Old 08-13-2013, 10:48 AM   #18651
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Originally Posted by foghelmut View Post
I turn the car fully off with the key still in when its being filled. I live in NJ and we are all dumb babies here who aren't allowed to pump our own gas.
I started it up, and the fuel gauge had only one bar. Then I turned it off, and started it again, and it was still listing as empty. The fuel light on and everything. I was late for my softball game, so I just drove there. We had a double header, so my car sat in the parking lot for 3 hours turned off.
When I left, the fuel gauge had bumped up from 1 bar to 2 bars. I drove home. When I started it this morning, all of the bars were full.
The service guy said it was a "common complaint" and that it had to do with the sensors needing time to reset themselves, which sounds really weird, and that I shouldn't worry about it.
So either they really don't think it's a big deal, or they don't know how to fix it, or they're trying not to have to do work under warranty.
The only time that this happened to me is when I turned my key to the ACC position from OFF while fueling up.
jay25RS is offline   Reply With Quote
Old 08-13-2013, 04:11 PM   #18652
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Hanging out at dealer, hoping they at least clean my a/c since it stinks.
Complaints:
1. Weak, hardly can keep up when 90+ even with tinted Windows and recirc mode on.
2. Stinks
flyboy1100 is online now   Reply With Quote
Old 08-13-2013, 04:50 PM   #18653
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Complaints:
2. Stinks
Warranty doesn't cover odors I guess, so I am buying the kit and bringing it home.
They also said the air bring output on fan 2 w/ recirc on is 41f, and the minimum spec per Subaru is 52f
Old 08-13-2013, 04:50 PM   #18654
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
In 90+, I have to have the AC fan on at least 3, after 20 minutes I can go down to 2 sometimes. These cars are greenhouses.
foghelmut is offline   Reply With Quote
Old 08-13-2013, 04:55 PM   #18655
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
That sounds about right. On my last roadtrip I hadn't even noticed the temp rose from 77 to 94 over about 30 minutes until I saw the temp display. But that was after about 8 hours of driving. 1 with recirc was more than adequate.
It just seems on the short trips (less than 30min) I have problems.
Oh well I will get over it
Old 08-13-2013, 05:13 PM   #18656
nubsub
Member#: 313575
2012 Impreza 2.0i HB
i'm slowly learning that maybe i should have reconsidered my thought on have a dark interior car, not to mention the DGM paint not helping either.
are you in Premium Sport? how many fan speeds do you have?
i have many (8?) on the Limited and the first 4 don't do much if the car has been sitting in the sun. but i do agree: for all cars i've owned, there is no problem keeping up with hot weather if it starts and stays cool. the problem is if you let it bake in the sun and then try to cool it off.
my strategy which always works is to keep all the windows rolled down initially to flush out that hot air that has accumulated and wait until i feel cold air coming through the vents using "non-recirc" mode at max fan. then, i close the windows and after a little while, hit the recirc button to get the full max cooling effect. it still takes a while though (10-15min until its comfortable and i can back off the fan), but i have had that work on a 100+ oF day after the car had been sitting for several hours.
nubsub is offline   Reply With Quote
Old 08-13-2013, 06:25 PM   #18657
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I see best performance with the fan on 2 and recirculation mode. Speeds 3 and 4 move more air, but the vent temps start to rise.
Mine used to stink. Try changing the cabin filter to something that will resist mold. Also avoid running the A/C with fresh air mode. I never use the defog mode for this reason. Running the A/C with recirculation mode does just as well.
Commander Keen is offline   Reply With Quote
Old 08-13-2013, 07:25 PM   #18658
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have a new cabin filter, that isn't the problem. The smell only comes when ac is enabled.
I bought the Subaru ac cleaner kit and will do it tomorrow when I rotate my tires as you need the front off the ground to really access the evap drain.
And I have a sport premium dgm w/ black interior, 4 fan speeds
I also have the Subaru windshield visor and use it when I park in the sun, it helps, but still takes a while to get the residual heat out.
Old 08-14-2013, 09:09 AM   #18659
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
What were the wiper sizes again? 24 & 16?
My car is at home so I can't just go measure it...
