Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 10-19-2013, 05:16 PM   #19226
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
Originally Posted by flyboy1100 View Post
Adds energy to the airflow around the mirrors which should cut down on the wind noise produced by them
If i understand correctly, the headlights are already shaped to do that.
MCarp22 is offline   Reply With Quote
Old 10-19-2013, 05:18 PM   #19227
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Finally got the front footwells sound proofed with mlv. I only did the vertical portion, and it made quite a bit of difference, wish I had been motivated enough 6 months ago to do it when I did the doors, hatch, hatch floor. Oh well
Next step is to make some vortex generators for the mirrors
Just ordered the stuff to do doors myself. No pictures of the footwell install? Very curious.
CalTech87 is offline   Reply With Quote
Old 10-19-2013, 08:50 PM   #19228
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No, not much to take a picture of, just cut to fit and put inbetween carpet and the existing sound dampening.
I could have done all the way to the seats, but I didn't want to figure out the carpet retainer in the door sills, and I figured most of the noise would be coming from the front/vertical portion
flyboy1100 is online now   Reply With Quote
Old 10-20-2013, 10:26 AM   #19229
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
No, not much to take a picture of, just cut to fit and put inbetween carpet and the existing sound dampening. I could have done all the way to the seats, but I didn't want to figure out the carpet retainer in the door sills, and I figured most of the noise would be coming from the front/vertical portion
Did the sound deadening make a noticeable difference?
gregorz4 is offline   Reply With Quote
Old 10-20-2013, 01:31 PM   #19230
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Everything I did, yes.
Old 10-20-2013, 08:43 PM   #19231
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
My big pet peeve with this car is the wind noise. It always sounds like a door isn't completely shut. lol
averagewhiteboy is offline   Reply With Quote
Old 10-20-2013, 10:59 PM   #19232
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It is either the roof rails and the mirrors. The door seals don't seem any worse than our jetta
Old 10-21-2013, 03:01 AM   #19233
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
It's entirely possible it's the mirrors. They're large, and jut out from the car pretty good. haha
Old 10-21-2013, 12:13 PM   #19234
TJMA
Member#: 304306
2012 Impreza-premium
Ice Silver
I do not notice any wind noise with my 2012 Impreza sedan. It s a lot of road noise inside the car.
TJMA is offline   Reply With Quote
Old 10-21-2013, 12:21 PM   #19235
imcausinmadrukis
Member#: 318978
Has anyone found an easier way to remove the fog light surround trim to access the foglight yet than from going under the bumper? I'm replacing the bulbs again in a week or so, and would like to not have to lay on the ground again..
Yeah you can pop out the black plastic cover of the fog lights without scratching anything with this kit. I can take off the cover in 10 seconds and have access to my fogs lights. This is also the best way to add film protection to your fog lights to prevent the glass from chipping from rocks.
7 pc Nylon Pry Bar Set Automotive Dash Panel Plastic Molding Trim Remover Tool
http://www.ebay.com/itm/7-pc-Nylon-P...item5658d0b14a
They sell these on ebay.
imcausinmadrukis is offline   Reply With Quote
Old 10-21-2013, 12:38 PM   #19236
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
when you have added as much MLV as i have, it all becomes wind noise
Old 10-21-2013, 01:10 PM   #19237
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
How many pounds of MLV do you think you've added? Also, what brand did you use? Thinking about adding some sound deadening.
jr0bb5 is online now   Reply With Quote
Old 10-21-2013, 09:32 PM   #19238
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
4 sheets of rammatt, 60-70sq ft of mlv. Probably added about 70-80lbs total
Old 10-21-2013, 09:34 PM   #19239
jr0bb5
Member#: 315353
5MT OBP/DGM
Wow, hope it really makes a difference for adding that much weight.
Old 10-21-2013, 09:47 PM   #19240
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
MLV is 1lb/sq ft
Old 10-22-2013, 04:07 PM   #19241
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Question.
Has anyone with a non-Crosstrek Impreza switched to some sort of all-terrain tire? Similar to the Geolanders found on the Crosstrek? I was wondering if there was some sort of "multi-use" tire similar to those that was offered in an Impreza-friendly 17" size. Like a 205/50 or similar. I am currently on FRS/BRZ wheels with the stock 215/45's they come with, but am swapping them out for my 215/45 Contiwinters soon. So looking into it for when I remove them. It'd be nice to have a good multi-purpose tire instead of swapping between all-seasons that are meh in the snow, and snows.
Another question.
To anyone who has used risers in their stock suspension, what spacer size did you use in your rear to even out the height with the front height? Considering just lifting the rear of mine to match the front for now until I put coilovers on. I know a few guys have used the saggy-butt spacers on here..
Old 10-22-2013, 04:08 PM   #19242
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Check out my tread on my lift kit
3/8" to even out for me, but I do have a hitch installed that made mine sag just a bit more.
SIA_worker is offline   Reply With Quote
Old 10-22-2013, 05:05 PM   #19243
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I have your picture saved, it looks good that way. That was achieved with only a 3/8 lift?
Old 10-22-2013, 05:10 PM   #19244
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Ah, that picture comparison is with the 3/8 spacer AND a 1" lift. Would you say the 3/8 rear spacers alone would even out the stock front gap?
Old 10-22-2013, 05:11 PM   #19245
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Essentially, if you lift the car up and have the e-brake on when you drop the car down and it stays up, that's about where I want it. It evens the rear out with the front until you remove the e-brake and the car sets in the rear.
Old 10-22-2013, 05:18 PM   #19246
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
I would say go 3/8. It is level with mine BUT I have a hitch on back adding 80 extra pounds that makes it sag a bit more than stock. If you did 3/8 you may be a tad higher in back not noticeable I would guess.
Old 10-22-2013, 06:22 PM   #19247
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I'd way rather be slightly higher in the back than the front. This reverse rake is just weird. lol
Old 10-22-2013, 06:29 PM   #19248
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
my car sits perfectly level. it looks like the front is higher only if you look at the fenders, but if you look at the rocker panel it is level.
Old 10-22-2013, 08:17 PM   #19249
jr0bb5
Member#: 315353
5MT OBP/DGM
I'll have to find a flat spot and measure from the rocker panel to the ground on both ends to see if mine is actually level. As it sits now, the rear looks considerably lower than the front.
Old 10-22-2013, 08:24 PM   #19250
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i haven't ever actually measured it, maybe I will go do that now (my garage floor is level)
edit: i stand corrected, the back is about 3/8" lower than the front, but i do have some stuff in the back right now, so maybe under normal conditions 1/4" lower. not enough for me to care about
edit2: definitely more work than I want if you have to go through all this work
http://www.subaruforester.org/vbulle...nstall-128157/
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
