Old 05-02-2013, 06:54 AM   #17901
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Dirt Bringer View Post
At this point I'm seriously considering returning the rear sway and getting a strut tower brace. I'm a bit short on cash at this point and wasn't planning on spending an extra $125 over the 240 I already spent on the upgraded rear sway. Has anyone here run a 22mm rear sway bar? If so, what did you do for endlinks?
Why don't you just save the cash, and while you are saving up (can't take that long, couple months perhaps?) Run the stock ones, if they bend you might need to find a way to order them sooner, but if they don't just don't run them permanently because they probably won't hold up.
Old 05-02-2013, 07:25 AM   #17902
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
If you are low on funds I would return the 22mm rsb and drop in the 19mm rsb/bushings. The money spent on the 19mm upgrade is better than the strut tower brace with the OEM 16mm rsb.
19mm rsb/no brace > 16mm/tower brace
uspopo is offline   Reply With Quote
Old 05-02-2013, 09:15 AM   #17903
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
I have a 19mm on there...it's not enough. lol
Dirt Bringer is online now   Reply With Quote
Old 05-02-2013, 09:43 AM   #17904
Dirt Bringer
Member#: 340297
Ice Silver
My whiteline bar came with sway bar braces that attach to the control arm mounting point and the sway bar mount. Do these help at all, and should I even use them? They also don't have any collars or brackets to prevent lateral movement. I've seen collars online that prevent this kind of movement, is this a good idea or overkill?
Old 05-02-2013, 10:48 AM   #17905
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Picture?
Old 05-02-2013, 11:20 AM   #17906
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Hmmm, this is interesting. I thought the connections between the RSB, end links, and control arms were meant to articulate. As I recall when I installed my RSB onto the stock end links, there were bushings that allowed the assembly some freedom to move laterally, by design.
Just guessing, but I would think that restricting that movement with extra bracing would make an even stronger case for installing aftermarket end links that are beefier than the stock end links.
sgoldste01 is offline   Reply With Quote
Old 05-02-2013, 11:22 AM   #17907
Dirt Bringer
Member#: 340297
Ice Silver
Apparently it works from what I hear but allows for flex. The 19mm sti rear sway has some collars on it that fit inside the bushings and keep it aligned, preventing lateral movement. This is all very new to me. I know the perrin rear sway has built in collars.
Old 05-02-2013, 11:37 AM   #17908
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK.
I'm not trying to be a jerk, but I have to ask:
When and where do you drive that you need such a neutral-to-oversteering configuration? Do you drift your car on public roads? Are you risking your safety and the safety of others? You sound like you're not swimming in money. Are you aware that by driving in a way that would reveal the neutral/oversteer you so desperately desire, you're not only consuming more gas, but wearing out your tires (and probably other components) more quickly?
It's your money to spend as you wish. The safety thing is actually the bigger concern of mine. I like taking some turns fast too. But I suspect what I call "fast" is at a much lower level than what you call "fast". I've never even made my tires squeal.
I guess I'm just a 50-year-old fart. I'll shut up now and mind my own business.
Old 05-02-2013, 12:01 PM   #17909
Dirt Bringer
Member#: 340297
Ice Silver
OK.
I don't think this car can drift hahaha. Trust me I'm aware of the risk of taking turns fast on public roads. Mostly it comes down to the fact that I would like to minimize body roll, and I grew up driving cars with massive understeer, so I kind of have a phobia of it. I've taken a good few turns at a pretty high rate, but I'm fully aware of when and where to do it, so as not to put my safety and that of others at risk. It's more from a performance feel and peace of mind perspective than the idea that I would actually push the car that far anywhere that wasn't pretty much clear of people and safe. I'm fully aware of the danger, like most of us I used to be a stupid teenager, but now I know where to drive quietly and where to make some noise (far away from everyone else). If it's safety you are concerned with, you needn't worry, I play it safe these days.
Old 05-02-2013, 12:28 PM   #17910
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
...clearly.
I think youre over thinking it. Just buy what you want when you get the money. The car drives just fine either way.
