Old 04-26-2013, 05:47 PM   #17826
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Medium inno fairing and also you will need the long bolt kit for it
aeoporta is offline   Reply With Quote
Old 04-27-2013, 11:03 AM   #17827
Shotokan07
Member#: 300420
2012 Impreza Sprt LT
ISM
Thanks.
Shotokan07 is offline   Reply With Quote
Old 04-27-2013, 11:16 AM   #17828
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Welcome back!
ST Eye is offline   Reply With Quote
Old 04-28-2013, 01:33 AM   #17829
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
So, I understand that putting a rear sway bar on that is too large, such as a 24mm, can make one of the rear inside tires lift off under high limits, but what I'm interested in is, how dangerous is that? I mean, if you are under high limits you would be aware and prepared for oversteer I imagine. I only ask what seems like an obvious question because I have seen hot hatches do it in the past with stock setups. Obviously they were being driven very hard, but still, if they are being set up that way from the factory, how dangerous can it really be?
Dirt Bringer is offline   Reply With Quote
Old 04-28-2013, 01:44 AM   #17830
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
It might not be dangerous, but how well do you expect to accelerate with a wheel in the air? There comes a point where more isn't better.
Commander Keen is offline   Reply With Quote
Old 04-28-2013, 02:01 AM   #17831
Dirt Bringer
Member#: 340297
Ice Silver
I guess that's a good point...I wonder what effect that would have with the AWD on this car. So no one really thinks it might be a fun idea to run a 24mm sway on the back?
Old 04-28-2013, 02:23 AM   #17832
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
As was mentioned, the 24mm rear sway likely lifts the inside rear tire in a corner. Now, with the tire in the air, you have a FWD Impreza.
Not fun.
MCarp22 is offline   Reply With Quote
Old 04-28-2013, 02:54 AM   #17833
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
So we are saying 24 front, 22 rear for max width..? I haven't looked at this in awhile.
averagewhiteboy is offline   Reply With Quote
Old 04-28-2013, 05:50 AM   #17834
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I could be wrong, but I believe the only hot hatches that would lift the inside rear wheel when being driven hard do so because they have a solid rear axle. Our Imprezas have an independent rear suspension, which is superior to a solid rear axle, and I have no interest in mimicking a solid rear axle on my Impreza.
sgoldste01 is offline   Reply With Quote
Old 04-28-2013, 09:41 AM   #17835
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm not sure anyone has found a larger front sway bar for out cars yet, at least not in the US.
If I could get a larger front, I would probably move to a larger rear, but with all that stiffening something still needs to flex, and really it could be any of the other parts, even the rear subframe/diff carrier. So in second thought because I am not going to track this I am going to leave what I have alone. I honestly don't think the rest of the rear suspension can handle the stiffening that would come from a 24mm bar
JamesWilson bent something tracking his IIRC, anyone remember what?
Old 04-28-2013, 10:10 AM   #17836
LuckyNYC
Member#: 72812
2013 Impreza Sport
Ventian Red Pearl
Originally Posted by sgoldste01 View Post
I could be wrong,
Yep
edit: MINIs on the sport suspension from factory do this stock
LuckyNYC is offline   Reply With Quote
Old 04-28-2013, 12:06 PM   #17837
Dirt Bringer
Member#: 340297
Ice Silver
I can't imagine it would be that weak if the car is a platform for the new wrx...
Old 04-28-2013, 12:13 PM   #17838
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
I'm kinda glad the new WRX isn't being offered in a 5-Door. It means I don't have to give up my Impreza! I'm quite attached to it.
Reverend_ is offline   Reply With Quote
Old 04-28-2013, 12:42 PM   #17839
Dirt Bringer
Member#: 340297
Ice Silver
All I want is stiffer springs and the ability to turn off the stability control
Old 04-28-2013, 01:11 PM   #17840
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I saw something posted yesterday at subaru forester, and their stock subframe doesn't compare to the sti assemblies, I assume our essentially base impreza is the same and not the beefy sti one. The platform might be shared, that doesn't mean they give us an sti frame/assemblies
Old 04-28-2013, 01:49 PM   #17841
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
Seems like that's the one thing folks can't figure out. I know it'd void the warranty, but isn't there anything we can change in the computer to have that toggle actually disable what it should? Everything?
Old 04-28-2013, 02:41 PM   #17842
AA9ZZ
Member#: 294058
2012 Impreza
Default 2012 Impreza cylinder and cam cover leaking oil
I have a 2012 Impreza 2.0 with 27k. The oil light kept coming on and as others in this forum have noticed, I thought the sensor was bad. The diagnoses was a leaking right cylinder and leaking cam cover. Anyone else had this issue?
AA9ZZ is offline   Reply With Quote
Old 04-28-2013, 03:23 PM   #17843
Dirt Bringer
Member#: 340297
Ice Silver
Maybe. I just can't see how tracking the car could do that. I mean for gods sake, these cars are supposed to have rally bred DNA. Launch it over a speedbump or push it really hard on a rallycross track, then yeah, maybe, but on a smooth track, I'm kinda pulling a WTF right now.
Old 04-28-2013, 04:09 PM   #17844
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yes a few have
Old 04-28-2013, 04:10 PM   #17845
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I haven't crawled under the back of my car in a while, next time I rotate tires I will take a look at the subframe
Old 04-29-2013, 12:42 AM   #17846
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I mean, for a daily, the car is solid enough. But unlike my Si, I'm not sure if I'd feel comfortable with really "pushing" the car. Even in the Sport trim, it doesn't seem super rugged. But then again, I didn't buy it to go off roading or to track. So I'm not too concerned. lol I just hope this car doesn't fall apart after a year or two. All these scattered issues worry me a little..
Old 04-29-2013, 12:43 AM   #17847
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
My 12 Subie just turned 1 today, going strong with no issues!
Xarthan is offline   Reply With Quote
Old 04-29-2013, 01:09 AM   #17848
Dirt Bringer
Member#: 340297
Ice Silver
The fact that the frame is stiffer than the previous generation, and the fact that basically the same car is the crosstrek, minus the struts, suggests it is in fact somewhat more robust than we give it credit for. I mean, if I Mini can do that without ripping itself apart, I'm going to assume a Subaru can too.
Old 04-29-2013, 01:30 AM   #17849
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
While I don't doubt that, I'm just saying that there has been a couple other issues popping up. A rugged chassis is useless if the rest slowly falls off. haha I love mine so far, just hope they last as long as Subaru's typically do..
Old 04-29-2013, 01:45 AM   #17850
ceezWRX
Member#: 318522
2012 WRX
black
Anyone having same problem as me... Wen coldstarting my car and pushing clutch down, do you guys hear a light screatching noise? Or is it just my 12 wrx..? It only happens on morning starts..
ceezWRX is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
