Old 08-05-2013, 07:17 PM   #18626
garamas
Member#: 169194
04 STI
all those cars have modified hubs to get crazy camber most have setups like this
for anyone running any wheel larger then a 8.5 the car will camber enough to fit a 9.5 with out having to get camber plates/adj LCA's
but theres no way u can run 0 camber with a 9.5 wheel so thats why his car sits like that
garamas is offline   Reply With Quote
Old 08-05-2013, 10:52 PM   #18627
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
I used to run -3.5 degrees of camber in the front on my STI when I was autocrossing it. The aggressive camber really gave good turn in response and the contact patch was larger when the wheel was turned.
ST Eye is offline   Reply With Quote
Old 08-06-2013, 01:10 AM   #18628
Vjaramillo
Member#: 359666
2013 Impreza limited
Ice silver
Hey Dijma...I was thinking of doing the same thing for the roof. Black carbon fiber wrap but wasn't sure how it would look like. What are your thoughts on carbon wrapping the boot, roof and hood. Anyone have any thoughts.
Vjaramillo is offline   Reply With Quote
Old 08-06-2013, 08:44 AM   #18629
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
I prefer wood grain wrap.
foghelmut is offline   Reply With Quote
Old 08-06-2013, 09:29 AM   #18630
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Default Spring Ride Quality Swap
So someone recently confirmed that our Impreza shares struts with the 08 series WRX, such that springs and struts from that specific series are interchangeable. I was looking at stiffening the ride up slightly, as it feels a bit too soft and comfort oriented for my tastes. Does anyone know the spring rate on the stock springs and the 08 WRX springs? I was wondering if swapping out for WRX springs might improve the ride somewhat. I also heard that swapping springs shortens strut life. Is that because the ride height is lowered or because the springs overdrive the struts?
Dirt Bringer is offline   Reply With Quote
Old 08-06-2013, 11:23 AM   #18631
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
only reason i wanna carbon wrap my roof is to match the front lip, i think either way, its going to look good..hopefully next month ill have it done, (cost around $4-500 here in Australia for just the roof)
Dijm8 is offline   Reply With Quote
Old 08-06-2013, 07:04 PM   #18632
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I'm wrapping an impreza sport for the business. Thinking about doing the full 3M Carbon Wrap then add business logo. That way its cool looking and when I cycle cars every few years I can unwrap it for nice clean paint for the sale. I wanted to know if anyone here has experience with the full 3M wrap
G2Spfld is offline   Reply With Quote
Old 08-07-2013, 05:33 PM   #18633
n00b on demand
Member#: 158355
2012 Sport 5MT
So off and on for the past month sometimes while braking my Abs, traction light, and hill holder assist light all come on at the same time and stay on until i restart the car. Whats going on? Car performs totally normal while lights are on. I usually will stop...restart and the lights go away until the next time i press on the brakes.
n00b on demand is offline   Reply With Quote
Old 08-07-2013, 07:13 PM   #18634
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
No idea, but I'd guess there's a problem with one of your wheel speed sensors or the computer that controls the brakes for those functions. You probably oughtta just take it into the dealer. But next time it happens, try seeing if the hill holder still functions. Or the ABS and traction control, if you're on a loose surface and/or feeling adventurous.
soobie doo is offline   Reply With Quote
Old 08-07-2013, 10:11 PM   #18635
n00b on demand
Member#: 158355
2012 Sport 5MT
will do. Its so finicky...cant get it to happen whenever i want...just happens randomly. Ive noticed that when it does happen its when i brake hard.