Old 08-14-2013, 09:26 AM   #18660
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
You actually want 26 and 16. 24 will work, but 26 fits and will give you more wiping coverage.
sgoldste01 is offline   Reply With Quote
Old 08-14-2013, 10:21 AM   #18661
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Thanks. I'm gong to try Goodyear blades
Old 08-14-2013, 11:09 AM   #18662
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
This is the blade I'm currently running:
http://www.amazon.com/gp/product/B007TG7IJY/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1http://www.amazon.com/gp/product/B007TG7IJY/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1
Disregard Amazon's product compatibility database, which says the 26" blade doesn't fit on our Imprezas.
Old 08-14-2013, 11:56 AM   #18663
lumpy
Member#: 28410
2012 Impreza Sport
I used this on my Baja. It was a piece of cake to do and it worked well.
lumpy is offline   Reply With Quote
Old 08-14-2013, 12:21 PM   #18664
79letour
Member#: 302570
2013 XV
DGM!
I will be picking up one of these down the road. I use the ac a lot. Usually on 4, then after ten mins or so down to 2.
my Impreza had a very musty smellimg ac system since it was practically new.
So far so good with the XV. Still smells new. This car has an extra
dank new car smell to it. I do love the new car smell. Its addictive.
79letour is offline   Reply With Quote
Old 08-14-2013, 01:08 PM   #18665
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I learned 4 things this morning......
1. Do NOT use entire can, it will flood out everything and leak all over your carpet
2. It smells like Resolve carpet cleaner and those areas of my carpet are now very clean.
And for those who complain the vents are loud on high fan settings..
3. The fan itself moves a lot of air, and when on the highest settings it is loud. It also dries the carpet nicely when removed from housing to dry off (I'm hoping the actual motor didn't get wet, doesn't appear to have)
4. Fan removal/installation is very easy in this car
Old 08-14-2013, 01:27 PM   #18666
79letour
Member#: 302570
2013 XV
DGM!
my fan only makes whining/whistling noise on 3. odd.
Good thing 4 and 2 are where its at.
Old 08-14-2013, 01:54 PM   #18667
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
sorry for the lines on the first pic, the camera did it and i don't know why, didn't notice it until it was on the computer
and what came out of the evap, this stuff went in perfectly clear and came out like this, and this is only after 1.3 years of use/29,000 miles
so far, it smells much better, and I will replace the cabin filter tomorrow too, it is dusty, but no mildew/mold i can see on it.
Old 08-14-2013, 02:05 PM   #18668
79letour
Member#: 302570
2013 XV
DGM!
nice post! thanks man!
Old 08-14-2013, 02:18 PM   #18669
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
flyboy, product? price? level of difficulty involved?
Old 08-14-2013, 02:31 PM   #18670
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
And link to where you got it from!
Xafen is offline   Reply With Quote
Old 08-14-2013, 03:12 PM   #18671
LGA2011
Member#: 321173
You can always go at the dealer & only change the Teflon.
LGA2011 is offline   Reply With Quote
Old 08-14-2013, 03:26 PM   #18672
fistv
Member#: 350063
2013 Impreza sport
I always leave my front windows cracked when I park in the morning at work, just a 1/2 inch but it's enough to let the super heated stuff out.
fistv is offline   Reply With Quote
Old 08-14-2013, 03:56 PM   #18673
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Complaints:
2. Stinks
1. I think my Impreza Sport has a great A/C system and is icy cold. I thought the same about my STI compared to my '06 WRX and my Impreza is even more powerful than the STI's.
2. I've used the 1Z Einszett Klima Cleaner A/C odor and Bacteria cleaner on my 1998 Outback that had a funky smell to it. This fixed the problem and left behind a pleasant apple scent! http://www.detailersdomain.com/1Z-ei...aner_p_78.html
Old 08-14-2013, 04:07 PM   #18674
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
SOA868V9315, 19.95 + tax at my local dealer. it is hazmat so AFAIK none of the online sellers will ship this one. MAKE SURE YOU GET THE HOSE! the larger can come exactly as in the picture, so w/o the hose i don't know how you would realistically spray this stuff
Difficulty? 1.5/10 as long as you only spray 1/2 the can, let it drain, then spray the other 1/2. if you spray it all at once and then have to remove the blower I would say 2/10.
the only thing i did other than what the directions on the can say to do is pull the drain tube out of the clip and spray from the top of the engine bay. otherwise follow the directions
and to disable the compressor just unclip the single wire on top of it
Old 08-14-2013, 04:09 PM   #18675
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i already had them replaced under warranty, they are just as crappy as before no way i would pay the nearly 30-40.00 price for the refills
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
