Old 07-07-2013, 05:47 PM   #18401
n00b on demand
Member#: 158355
2012 Sport 5MT
Originally Posted by Rememo View Post
Nope... that's just a blank that's installed if you don't have fog lamps.
You'll need #17.
thanks!
n00b on demand is offline   Reply With Quote
Old 07-08-2013, 12:04 PM   #18402
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Originally Posted by Reverend_ View Post
In case you've missed it, I've got writeups for both my SPT Catback Exhaust setup and my BRZ/Impreza Exhaust setup for my 5-Door Impreza. Both on my blog: All We'll Drive
SPT Setup
BRZ Setup
No video of the BRZ exhaust?
foghelmut is offline   Reply With Quote
Old 07-10-2013, 01:32 AM   #18403
Willy Wonka
Member#: 359995
2013 Impreza Sport
Venetian Red Pearl
So, I've been setting things on the passenger seat next to me every day since the day I bought my Impreza. I've set groceries and laundry on it. I set my iPad on it every single day.
For the first time today, I set my iPad on the seat and the seatbelt alarm went off. It wouldn't go off until I removed the iPad. I put it back and the alarm went off again. Same thing all day, to and from work.
What gives?
Willy Wonka is offline   Reply With Quote
Old 07-10-2013, 08:56 AM   #18404
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
What gives?
Interesting. I knew this was a common complaint with the early 2012 Imprezas, but I thought it was fixed in later 2012s and all 2013s.
Does anyone know if there is a TSB for this problem?
sgoldste01 is offline   Reply With Quote
Old 07-10-2013, 09:23 AM   #18405
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
I had the problem that my check SRS airbag system light would randomly turn on and off. I went to Subaru with the problem and it was a faulty passenger seat airbag sensor...what's next?
gregorz4 is offline   Reply With Quote
Old 07-10-2013, 10:03 AM   #18406
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
This is my work around for that problem.
The Official Subaru instructions, here they are:
1. Turn engine to ACC
2. Within 30 secs of ignition, clip/unclip seatbelt 20 times. Driver side only but works for both sides. Removes the red light and beeping.
SIA_worker is offline   Reply With Quote
Old 07-10-2013, 10:11 AM   #18407
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
What gives?
http://forums.nasioc.com/forums/show....php?t=2374065
There is a TSB for this.
Service Bulletin # 17-16-12
Pages: 8
Bulletin Description: If you encounter a customer complaint that the Air Bag Warning Light was illuminated and the Passenger Air Bag Indicator was OFF when the passenger seat was occupied, the Occupant Control Unit may need to be replaced. This bulletin is only applicable if DTC B1650, B1760 and/or B1761 are also stored in memory. A possible occupant action that may have resulted in this condition would be the use of an iPod or cell phone (plugged into the Accessory power outlet) by someone seated in the passenger seat when the ODS is On. Another cause may be a seated passenger touching a metal part of the vehicle that is electrically grounded (i.e. forward/rearward seat adjuster lever) when the ODS is On. The possibility of these conditions affecting the ODS is dependent upon the occupant’s personal capacitance. To reduce the possibility of the condition reoccurring, the Occupant Control Unit logic was modified to be less sensitive under those conditions.
That will remove the bell but the airbag is still armed when it doesn't need to be.
SleepNMnky is offline   Reply With Quote
Old 07-10-2013, 10:15 AM   #18408
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
True but I never have anyone in front seat that is too small for airbag.
Old 07-10-2013, 10:51 AM   #18409
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
My experience with the airbag issue:
I'd be driving around with a passenger, the passenger airbag indicator would switch to "off", and the airbag warning light on the dash would come on. Got that taken care of under warranty.
The new sensor is still very sensitive. If I just lightly rest my hand on the passenger seat while driving, it starts buzzing at me. Doesn't usually happen for groceries, though.
Another, unrelated seat issue that I've been having:
Around six weeks ago, I was driving home from work and felt something collapse a bit in the drivers seat. Got home, opened up the seat, found that a little metal clip along the right side of the seat had snapped. The clip had been holding the front and back parts of the frame together, if I recall correctly. It was about halfway up the seatback. Anyway, I got it fixed under warranty. Happened again yesterday, though. I'm just over 150 lbs, so there's no reason I should be breaking parts of the seat. Has anyone else had this happen?
soobie doo is offline   Reply With Quote
Old 07-10-2013, 11:11 AM   #18410
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Is anyone having seat problems with the leather seats? Or is it just the fabric?
I don't have any problems with mine that I know of, but maybe I just haven't noticed it.
Old 07-10-2013, 11:34 AM   #18411
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yes, but mine didn't break it just popped off
Old 07-10-2013, 11:34 AM   #18412
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
No problem here
Caocao is offline   Reply With Quote
Old 07-10-2013, 12:20 PM   #18413
Angelus911
Member#: 89967
2012 Impreza Sport
I'm at the dealership this am getting a couple things done: squeaky front drivers seat, remote start TSB, and the rear hatch latching issue.
