Old 10-10-2013, 09:36 PM   #19126
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by goregasm View Post
How long do they last? H9s generally have pretty good output but also **** life.
currently at 17 months/32,000 miles on mine. was going to get another set soon, they haven't burnt out, but if you want output you have to sacrifice long life. they are rated at 500 hours, i am probably getting close to that
Amazon.com: Philips H9 Standard Headlight Bulb, Pack of 1: AutomotiveAmazon.com: Philips H9 Standard Headlight Bulb, Pack of 1: Automotive
Old 10-10-2013, 09:59 PM   #19127
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Video Link: http://www.amazon.com/Philips-Standard-Headlight-Bulb-Pack/dp/B00480KOP4/ref=lh_ni_t?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Well I think I'll do that when my current ones burn out. Thanks!
goregasm is offline   Reply With Quote
Old 10-10-2013, 10:23 PM   #19128
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Price is too good on Amazon so I ordered another set, will change them out before it gets too cold as they need a little modification (removing 1 extra tab inside the socket)
Old 10-10-2013, 11:00 PM   #19129
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
How long was it sitting unlocked? I think after some time the alarm arms regardless of whether it's unlocked or not
Sat for several hours. Normally this doesn't happen. I usually lock all doors with the lock button and then unlock just the drivers door to exit. Leaving all doors and hatch locked but not the drivers door.
JustaImpreza is offline   Reply With Quote
Old 10-10-2013, 11:01 PM   #19130
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
Originally Posted by CLL_OBP View Post
That's supposed to happen. When you lock the door, the car shaped red light to the lower left of the speedometer starts flashing fast for 30 seconds. Alarm is set. It will go off if you unlock the door from the inside and then open it. A la somebody trying to steal the car.
You're right but that's not what I did. When I returned to my car several hours later the alarm went off when I opened my door.
Old 10-11-2013, 12:00 AM   #19131
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
Originally Posted by Alan777 View Post
Hey guys I got approved for a '13 sport limited today, going to pick it up next week. I've been reading through some of the threads, and was curious about any common issues/upgrades you guys have that make a difference.
Hello, Alan. I thought I'd jump in here since nobody had responded to you yet. The vast majority of us here are very happy with our cars.
Issues:
-Don't get too concerned about low fuel economy for the first couple thousand miles while the car's breaking in.
-Some of our cars burn a bit of oil, so make sure you check the level regularly. If you burn over a quart per 1200 miles, Subaru will buy you a new engine. One quart per 1200 miles is an awful lot of oil consumption, which it's very unlikely that you'll achieve.
-Front seats sometimes get squeaky. You can get it fixed under warranty, or there's an easy DIY fix that worked well for me and plenty of other people.
Upgrades:
-STI 19mm rear sway bar is very popular. Your car will have a 16mm rear sway bar, so it won't benefit quite as much as those of us with base models that have no rear sway bar. If you're a spirited driver and the understeer bothers you, this is an easy way to address it.
-The stock tires are very noisy, especially once they get a bit worn. Some people aren't satisfied with their performance in snow. Continental DWS are a popular replacement.
soobie doo is offline   Reply With Quote
Old 10-11-2013, 03:48 AM   #19132
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Just to clarify, is that the 08+ STI rear sway bar? Anything else needed, or just the bar it's self? I have a buddy with an 08+ STI that may have his lying around..
averagewhiteboy is offline   Reply With Quote
Old 10-11-2013, 09:24 AM   #19133
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
Yes, 08+ STI rear sway bar. There's probably about a dozen threads about it on here. If you have a premium or limited model, then I think you need the sway bar and new bushings to fit the larger bar. And a metric socket wrench set. If you have a base model, you need sway bar, bushings, clamps, and endlinks.
Old 10-11-2013, 09:25 AM   #19134
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Issues:
Upgrades:
Id agree with this, but just like to add the disclaimer that the VAST majority do not burn oil. Also the entire car is a little squeaky/chattery but not overwhelming.
Those are probably the best mods too.
Old 10-11-2013, 09:36 AM   #19135
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
PUP 5W30 92,050 miles
Like I said earlier, you set the alarm. The only way to do that is pressing the lock button on the key or pressing the lock button on the door with it open.
See for yourself. Open the driver door, press lock and watch the car shaped light start blinking fast. You have 30 seconds to do whatever (like manually unlock the driver door for some odd reason), close the door and wait. When you open the door without pressing unlock first, the alarm will sound.
CLL_OBP is offline   Reply With Quote
Old 10-11-2013, 12:24 PM   #19136
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Good look on the bar. That's what I thought, but wasn't sure.