Old 08-08-2013, 08:12 AM   #18636
sharco
Member#: 334052
04 STI
Recently sold my 2012 Impreza, if anyone is looking for roof racks, factory subwoofer, all weather trunk mat, or a 2011 STI 19mm rear sway bar feel free to PM me.
link to thread
sharco is offline   Reply With Quote
Old 08-10-2013, 09:43 PM   #18637
KickPaintz
Member#: 363043
link to thread
How much for the racks
KickPaintz is offline   Reply With Quote
Old 08-11-2013, 02:04 AM   #18638
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
some pics from over the weekend
subi stance port adel by Dijm8, on Flickr
subi stance port adel 2 by Dijm8, on Flickr
subi stance port adel 3 by Dijm8, on Flickr
subi stance port adel 4 by Dijm8, on Flickr
Old 08-11-2013, 02:18 AM   #18639
garamas
Member#: 169194
04 STI
looks good man needs more low tho
Old 08-11-2013, 02:19 AM   #18640
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
going for a service end of the month, so it'll get a touch more lower then
Old 08-11-2013, 12:23 PM   #18641
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
You've blown a fuse. It's on the right (separate) side of the main fuse block in the dash. I think fifth from the bottom. 7.5 amp fuse. It's the fuse you disable to turn off VDC.
apexracer is offline   Reply With Quote
Old 08-11-2013, 12:31 PM   #18642
apexracer
Member#: 257754
Camilla Red Pearl
I cut a ring connector and filed it to match as much as I could to the fuse. Better Option is the GTC fuse connector These are the lights that come on when you flip the switch and apply the brake. You also lose cruise control, but you don't need it anyway when this is activated. Inline fuse, one end to fuse slot, other side to switch (RED). All black wire is straight from the switch to the fuse slot. Left is inline fuse wire, right side is straight wire to switch. Doesn't matter what sides you use by the way. This is the switch, I'd recommend just a plain switch or some OEM subaru switch you could pop in. The light function doesn't work like you'd want it to. If I grounded the switch the light would come on when I pressed the brake (pointless).
Old 08-11-2013, 03:59 PM   #18643
garamas
Member#: 169194
04 STI
Sorry I must have missed something but what does the wiring you did there do for the car??
Old 08-11-2013, 04:17 PM   #18644
apexracer
Member#: 257754
Camilla Red Pearl
. It was a reply to the guy with the lights going off on his dash. There's a pic in there that shows the location of said fuse. As well, it's a DIY post on how to disable vdc with fuse bypass switch.
Old 08-11-2013, 05:18 PM   #18645
garamas
Member#: 169194
04 STI
ohh nice ok i was thinking something else...
is there a write up to enable the foglights to be on with driving lights?
Old 08-11-2013, 08:20 PM   #18646
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
link to thread
PMed u
ronjr8102 is offline   Reply With Quote
Old 08-13-2013, 08:05 AM   #18647
foghelmut
Member#: 328414
2012 Impreza SP 5MT
Last night, I filled up my tank. The fuel gauge didn't fill up. I turned the car off and on several times. This morning, I started the car and the fuel gauge was full. I dropped it off at the dealer for a separate check engine light, and the service department guy said that it was a normal complaint but wasn't an issue. Uhhhh???? What?
Old 08-13-2013, 08:16 AM   #18648
79letour
Member#: 302570
2013 XV
DGM!
did you leave the key in the ignition switch while pumping gas?
79letour is offline   Reply With Quote
Old 08-13-2013, 08:24 AM   #18649
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Or more specifically, did you leave the key in the ignition with the engine off but the key in the RUN position with all of the dashboard lights lit?
Simply leaving the key in the ignition while pumping gas but with the dashboard powered off is normal and certainly not a problem.
sgoldste01 is offline   Reply With Quote
Old 08-13-2013, 09:00 AM   #18650
foghelmut
Member#: 328414
2012 Impreza SP 5MT
I turn the car fully off with the key still in when its being filled. I live in NJ and we are all dumb babies here who aren't allowed to pump our own gas.
I started it up, and the fuel gauge had only one bar. Then I turned it off, and started it again, and it was still listing as empty. The fuel light on and everything. I was late for my softball game, so I just drove there. We had a double header, so my car sat in the parking lot for 3 hours turned off.
When I left, the fuel gauge had bumped up from 1 bar to 2 bars. I drove home. When I started it this morning, all of the bars were full.
The service guy said it was a "common complaint" and that it had to do with the sensors needing time to reset themselves, which sounds really weird, and that I shouldn't worry about it.
So either they really don't think it's a big deal, or they don't know how to fix it, or they're trying not to have to do work under warranty.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