I'll let you guys know if they find anything with the rear hatch, as I know others have had problems with it as well.
Angelus911 is offline   Reply With Quote
Old 07-10-2013, 12:27 PM   #18414
79letour
Member#: 302570
2013 XV
DGM!
Yes the rear hatch is finicky...
And yeah my 12' Imprexa's seat was broken. Squeaky and no support!
79letour is offline   Reply With Quote
Old 07-10-2013, 12:32 PM   #18415
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
If they tell you that there is no adjustment for the rear hatch, tell them to look at page EB-61 in the Service Manual!
Old 07-10-2013, 12:40 PM   #18416
Angelus911
Member#: 89967
2012 Impreza Sport
^Noted, thanks
Old 07-10-2013, 01:03 PM   #18417
nubsub
Member#: 313575
2012 Impreza 2.0i HB
weird thing has happened recently. on random occasions, when i get out of the seat, i hear some sort of squawk or sound...
not repeatable though...but is the start of something bigger/louder?
nubsub is offline   Reply With Quote
Old 07-10-2013, 01:06 PM   #18418
Angelus911
Member#: 89967
2012 Impreza Sport
So as others have had happen, the tech wasn't able to "hear" the squeak of the drivers seat. I said that there's a TSB out there for the fix, all though he wasn't totally certain of one. He said they would have to replace the whole seat back which is insane, maybe I should just forward this to him:
Service Bulletin #12-142-12
Pages: 3
Bulletin Description: This Bulletin provides a repair procedure to address a customer concern of a squeaking-type sound coming from the driver or passenger front seat back. The flat mat main support rods are covered in paper to prevent metal-to-metal contact with the backrest frame. However, if an edge on the backrest frame damages the paper, metal-to-metal contact will result, creating the squeak. Bushings will need to be installed to prevent the condition. This procedure eliminates the need to replace the backrest frame.
I really have my doubts that they'll do anything for the squeak
Old 07-10-2013, 01:33 PM   #18419
79letour
Member#: 302570
2013 XV
DGM!
They replaced my seatback. It didnt help. even adding bushings didnt help.
Somehow that seat just never felt at all right.
I wonder if zip-ties may be the last resort to keeping the springs where they are supposed to be.
Old 07-10-2013, 02:15 PM   #18420
Angelus911
Member#: 89967
2012 Impreza Sport
No luck on the squeaky seat. Tech heard it faintly and it's pretty loud to me. Maybe time for a new dealer. Nothing on the rear latch either, just a little extra lube and that's it
Old 07-10-2013, 03:40 PM   #18421
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
My dealership literally had to replace broken lumbar spring clips in my seatback 4 separate times! They finally smartened up and ordered the bushings for the seatback TSB. Its been about a month and so far, so good. Haven't experienced any more squeaks or broken clips since. (Knock on wood).
jr0bb5 is offline   Reply With Quote
Old 07-10-2013, 05:12 PM   #18422
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Get the parts and do it yourself that is what I did. 10.00 and some if my time
Old 07-10-2013, 06:21 PM   #18423
Angelus911
Member#: 89967
2012 Impreza Sport
Yup I will probably end up doing that. I think they're just being lazy because its really easy to hear the squeaking when in the car.
Old 07-12-2013, 06:27 PM   #18424
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
just added 0.4qts (13oz) to my car today to bring it back up to the "full" line (after oil change full line, so 3.16" above the dot). currently at 4400 miles on this interval. not worried about it I guess, but it did use probably 7-8oz over my trip this week to Kansas where it was 100+ every day! I checked it before I left and I was at the full dot, and before adding oil was 1/4" below, not bad for 1700 miles and those temps!. I 100% blame the temps in this case, but I have another 2500+ mile trip planned in 3 weeks and I am undecided if i will change the oil before or after the trip so that is why I added oil.
also can't decide what kind of oil I want to go with, I'm not a big fan of Amsoil OE, it does seem to use a little bit more than when I was using Signature, but Signature is hard to justify unless I am going to an extended interval which I don't know if i really want to do that when still under the warranty, even with UOA's to prove the oil is doing good. I'm not worried, it is just the freak chance of what if....
so Amsoil XL or Signature, when I used XL before it was still breaking in so I don't think i gave it a fair evaluation, maybe I will try that again and next time I order oil (6-7months) I will get Signature again.
Old 07-12-2013, 06:54 PM   #18425
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Are you happy about your oil consuming impreza? It seems as though at the moment your content about it and acting as its a normal function of the car, but what if it gets worse over time? Will you change how you feel about it as it gets worse or keep thinking it's normal? I don't mean to attack you or anything, just wondering why it doesn't seem to phase you at all that you have to add oil while others do not.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
