Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 10-12-2013, 12:11 AM   #19151
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
SIA Worker is first in line, but you're now second. haha
And if I go STI rear sway, my Sport bar will be for grabs too..
averagewhiteboy is offline   Reply With Quote
Old 10-12-2013, 08:35 AM   #19152
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by photoman-mark View Post
So I just found out that my base 13 impreza does not come with a RSB, looking to add a stock 16mm or WRX 19mm. I know I need added parts for the instal is this all I need aside from the sway bar and bushings? http://www.ebay.com/itm/Impreza-Whit...e54b4f&vxp=mtr
When I scroll down on that page and enter "2013 Impreza" into the drop-down fields, it says that those parts are not compatible.
However, yes, in general, you will need parts similar to those to complete the installation. What you're still missing is the clamps that mount over the rubber bushings (and the associated bolts to secure the clamps).
If I were you, I'd probably just install Subaru parts rather than aftermarket, using one of the online Subaru part supplier web sites. But that's just me.
Hope this helps.
sgoldste01 is offline   Reply With Quote
Old 10-12-2013, 09:51 AM   #19153
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
If you have a reasonable price, pm me if you do that.
goregasm is offline   Reply With Quote
Old 10-12-2013, 10:31 AM   #19154
photoman-mark
Member#: 370737
2013 Impreza Base 5D
Dark Gray
Hope this helps.
it does, I looked it up and found all the OEM parts but the hardware at https://www.subarugenuineparts.com/oe_parts_cat.html
Where can I find the hardware
If anybody is selling a OEM 19mm or 16mm for cheap let me know
photoman-mark is offline   Reply With Quote
Old 10-12-2013, 11:53 AM   #19155
Rememo
Member#: 340728
2013 Impreza 5-spd
You can have the 16mm off of my 2013 Impreza for the cost of shipping.
It's just the sway bar and the rubber bushings. No bolts, or clamps are included. IM me if you're interested.
Rememo is offline   Reply With Quote
Old 10-12-2013, 12:42 PM   #19156
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i could be tempted to sell mine too, it is just collecting dust
Old 10-12-2013, 12:56 PM   #19157
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
If everyone is offering up there 16mm RSB I might as well join the party, but I'm in Canada so pm me if you would like the 16mm RSB with bushings.
gregorz4 is offline   Reply With Quote
Old 10-13-2013, 05:35 PM   #19158
Vjaramillo
Member#: 359666
2013 Impreza limited
Ice silver
I have one off my 2913 limited with less that 4k miles on it. I'm in California. Let me know if you'd be interested. Vince
Vjaramillo is offline   Reply With Quote
Old 10-13-2013, 05:47 PM   #19159
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
So I just changed my oil and yet again, adding in 5 qts alone leaves me .4-.5qt low. Odd. I'm warming the car up, running to the store in my other car and will check again when I return, everything should have drained back down by the time I return. The spot I check the oil in is for sure level, I even verified it with a 4ft level.
Old 10-13-2013, 07:44 PM   #19160
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
The car holds 5.3 quarts, Agent Scully. You didn't uncover some big oil gnome conspiracy with Obama.
On another note, is anyone else consuming coolant very slightly? Say every 3 months I'm a cm below the low line with the car completely cold.
Old 10-13-2013, 08:25 PM   #19161
G2Spfld
Member#: 354284
2013 Imp Sport CVT
My coolant is low. Never noticed but assumed it was full when new. Just noticed it was low before last trip I was on.
G2Spfld is offline   Reply With Quote
Old 10-13-2013, 09:12 PM   #19162
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
they actually lowered the capacity to 5.1, I was just hoping to not have to crack another bottle. Oh well.
On the plus side I did drain out about 5qts
Old 10-13-2013, 09:25 PM   #19163
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Well hopefully the added few tenths of a quart keep the oil cleaner longer than say a car with 4.6qts
Old 10-13-2013, 09:44 PM   #19164
nubsub
Member#: 313575
2012 Impreza 2.0i HB
i noted after a few months of ownership (2-3k) that i smelled coolant on occasion after stopping the car in the garage. inspection didn't suggest anything about at 8 months and about 7k, i had the car in for warranty work where i noted that the "resting level" of the coolant dropped from high to close to low.
they checked a lot of things out and found nothing (the service advisor was useless, the but the tech did due diligence with pressure checking, inspecting the heater core, etc) but didn't see any leaks. he topped it off, and now after another 8k, i have seen a much more modest change in level (maybe 1/4-1/3 between the lines and i still on occasion smell a hint of coolant.)
i'm going to keep an eagle eye on it through my 3 year warranty (i'm at 1.5 years now) at 15k.
nubsub is offline   Reply With Quote
Old 10-13-2013, 10:01 PM   #19165
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
You know the coolant is supposed to be at the low line when the car is cold right? It shouldn't be at the full line when it's not running and cold.
Old 10-13-2013, 10:03 PM   #19166
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Good to know. That'll make it like my Tahoe then. The stamping in the head casting seeps thru the casting and it will smell a little when u first start up. It takes a while to notice any loss but I have had light on with it. The imp was almost in the low mark before my last 1500 mile trip and I figured I'd see the light come on, but after returning I checked and it's still at same spot. So I figure it'll have a slow seep like the Tahoe.
Old 10-13-2013, 10:30 PM   #19167
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
5qts, 12oz brought me up to the full dot exactly. It just doesn't make sense to me, normally that would put me 1/4"over full.
I guess I fill find out tomorrow after a 35 mile round trip excursion
Old 10-13-2013, 11:40 PM   #19168
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Maybe there are oil gnomes stealing your oil?
Old 10-14-2013, 12:01 AM   #19169
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
possible.
Old 10-14-2013, 04:13 PM   #19170
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Well after my little trip, oil is back to 3/16" over full, so next time I'm just trying 5 even and will go for a drive first before adding more
Old 10-14-2013, 08:35 PM   #19171
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Could you theoretically lift an Impreza 3-4" and have a crosstrek for about $5000 less?
Old 10-14-2013, 08:52 PM   #19172
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I think the price delta between an Impreza and XV is more like $1200 or $1800 or something like that. So it wouldn't be $5k less.
Old 10-14-2013, 08:56 PM   #19173
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
I got a little over 1 1/2 for a lot less I love it. Looks great and is functional. Don't think u could do much more without throwing drivetrain, suspension and brake likes way out of wack
SIA_worker is offline   Reply With Quote
Old 10-14-2013, 09:02 PM   #19174
whatzone
Member#: 357817
Originally Posted by EnterTheDragon View Post
Anyone have the 30k service? Spark plugs or no?
I believe you have to replace the Spark Plugs every 100,000 thousand
whatzone is offline   Reply With Quote
Old 10-14-2013, 09:03 PM   #19175
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
60,000
Look at your manuals people
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