And to add, the only "things" I have found with my 13 Sport CVT is: the CVT takes a little longer than a standard auto to move from P to R/D, there's a good amount of wind noise on the highway, stock tires blow at STOPPING in snow, the stock radio is "meh", and sometimes you need to close your hatch twice before it shuts.
Again, nothing major. Just saying..
Old 10-11-2013, 01:41 PM   #19137
webster354
Member#: 343343
2014 Impreza 5dr Ltd
Are there any options other than an extremely expensive and time consuming HID retrofit to increase low beam headlight output? The h11s just don't do it. I need to drive at night at 55+mph regularly and sometimes there's cars coming just far enough apart that I can't use my high beams.
Edit: keeping in mind that REAL HIRs are long gone. The new generation ones probably aren't legal anyway and don't use the technology that reflects infrared to increase the filament temperature and therefore output.
The Canadian limited model comes with HIDs, although I have no idea how much it would cost for parts or the entire housing...
webster354 is offline   Reply With Quote
Old 10-11-2013, 02:15 PM   #19138
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by ans2k View Post
so far, 9 months on mine.
+1 on the H11 to H9 mod. I've been running them for about 10 months now. No burnouts. It's a cheap mod and greatly increases the output to where I'm satisfied (and I'm picky about headlight output)
Angelus911 is offline   Reply With Quote
Old 10-11-2013, 02:18 PM   #19139
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
was honestly the first thing I did IIRC, i didn't have the stock lights in for more than 1 month, probably not even 2 weeks
Old 10-11-2013, 03:36 PM   #19140
Rpresa
Member#: 341172
2012 GP
Canada here, and I have a Sport model which is not the HID model- but I looked into exactly what you're asking, the cost of a swap to the factory HID housings, ballasts and wiring. The guy behind the parts counter (I don't rank him too high in the knowledge category) said that each housing was just shy of 1000$, and then a full electronics swap was needed, as in the engine harness needed to be replaced as well. I'm realllllly skeptical of that, but IF it is true, then the cost certainly isn't worth the benefit.
I hope he was very wrong anyway.
Rpresa is offline   Reply With Quote
Old 10-11-2013, 03:37 PM   #19141
Rpresa
Member#: 341172
2012 GP
flyboy, you're talking about your foglights, correct? I remember seeing that you had switched out your factory fog lamps to the glass-lens outback lamps and connectors, right?
Old 10-11-2013, 03:43 PM   #19142
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
I have the H9 in my low beams and the HIR 9011 in the high beams. The high beams are probably too bright now. Street signs become ultra reflective and are blinding.
The stock tires are complete garbage in rain and snow. I have 28k miles on them, and I'm basically plowing around with understeer in the rain. You have to drive like a grandma to not. Dry weather they're great though, and you can drive like as big of an ******* as you want.
foghelmut is offline   Reply With Quote
Old 10-11-2013, 04:34 PM   #19143
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No, you can put h9s in the low beam. I do also have the h11 outback foglights.
Old 10-11-2013, 04:35 PM   #19144
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
The stock 9005s are bright enough when used with h9 low beams. I get a lot of what you describe with my setup
Old 10-11-2013, 04:42 PM   #19145
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
I have the same setup. H9 lows, 9005 highs and h11 fogs. I thought about going with HIR high beams, but it seems a little overkill. I would love to do a HID retrofit someday when I have the extra cash.
jr0bb5 is offline   Reply With Quote
Old 10-11-2013, 06:54 PM   #19146
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
There's an answer. I thought I locked with the door closed then unlocked before exiting. I obviously had the door open.
And that's not what you originally said.
Old 10-11-2013, 07:07 PM   #19147
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
Yeah, you're right and I noticed that too afterwards but didn't get the chance to fix it.
Old 10-11-2013, 07:11 PM   #19148
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Once my steelies come in, I am trading Ryan from Moore my Rota's for their Moore axleback system. Pretty stoked.
Does anyone want to buy my stock muffler delete with turndown? haha
Old 10-11-2013, 07:40 PM   #19149
ans2k
Member#: 315631
2012 Impreza Sport
ehh. i might be interested
ans2k is offline   Reply With Quote
Old 10-11-2013, 11:02 PM   #19150
photoman-mark
Member#: 370737
2013 Impreza Base 5D
Dark Gray
Default Rear Sway Bar Question
So I just found out that my base 13 impreza does not come with a RSB, looking to add a stock 16mm or WRX 19mm. I know I need added parts for the instal is this all I need aside from the sway bar and bushings? http://www.ebay.com/itm/Impreza-Whit...e54b4f&vxp=mtr
photoman-mark is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