Old 05-02-2013, 06:39 PM   #17911
Dirt Bringer
Member#: 340297
Ice Silver
So I'm really struck between returning this sway bar for the perrin alternative that costs $40 less or just using the whiteline option. The whiteline option doesn't come with collars to prevent lateral movement (as I mentioned above), but the perrin has them built in. Has anyone had any experience with whether this even matters on a typical road car? Do these have a lot of lateral play in them or is that only something to worry about on an actual track?
Old 05-02-2013, 07:05 PM   #17912
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Track is the only place I would worry
Old 05-02-2013, 07:58 PM   #17913
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
Originally Posted by Angelus911 View Post
Orrrr just wait and buy the new WRX when it comes out next year
Screw that! The new WRX is sedan only. I do too much loading/unloading from my hatch to go to a trunk. That, and I'm a sucker for going the unique route, regardless of whether its cost-effective or not.
If/when I do this, it'd be at least 4-5 years down the road. By then, maybe Subaru will have the WRX in a hatch again. For now, I love how my car looks and wouldn't be interested in trading it for anything.
Reverend_ is offline   Reply With Quote
Old 05-02-2013, 08:13 PM   #17914
Dirt Bringer
Member#: 340297
Ice Silver
Sedans are so passe and status quo.
Old 05-02-2013, 08:52 PM   #17915
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
Dijm8 is offline   Reply With Quote
Old 05-02-2013, 08:54 PM   #17916
Dirt Bringer
Member#: 340297
Ice Silver
Originally Posted by Dijm8 View Post
WHERE AND HOW MUCH?!?!
Old 05-02-2013, 08:59 PM   #17917
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
sorry i usually provide links on my purchases but forgot to add it, here they are (although might have to send him a msg to see if he can post to the states)
CLICK ME
Old 05-04-2013, 12:22 PM   #17918
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
Well, I've had the exhaust on for a week or so and I've got no complaints! I got my performance back up, my ground clearance is back, the car is still turning heads (Got a wave from two kids in a Civic with Florida Plates?), and it's really become my car.
Next for the Exhaust is the Exhaust tips. I did some research and looked around at different options. I decided to go with the "quad tips" look... seeing as how I was spoiled when I had the SPT on there. I just couldn't bring myself to go with a single tip on each end, so I searched for a high-quality double-wall tip that would mimic the look I had before. I settled on Red Tail Performance.
They're staggered, look fantastic, and from what I was able to tell, professionally built. The measurements work out great too, as there will still be a slight "reveal" out of the bumper for these. I'll be re-cutting the bumper and using the same Door Edge Guard material I had used before to finish the edges out.
After that's all done, I've still got side skirts and Rally Armors to install.
Old 05-05-2013, 11:15 AM   #17919
Dirt Bringer
Member#: 340297
Ice Silver
So I got my foglight overlays, but I'm not sure how to remove the foglight bezels. I'm sure others here have done it, anyone know how to remove them without breaking anything? I kind of wanted to plastidip the chrome too while I was at it.
Old 05-05-2013, 11:37 AM   #17920
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
click me
Old 05-05-2013, 01:58 PM   #17921
Dirt Bringer
Member#: 340297
Ice Silver
Are the stock endlinks on this car the same as are used on the sti/wrx? They look the same to me but I can't really compare them side by side.
Old 05-05-2013, 03:30 PM   #17922
Angelus911
Member#: 89967
2012 Impreza Sport
Just noticed a small crack in my front bumper, lower left hand side on the bottom. It isn't huge, but now that I noticed it, I'm going to see it all of the time now
Is there anything I can do to minimize the appearance of the crack? I'll try to get a picture of it for a better look.
Edit: here's the crack:
Angelus911 is offline   Reply With Quote
Old 05-05-2013, 09:38 PM   #17923
myrt1987
Member#: 323103
2012 Limited 2.0i
Prob no way to make it disappear. Maybe try pushing both sides from behind if you can, it may reduce the overlapped sides to a hairline crack.
Other then that, put a band-aid on it. lol
Old 05-05-2013, 10:52 PM   #17924
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
go buy a bumper repair kit and fix it from the inside, once you are done with that clean it up with some touch up paint. i did a fix like that on our jetta and it lasted over 3 years
Old 05-05-2013, 11:35 PM   #17925
Paradis
Member#: 334647
2012 POS Impreza
Oh god... I have exactly the same crack !! Will post picture tomorrow
Paradis is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
