Welcome to the North American Subaru Impreza Owners Club Thursday April 24, 2014
Old 05-08-2013, 06:25 PM   #17951
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
Originally Posted by uspopo View Post
When I had my Supertones installed, we initially used the Subimods relay and tested everything before reinstalling the grill. Once everything was put back together and we tested the horns again and it didn't work. We checked every connection and fuse and couldn't figure out why they stopped working. Pulled the grill off to access the bracket and wiring harness and we decided to swap the relay out for OEM Hella one and it worked. The Subimods relay went into the garbage. No issues with the horns since the install.
I installed the harness like it came out of the package and worked from the first press of the horn button.
Subimods said they put in a 5 pin relay instead of the Hella 4 pin cuz the 5 pin works better.
Mine are very loud and always worked so I never touched the harness cuz I love the quality of their harness.
ronjr8102 is offline   Reply With Quote
Old 05-08-2013, 06:50 PM   #17952
uspopo
Member#: 317014
2012 Impreza Sp Ltd.
Dark Grey Metallic
If it works without issues then that is good. Whether the 5 pin relay is better than the factory OEM Hella relay I am not going to debate but the Subimods wiring harness was well done. Maybe the supplier of the Subimods 5 pin relay may had a quality issue and I got a defective unit and used the OEM one instead.
uspopo is offline   Reply With Quote
Old 05-08-2013, 08:17 PM   #17953
ronjr8102
Member#: 216040
dark metallic grey
Ur right, if it works then it's all good. The only reason I say the 5 pin is better than the 4 pin is because that is what Subimods says on their site to selk the harness. So who knows if its true or just a selling gimmick.
Old 05-08-2013, 08:19 PM   #17954
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Would a different number of pins cause different/better sound?
Old 05-08-2013, 08:22 PM   #17955
myrt1987
Member#: 323103
2012 Limited 2.0i
Originally Posted by soobie doo View Post
during the 11 months that I have owned the car, the TPMS light has come on three times. The first time was during Hurricane Sandy, the second time was a couple of weeks ago, the third time was this morning on my way to work. Each time, my pressure gauge has confirmed that at least one tire was significantly below the recommended pressure, indicating that each time, at least one tire had lost pressure much more quickly than usual.
Each time the light came on, it was on very wet roads. Is there a reason that very wet roads would cause a decrease in pressure, or is this all just a strange coincidence?
Stock Yoko tires, stock 15" steel wheels.
Same thing happened to me last week. Light came on during my commute. 3 were at 35psi and one was at 25psi. I pumped it up and nothing since.
Maybe something with the stock tires? I havent heard anything from anyone else.
Old 05-08-2013, 09:00 PM   #17956
tspunk
Member#: 345444
2013 Impreza 5-door
Hey guys,
Can somebody take a look at their windshield wipers in the front for me and tell me if the passenger side rests on the defroster/heater?
I just noticed today that the passenger one sits higher up. it is not perfectly aligned with the defroster/heater strips...
tspunk is offline   Reply With Quote
Old 05-08-2013, 09:04 PM   #17957
Catalyse
Member#: 355887
Hey guys I just got a brand new 2013 WRX and I'm looking to replace the sound system with something a bit nicer. I was curious what others had been putting in their car for door speakers, and where I might put a 12' sub in the car. I wanted to avoid the trunk but I'll go there if need be.
Past that any other suggestions you might have. I obviously don't want to void the warranty but any suggestions aesthetic or otherwise that might make the car more enjoyable for me would be greatly appreciated!
Thanks
Catalyse is offline   Reply With Quote
Old 05-08-2013, 09:30 PM   #17958
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
Thanks
There's always the under seat subwoofers but they aren't all that great in my opinion. I have a 10" 100w (maybe more, not sure) kicker sub in my trunk, and I love it.
danstheman7 is offline   Reply With Quote
Old 05-08-2013, 09:53 PM   #17959
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
This thread is for the 2.0i Non-turbo Imprezas, so our car is a little different from your '13 WRX now that the Impreza and WRX have gone their separate ways. I'm not sure that getting advice for trunk space will be useful to you since the dimensions are all different.
Reverend_ is offline   Reply With Quote
Old 05-08-2013, 11:46 PM   #17960
jspec rsx
Member#: 321746
Originally Posted by tspunk View Post
Hey guys,
That happened to me as well while using the wipers while driving on the freeway I just turned it on again snd it went back to normal sitting on the defroster
jspec rsx is offline   Reply With Quote
Old 05-09-2013, 12:18 AM   #17961
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
I thought I remembered someone saying that the front seats from a WRX wouldn't fit our 4th Gen Impreza. I can't seem to find the post/information about it. What's different between the mounting points for those seats? I'm just curious because I have an opportunity to get a set of 'em for cheap from a guy who just put racing seats in.
Old 05-09-2013, 12:32 AM   #17962
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Mine did initially. I loosened the but and moved it down a tad then tightened the screw. Now it is perfect.
