Old 09-23-2013, 07:00 PM   #19001
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Angelus911 View Post
I think inspecting it entails checking all the pipes and tubes for leaks etc
Green would still be bad ..
Old 09-24-2013, 04:23 PM   #19002
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
For anyone who has painted their OEM grille, question..
What is the suggested way of doing this? Not the actual painting, I'm fine on that. But do you guys mask it off or can you actually remove the grille and/or center "wings" to paint? If so, any brief run down? I haven't really looked at it too closely, but I was considering doing it on Thursday.. I was thinking of painting the center bar "wings" in a textured matte black to match the rest of the grille bars. The car is silver, so I'm not doing the grille surround, only the center bar. Wasn't sure if you could remove them on the car or if you had to remove the grille first or what. Any help would be great. Thanks!
averagewhiteboy is offline   Reply With Quote
Old 09-24-2013, 04:29 PM   #19003
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
This will show you how to remove the grill (shows how to put in a mesh grill, but it does have the removal part). I'd probably have to take a look at the back of the grill to see if the chrome pieces are removable. I'm sure it wouldn't be too hard to mask it off.
http://techinfo.subaru.com/proxy/724...010fj000xx.PDF
VegasSubie is offline   Reply With Quote
Old 09-24-2013, 04:36 PM   #19004
06SE
Member#: 158925
12' Sport LTD
MBP
Or this thread with actual pictures will also help show you how to remove the grill.
http://forums.nasioc.com/forums/showthread.php?t=2448363
The painted wings on the 12' grill are definitely removeable - a couple of screws hold them on.
06SE is offline   Reply With Quote
Old 09-24-2013, 04:47 PM   #19005
79letour
Member#: 302570
2013 XV
DGM!
Or you can plasti dip it. Its really easy.
79letour is offline   Reply With Quote
Old 09-24-2013, 04:58 PM   #19006
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Perfect. Thanks guys!
And yes, a lot of guys do Plastidip, but I'm not a fan.. Looking for a more permanent solution. : )
Pics after completion! I noticed I've only ever put up one set of pics. lol
Old 09-24-2013, 06:48 PM   #19007
CLL_OBP
Member#: 310435
12 Sp Limited
M1 EP 0W20 102,450 miles
Default Here's another picture!
I removed the grille and this is what I used. I'd say it's permanent. I got about 8 coats out of it. Started on a Saturday morning, put it back together Sunday evening.
http://www.rustoleum.com/product-cat...-enamel-spray/
CLL_OBP is offline   Reply With Quote
Old 09-24-2013, 07:39 PM   #19008
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
That is exactly the finish I am looking for. Just something to match the grille trim behind the wings. Did you use any primer or clear?
I painted my H logos on my Si I had. They looked great at first. The rear was fine, but the front one eventually started getting tiny chips in it from road debris.. Trying to prevent that..
Old 09-24-2013, 08:38 PM   #19009
CLL_OBP
Member#: 310435
12 Sp Limited
It's held up great over a year now. I believe the back of the can said it was clip resistant too but don't quote me on that. No primer or clear, just a little bit at a time, steady and even. I have a propane torch and I watched this video to prep, especially the wings. I was extra cautious not to melt the damn thing, lol. It turned out nice
Old 09-24-2013, 09:52 PM   #19010
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Perfect. Thanks for the tip! I'm planning on doing this on Thu now..
Old 09-24-2013, 11:41 PM   #19011
Vjaramillo
Member#: 359666
2013 Impreza limited
Ice silver
You have to remove the bumper to replace the grille? Wow. That's nuts.
Vjaramillo is offline   Reply With Quote
Old 09-25-2013, 12:05 AM   #19012
CLL_OBP
Member#: 310435
12 Sp Limited
No, you do not have to remove the bumper.
Old 09-25-2013, 12:41 AM   #19013
bradze
Member#: 103208
2011 Outback
Azurite Blue
has anyone painted the inside of the headlights? i wanna make my wife's car look cooler.
bradze is offline   Reply With Quote
Old 09-25-2013, 05:40 AM   #19014
CLL_OBP
Member#: 310435
12 Sp Limited
Check this out. It's not painting but it's opening up the lens if you wanted to. http://forums.nasioc.com/forums/show....php?t=2454725
Old 09-25-2013, 08:17 AM   #19015
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
No. Takes a few minutes to remove from above.
