Old 04-16-2013, 07:41 AM   #17576
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by Unknown77 View Post
My 19mm STi rsb is still laying in the garage. Still gotta find time to actually put it on the car,
30 mins time....find it!!! It's so worth it and you'll be kicking yourself once you realize how little time it takes to install and how much of an improvement it is.
jsteg is offline   Reply With Quote
Old 04-16-2013, 07:48 AM   #17577
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
+1 The RSB upgrade is the first mod all Impreza owners should have done!
uspopo is offline   Reply With Quote
Old 04-16-2013, 08:04 AM   #17578
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Agreed. It makes me wonder why Subaru doesn't just build the car with a 19 mm bar themselves. I'm guessing that the cost difference of a 16 mm vs 19 mm bar could be measured in pennies for a manufacturer like Subaru. And the 19 mm bar doesn't make the car ride more harshly, so customers wouldn't complain about that. I can't imagine that customers would be complaining, "Gee, I wish my car leaned MORE when I go around corners."
Unless it's a safety thing, where Subaru is trying to induce oversteer at the limits so that incompetent drivers have a better chance of regaining control.
sgoldste01 is offline   Reply With Quote
Old 04-16-2013, 08:27 AM   #17579
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by jsteg View Post
Hmmm...hopefully someone who has done both the 19mm RSB and front strut tower brace will chime in. Personally, I think what little bit the front tower brace will do, it should be perfect for me. What also might help is a different set of tires, which for me won't get replaced until the stockers are worn out.
I have done both. The RSB is definitely the better upgrade of the two. The strut tower brace also helps slightly, but it's hard to tell and I could be wrong. If it does, it's very minimal.
gregorz4 is offline   Reply With Quote
Old 04-16-2013, 08:27 AM   #17580
AJB001
Member#: 338330
I agree...It is way easy to install and the difference is amazing! I have cornered to the tires limits and the cornering is fairly neutral with the 19mm sb. On turn in it understeers slightly then it wallows a bit then slight oversteer on exit. Very predictable.
AJB001 is offline   Reply With Quote
Old 04-16-2013, 08:40 AM   #17581
Kharn
Member#: 306129
Has anyone had issues with the hatch sensor being super sensitive? Mine will say its open maybe 60% of the times I open/close it, and I have to get out and close it with some gumption to get it to register.
My passenger wiper insert keeps riding down the arm, eventually it pops out of the outer-most holder on the arm so the holder rides against the glass.
Kharn is offline   Reply With Quote
Old 04-16-2013, 08:46 AM   #17582
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I've never had a problem with the sensor, but I do notice that 80% of the time I have to either give the hatch a good push, or I close the hatch, it's not fully latched, and I need to try again. lol It's rather touchy.
averagewhiteboy is offline   Reply With Quote
Old 04-16-2013, 09:00 AM   #17583
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I've never had this problem with my rear hatch. Perhaps you should go to the dealership and have them adjust the alignment of the latch.
If you're still using the original wipers, Amazon is currently running a sale on the Bosch Clear Advantage wiper blades (two for $20, which is a very good price). You want the 26" for the driver's side, even though the Amazon site says you want 24". The passenger's side uses 16".
Old 04-16-2013, 09:16 AM   #17584
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
I've never had an issue with my hatch & don't find that I need to close it hard to latch either. Definitely have that & your wiper arm checked out.
My only hatch complaint is the license plate rattle when you close it. I'd know that sound anywhere. At the grocery store I heard it behind me in the lot. Turned around & there's another 2012 Impreza hatch.
SleepNMnky is offline   Reply With Quote
Old 04-16-2013, 09:31 AM   #17585
Unknown77
Member#: 332289
2012 Impreza Premium
Dark Gray Metallic
I feel you on the license plate rattle. Makes me cringe sometimes, like when someone slams the car door shut.
Unknown77 is offline   Reply With Quote
Old 04-16-2013, 09:43 AM   #17586
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Did you notice any steering or understeer improvement with the strut tower, or would you recommend a thicker sway bar over a strut tower? ( I have a 19mm sway on there right now)
Dirt Bringer is online now   Reply With Quote
Old 04-16-2013, 10:16 AM   #17587
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
That's an easy fix. Use all 4 screws instead of the top 2. Ad foam padding if it's still rattling after that. Mine is nice and quiet.
Reverend_ is offline   Reply With Quote
Old 04-16-2013, 10:46 AM   #17588
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Originally Posted by Reverend_ View Post
What other suspension/handling modifications have you made? I'm running stock front and rear sways and I'm trying to decide what to do first: sways or strut tower brace.
Only other mod was adding the stock rsb. I plan on a future upgrade to the 19"
scoutisimo is offline   Reply With Quote
Old 04-16-2013, 10:47 AM   #17589
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Originally Posted by Dirt Bringer View Post
I think scoutisimo has, I'm hoping he'll come back with some performance results. I kind of feel like the steering is vague, and am willing to forego a thicker sway bar in exchange for a strut tower if that helps cure the sleepy feeling steering.
I will. I'm in the middle of a move across the entire country at the moment.
Old 04-16-2013, 10:51 AM   #17590
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Are you moving to or from Harrisburg?
Old 04-16-2013, 10:52 AM   #17591
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
And I may be wrong but I do believe a stiffer rear and a softer front sway bar would increase oversteer.
Old 04-16-2013, 10:54 AM   #17592
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
From. Thank god! I can't stand pa!
Old 04-16-2013, 10:59 AM   #17593
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I don't mind PA in general, but my VW TDI left me stuck near you in (are you ready for the irony?) Mechanicsburg, PA for 3 days last year. So I have negative feelings about that place.
Old 04-16-2013, 11:35 AM   #17594
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Have a link, I looked the other day and didn't see it
Old 04-16-2013, 11:43 AM   #17595
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yes, just search for "Bosch Clear Advantage" on Amazon.com. Beneath the picture of the wiper blade, you will see a box titled "Bonus Offer" that describes the sale.
Old 04-16-2013, 11:44 AM   #17596
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
That's why I install license plates with washers behind them and it helps protect the paint
Old 04-16-2013, 11:54 AM   #17597
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
So how many of you are looking at this latest news on the WRX STi spotted testing in Germany and thinking "Hey, I wanna swap those mirrors!"
Because that's totally what I'm thinking. The mirrors on the 4th Gen Impreza have always bothered me just a little. They're oversized IMHO, and now I know why. Go to your local Subaru dealer and look at the new 2014 Forester mirrors. It's the same thing, same identical part. Now look at the new WRX STi... see all the cues it takes from the Impreza 4-Door Sedan. That mirror should be swappable as long as it's mounting point is the same as ours.
Old 04-16-2013, 11:57 AM   #17598
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Looks like a Mitsubishi
Old 04-16-2013, 11:59 AM   #17599
Dirt Bringer
Member#: 340297
Ice Silver
It's basically the same car. Which is good. Because soon we will have aftermarket upgrades like rain. Course I may have moved on to a WRX by the time that thing comes out...
Old 04-16-2013, 12:12 PM   #17600
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
For me, there is no "Switch" to the WRX unless it's offered in a 5-Door. I can't give up the functionality (or the styling that I prefer) of the Hatchback.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