ST Eye is offline   Reply With Quote
Old 05-09-2013, 12:48 AM   #17963
solistik
Member#: 345948
Another cross post from the 2012 Impreza Pictures thread.
Originally Posted by solistik View Post
I threw my WRX wheels on today:
My BC Racing BR Series coilover kit should arrive next week, so I should have that installed with a few other parts I have accumulated recently (Rally Armor mud flaps, Visual Garage shark fin antenna, Subaru OEM body molding, and a few other things). So once all those items are installed, I'll do a little photoshoot if the weather permits it.
solistik is offline   Reply With Quote
Old 05-09-2013, 08:07 AM   #17964
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Hey guys,
Mine are both centered on those strips
Old 05-09-2013, 08:08 AM   #17965
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It looks like they completely redesigned the seat base, if there is a way to swap bases you might be able too.
Old 05-09-2013, 09:17 AM   #17966
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
Thanks
I got these speakers, because they were half price at Best Buy when I bought them.
http://www.pioneerelectronics.com/PU...ries/TS-A1674R
I'm pretty happy with them, but they seem to have a bit less bass than the stock speakers did. Go figure. Thinking of getting a sub at some point to fix that problem.
Since upgrading my system, I've heard that Polk Audio is the way to go for speakers.
Re. sub: I'd see what the previous model Impreza guys are doing, since their cars should be more similar to yours than the 2012+ imprezas.
soobie doo is offline   Reply With Quote
Old 05-09-2013, 10:18 AM   #17967
tspunk
Member#: 345444
2013 Impreza 5-door
I figured i might have turned it off before it could settle back into position, but i went in the car, turned it on again, and turned it off. It still rests too high...
Old 05-09-2013, 10:20 AM   #17968
tspunk
Member#: 345444
2013 Impreza 5-door
Thanks, I'll try that.
Old 05-09-2013, 11:26 AM   #17969
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Has anyone installed upgraded endlinks, such as those from Kartboy? I have read elsewhere on wrx/sti forums that they dramatically improve handling, and I'm a bit tentative to put a bigger sway bar on the back without them. Losing an endlink in a turn isn't really my idea of safe. Do you fellows think upgraded endlinks will help much with a 19mm sway (which I have) or should I throw a strut tower brace on there and call it a day?
Dirt Bringer is offline   Reply With Quote
Old 05-09-2013, 11:32 AM   #17970
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I don't believe that a 19mm RSB requires stronger end links to operate reliably. But then again, I think the Impreza's unibody is stiff enough to not benefit from a tower brace either.
So don't listen to me because I'm not giving you the fun answers you're looking for!
sgoldste01 is offline   Reply With Quote
Old 05-09-2013, 11:55 AM   #17971
Dirt Bringer
Member#: 340297
Ice Silver
It's not quite so much stronger as stiffer that I'm curious about. I've heard that aftermarket endlinks are significantly stiffer.
Old 05-09-2013, 12:40 PM   #17972
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Originally Posted by Angelus911 View Post
Just noticed a small crack in my front bumper, lower left hand side on the bottom. It isn't huge, but now that I noticed it, I'm going to see it all of the time now
Is there anything I can do to minimize the appearance of the crack? I'll try to get a picture of it for a better look.
Edit: here's the crack:
Originally Posted by Paradis View Post
Oh god... I have exactly the same crack !! Will post picture tomorrow
Originally Posted by flyboy1100 View Post
They work great, you should probably stop drill the crack too so it doesn't spread further. Then clean up the hairline crack well and hit it with the touch up paint.
I have used a few of them over the years and never had one fail, 3+ on the jetta and 4+ on my Buick (stupid parking burms)
I have the exact same crack too!!! Tried to get it looked at as warranty issue as I never ran anything over or scraped it but no such luck. They (Subaru dealer) quoted me $650 to replace. NO WAY!!!
I figured I'd duct tape from behind & use some epoxy. Glad to hear there's a kit for this. @Flyboy do you just drill a larger hole at the very end of the crack & that stops it from cracking further?
SleepNMnky is offline   Reply With Quote
Old 05-09-2013, 01:36 PM   #17973
Angelus911
Member#: 89967
2012 Impreza Sport
^this must have just happened as I changed my oil about a month ago and would have noticed that while crawling underneath my car. I haven't hit anything either, which sucks, and that's what I thought Subaru would say. If it was larger I would probably try my luck at my dealer, but it doesn't seem worth the hassle right now.
Angelus911 is offline   Reply With Quote
Old 05-09-2013, 02:05 PM   #17974
myrt1987
Member#: 323103
2012 Limited 2.0i
This happened to me during the winter and it left a nice crack in my bumper. I didnt hit anything, unless it was a hit and run in my neighborhood. The crack is above the fog light void.
Old 05-09-2013, 02:22 PM   #17975
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
you just need to drill a hole slightly larger than the crack, just to make sure it doesn't progress any further
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