TRSAndrew is offline   Reply With Quote
Old 09-25-2013, 09:39 AM   #19016
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
So I had to clean my a/c evap again, I just did it like 5 weeks ago. This time for the heck of it I pulled on the drain tube and about 1.5" more hose came out. I pulled the grommet off and saw there is quite a bit of space up there, I couldn't see where it actually attached though. I'm thinking maybe since 1.5" of the hose was stuffed up there it isn't draining properly. A lot more nasty stuff came out this time compared to last time which supports my not draining theory.
So a few observations for people considering this, or maybe those who have done it.
1. Check the hose is out ask the way.
2. 1/2 can of the foam is too much at one time. Yet again I had too pull the fan and clean it out. Argh.
3. I don't want to do this again. I have been making sure to not let the a/c run until the car shutdown to hopefully help dry it out, but I don't think it was draining correctly.
Old 09-25-2013, 04:26 PM   #19017
bradze
Member#: 103208
2011 Outback
Azurite Blue
yeah thanks, i found that thread a minute after i posted this. but ill pay someone to do it, i would **** it up. i paid for my outback lights to get painted, i just wanna see what it looks like. the chrome in the top section needs to be black.
Old 09-25-2013, 05:02 PM   #19018
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Does anyone know off hand the procedure to disable the DRL and/or auto-on headlights? I thought I remembered there being a way.. I wasn't sure if it was the same as the 08+ WRX's or what..
Old 09-25-2013, 05:19 PM   #19019
79letour
Member#: 302570
2013 XV
DGM!
Originally Posted by flyboy1100 View Post
Green would be bad. .
How do you figure. Both my brand-new subarus came with green "dex". Its bluish green but very easily green. What color is your coolant, man?
Old 09-25-2013, 05:42 PM   #19020
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
A little and I mean little searching on often will provide a quick answer and write ups. To make it quick, put on ramp remove splash guard on passenger side below fog light. Look for aluminum heat diffuser block with a brown and grey connection and unplug. Tape off connection to seal from elements and your done. To turn fogs into drl wire tap green wire you disconnected to the black and white wire on fog light right below and now you have fogs acting as drl.
SIA_worker is offline   Reply With Quote
Old 09-25-2013, 05:46 PM   #19021
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
So I had to clean my a/c evap again, I just did it like 5 weeks ago. This time for the heck of it I pulled on the drain tube and about 1.5" more hose came out. I pulled the grommet off and saw there is quite a bit of space up there, I couldn't see where it actually attached though. I'm thinking maybe since 1.5" of the hose was stuffed up there it isn't draining properly. A lot more nasty stuff came out this time compared to last time which supports my not draining theory. So a few observations for people considering this, or maybe those who have done it. 1. Check the hose is out ask the way. 2. 1/2 can of the foam is too much at one time. Yet again I had too pull the fan and clean it out. Argh. 3. I don't want to do this again. I have been making sure to not let the a/c run until the car shutdown to hopefully help dry it out, but I don't think it was draining correctly.
I can't say for sure but on the legacy and outback that I build at the factory the drain hose is attached to the hvac right up against the firewall and on passenger side behind the tunnel. As for being able to pull more hose out that sound possible because about 2 inches run down the back of the firewall and then out the floor. We are not allowed to push it all the way thru because it can create a pinch point especially if a passenger has their feet on the carpet in that area. May be fine to pull thru to clean but I would strongly recommend pushing back up before finishing. Just my two cents
Old 09-25-2013, 05:47 PM   #19022
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
Badass. Didn't know you could do such a thing.
Old 09-25-2013, 05:50 PM   #19023
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Blue, very deep blue color. I know because I have a gallon on the shelf from when i drained the block to install my block heater.
I was surprised it was that deep of a blue because looking in the overflow bottle it does have a green tint, but it isn't green at all
Old 09-25-2013, 05:51 PM   #19024
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Since fogs are in parallel they both run from just the one side being powered. Took me 10 min and I love the look.
Old 09-25-2013, 05:55 PM   #19025
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm not sure exactly what you mean, because once the drain is through the grommet, it runs another 10" or so before the end of the hose.
I just cleaned the system (which on a 16 month old car is ridiculous imho), and when I did it again yesterday, more nasty stuff came out than the first time I cleaned it. That tells me it isn't draining properly allowing mold/mildew to grow.
I plan to test it in the garage and see how well it drains now, and if for some reason it doesn't drain well then I will push that little bit back in
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
