Old 07-12-2013, 08:02 PM   #18426
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by gregorz4 View Post
Are you happy about your oil consuming impreza? It seems as though at the moment your content about it and acting as its a normal function of the car, but what if it gets worse over time? Will you change how you feel about it as it gets worse or keep thinking it's normal? I don't mean to attack you or anything, just wondering why it doesn't seem to phase you at all that you have to add oil while others do not.
because my car is consuming at 1qt per 11,000 miles, i feel that is perfectly normal, some oil has to get used otherwise not everything gets lubricated. I'm coming up on 25,000 miles and after my next trip will be at or above 28,000. At this point I'm really not too worried. in fact now that I think about it about 6-8 months ago I was using oil at about 1qt/7-8000 miles so my consumption has actually improved, all my UOA's show that my engine is perfectly healthy. I for sure based upon UOA's saw the engine still breaking in through 14,000 miles
our Jetta with 130,000 has used 1qt/3000 miles from the day we got it (28,000 miles). we just continue to add oil because it is very mechanically sound otherwise and a decent car.
Old 07-12-2013, 10:58 PM   #18427
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by flyboy1100 View Post
just added 0.4qts (13oz) to my car today to bring it back up to the "full" line (after oil change full line, so 3.16" above the dot). currently at 4400 miles on this interval. not worried about it I guess, but it did use probably 7-8oz over my trip this week to Kansas where it was 100+ every day! I checked it before I left and I was at the full dot, and before adding oil was 1/4" below, not bad for 1700 miles and those temps!. I 100% blame the temps in this case, but I have another 2500+ mile trip planned in 3 weeks and I am undecided if i will change the oil before or after the trip so that is why I added oil.
also can't decide what kind of oil I want to go with, I'm not a big fan of Amsoil OE, it does seem to use a little bit more than when I was using Signature, but Signature is hard to justify unless I am going to an extended interval which I don't know if i really want to do that when still under the warranty, even with UOA's to prove the oil is doing good. I'm not worried, it is just the freak chance of what if....
so Amsoil XL or Signature, when I used XL before it was still breaking in so I don't think i gave it a fair evaluation, maybe I will try that again and next time I order oil (6-7months) I will get Signature again.
i have 3 qts of OE left, so I ordered 3 more quarts of that, will do 1 more change will OE before my upcoming trip. after that I will do 2 changes with XL, maybe on an 8500-10000 interval.
Old 07-13-2013, 05:20 AM   #18428
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
so wheels are in, coilovers are in...still waiting for my lateral arms to adjust camber...still need to go lower aswell but waiting for my guards to be rolled!!
let me know your thoughts...and yesss what a stance it'll have
Untitled by Dijm8, on Flickr
Dijm8 is offline   Reply With Quote
Old 07-13-2013, 09:49 AM   #18429
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
^^Is it normal/acceptable to have the sidewall of the tire flexed out like that?
sgoldste01 is offline   Reply With Quote
Old 07-13-2013, 09:52 AM   #18430
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
also can't decide what kind of oil I want to go with, I'm not a big fan of Amsoil OE...
I'm in the process as I'm typing this of draining out Amsoil OE, after which I will fill with Pennsoil Platinum. I'm not making the switch because I was unhappy with OE. It's simply that the Pennsoil is easier and cheaper to buy at Walmart, it's often on sale, and I've read good reviews of it.
Time to go pour in the Pennsoil....
Old 07-13-2013, 10:32 AM   #18431
LuckyNYC
Member#: 72812
2013 Impreza Sport
Ventian Red Pearl
No, although it's a popular trend people are following to get the widest possible wheel under their car without rubbing.
LuckyNYC is offline   Reply With Quote
Old 07-13-2013, 10:49 AM   #18432
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Don't forget to adjust the camber so it looks like it will fly away to space
gregorz4 is offline   Reply With Quote
Old 07-13-2013, 11:10 AM   #18433
WStrembitsky
Member#: 323877
2012 Impreza Limited
Is there any benefit to having rims that are wider than the tires? I would only want to get wider rims in order to add wider tires, making the rims wider than the tires just for the sake of having wider rims makes no sense to me.
