, that the 4-Door wasn't offered and that changed in a couple of years - it's simply demand driven. If not a WRX, it may be a "turbo'd" Impreza with the Forester XT engine/drive train (old Impreza GT type of thing).
G-Omaha is offline   Reply With Quote
Old 04-05-2013, 12:55 PM   #17393
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
I could see that happening. I suppose the other problem I have is the romantic relationship I have with the 4th Gen Impreza's looks. Even after drooling over the WRX Concept photos, when I walked out to the parking lot to get my car I couldn't help but think "Damn, that's a good looking car."
I'll keep working on it, but I think you're right. I'll hold off on anything too crazy for awhile.
Old 04-05-2013, 12:58 PM   #17394
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
+1 Same here. I would love to see a beasted up version of our 4th Gen Impreza...
uspopo is offline   Reply With Quote
Old 04-05-2013, 01:17 PM   #17395
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
Well, I could beast up mine and trigger Murphy's Law so they make one. Take one for the team, right?
Old 04-05-2013, 01:23 PM   #17396
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Do it. My fingers are crossed for a five door too.
scoutisimo is offline   Reply With Quote
Old 04-05-2013, 01:36 PM   #17397
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
I have a lot against sedans. Can anyone say "mainstream" and "irrational"?
Dirt Bringer is offline   Reply With Quote
Old 04-05-2013, 01:49 PM   #17398
myrt1987
Member#: 323103
2012 Limited 2.0i
I dont mind that there wont be a 5 door, most people dont need the extra cargo space and prefer a sedan. However, I am very surprised because every car manufacturer has a sporty hatchback now. Now the 5dr impreza is the only option.
Old 04-05-2013, 02:17 PM   #17399
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
What's toyota sporty hatch again? Oh yeah, the matrix
Caocao is offline   Reply With Quote
Old 04-05-2013, 02:26 PM   #17400
aeoporta
Member#: 334126
Dark Gray Mettallic
5dr fooo liiiffe and yes no low ballers , summer 35f 34 r, winter 36f 35r montel jordan says this is how we do it
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