WStrembitsky is offline   Reply With Quote
Old 07-13-2013, 11:31 AM   #18434
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Hmmm. I'm not a fan. I don't like it cosmetically, and I have to believe that it stresses the tire in ways the tire engineers didn't intend.
Old 07-13-2013, 02:29 PM   #18435
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I can't see any reputable tire shop doing that.
Commander Keen is offline   Reply With Quote
Old 07-13-2013, 02:57 PM   #18436
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Don't forget to put oil filler cap back on..........
What a mess.....
Old 07-13-2013, 08:57 PM   #18437
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
What a mess.....
I'll bet. Yes, I always go through a mental check before I start the car (drain plug, new filter, new oil, dip stick in, filler cap on, etc.).
Old 07-13-2013, 10:48 PM   #18438
Zeeper
Member#: 299286
2015 WRX CVT
that is one reason I do my own changes, my parents brought their (then) almost new Toyota Sienna to the dealer and had an oil change done, the tech forgot to put the filler cap back in place...
the smoke stopped them on their drive home, and the mess under the hood on a practically brand new engine was not appreciated, to say the least.
Zeeper is offline   Reply With Quote
Old 07-13-2013, 11:11 PM   #18439
Vjaramillo
Member#: 359666
2013 Impreza limited
Ice silver
It's a trend/style that tuners use to slam their cars as low as possible and have the widest possible rim.
Vjaramillo is offline   Reply With Quote
Old 07-13-2013, 11:14 PM   #18440
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It was when I was adding oil the other day, i forgot to put it back on because i got distracted for an hour doing other things, when i came back i only checked the level to ensure it was good and then closed the hood
all the oil i added (13oz) is what appears to be what was exhausted when i downshifted leaving the interstate after a 39 mile drive, it was only the smell that made me go "huh, thats not right"
needless to say a can of foaming engine degreaser and a pay and spray car wash and the engine compartment looks brand new again....
need my new oil to get here so i can change it
Old 07-14-2013, 12:08 AM   #18441
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
As someone who has never been a form over function kind of guy, I do not approve. But to each his or her own.
Old 07-14-2013, 09:58 AM   #18442
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
Agreed. Screwing up the ride, handling, and safety characteristics for the sake of aesthetics does not sound like a good idea. But then, I hear the modification market is pretty profitable.
hemophilic is offline   Reply With Quote
Old 07-14-2013, 11:48 AM   #18443
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I think there is a difference stretching front tires a little for clearance, as some higher end cars come a little stretched on front. Then there is putting 10's or 12's on a tire designed for an 8" wheel. It's a good idea for paddles on your sand rail, but not for a normal passenger car IMO- but to each their own.
G2Spfld is offline   Reply With Quote
Old 07-14-2013, 01:56 PM   #18444
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
Has anyone debadged their car as of yet? I did not see where anyone posted. I want to remove them all from the back for a clean look.
swede978 is offline   Reply With Quote
Old 07-14-2013, 02:16 PM   #18445
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
Yeah there's a few threads on debadging
Caocao is offline   Reply With Quote
Old 07-14-2013, 03:15 PM   #18446
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
They stick out alot
subaru222 is offline   Reply With Quote
Old 07-14-2013, 03:54 PM   #18447
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
I have not seen one, thanks
Old 07-14-2013, 05:20 PM   #18448
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
Old 07-15-2013, 03:02 AM   #18449
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Default Front License Plate Mount
Where are people getting side mount brackets for the impreza 2012 2.0 at? are they all 70 to 80 bucks?
i assume to get the side mount, you'll need to install via tow hook? sturdy? does it rattle etc for those who have those installed?
ive seen the perrin and grimmspeed ones but not sure if they will fit since they dont say 2012+ Impreza 2.0 will fit...they mainly address the WRX and STI like every freaking aftermarket part ive tried looking for the car but can't find.
im still pissed my dealer drilled the plates into the bumper rather than using the OEM license plate holes smh.
Blackmamba24kb is offline   Reply With Quote
Old 07-16-2013, 12:16 AM   #18450
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
Delete
scoutisimo is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
