Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 11-07-2013, 03:21 PM   #19476
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by Zeeper View Post
You have to be the first person in the world who recommends avoiding the defog/defrost mode when trying to defog/defrost the windows.
Well, it has to be a small crowd, anyway.
Agreed. I've been following the process I described for the last 34 years with great success.
sgoldste01 is offline   Reply With Quote
Old 11-07-2013, 04:28 PM   #19477
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Directing air to the windshield would be a good idea if it didn't also run your A/C in the dead of winter, and blow freezing air over the heater core on a cold engine.
Blowing recirculated, non air-conditioned air on the windshield would be great, but our cars don't allow it.
Commander Keen is offline   Reply With Quote
Old 11-07-2013, 04:42 PM   #19478
Zeeper
Member#: 299286
2015 WRX CVT
Probably because the defogging aspect of using the AC to dehumidify the air overrides the fact that it uses outside air to clear the windshield. In any case, that is built into most modern cars, so you would be hard pressed to avoid it -- and the vents directing air to the windshield do work better than using the dash vents for that purpose.
I completely agree that letting the car warm up a bit before turning it on defrost is a good idea, 'cause otherwise you are just pushing cold air through the vents, and at the same time loading the engine unnecessarily with the AC compressor, before it has warmed up. I don't wait until the blue light goes off, but I do wait until warm air is available.
Zeeper is online now   Reply With Quote
Old 11-07-2013, 05:02 PM   #19479
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
My GSR'd CRX had no AC components in the car. It was nice being able to run the front de-fogger without the engine taking a strain on those soggy, humid evenings.
averagewhiteboy is offline   Reply With Quote
Old 11-07-2013, 05:45 PM   #19480
Commander Keen
Member#: 319157
In this scenario:
Originally Posted by goregasm
Anyone have any tips on how to keep frost off/clear frost off my car that's parked outside quickly in the morning? I hate to idle for 15 minutes until the coolant is warm enough to evaporate and clear the windshield.
...what I described works nicely. When you walk out to the car, the engine will be warmer, the interior will be warmer, and you'll have used less fuel than if you ran the defogger. The defogger is for removing humidity from the interior, so unless the inside of the windshield is iced over, don't bother.
The windshield only needs to be brought above freezing for the ice to slide off, which is easily done with a warm interior regardless of which vents you use. It's amazing how much faster the interior warms up when you're not running the A/C and pumping in winter air.
Old 11-07-2013, 07:46 PM   #19481
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Just installed the subaru remote start today. Only took 1hr 15min and cost $285 and $45 to get programmed. Much better than paying $600 for dealer to do!
SIA_worker is offline   Reply With Quote
Old 11-07-2013, 08:59 PM   #19482
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Could just do defrost & recirculation.....
Old 11-07-2013, 09:02 PM   #19483
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Oh, and the a/c clutch is literally one wire on top of the compressor, it would be very easy to add a switch in the cabin that would disconnect it, then you could run defrost w/o a/c engaged. I plan to do that in a few weeks
No codes or ill effects I have seen with the wire unplugged (required for evap cleaning)
Old 11-07-2013, 09:11 PM   #19484
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Found another thing my wagon likes to do today.. Mud trails.
Was driving through a local park this evening and found a side road/trail. Presumably for work trucks in the park. I followed it. After a building, the gravel part ended and the muddy trail kept going through the woods. I followed it. It was flat, so no incline or decline, but it handled the sloppy, deep-ish mud crazy well. Even on Turanza 215/45 touring tires. No hesitation. It rained like hell all last night into late morning today, so it was fresh. Probably a couple inches worth of soggy mud. Now to just get a taller side-wall set of tires and some Rally Armors. There was dried mud slung around the wheels, f/r fenders, and caked in the wheel wells when I got home. lol
I find something to love about my slow wagon everyday.
Old 11-07-2013, 10:26 PM   #19485
Zeeper
Member#: 299286
2015 WRX CVT
I think when the defog/defrost mode is selected the recirculation is disabled. Maybe it is different for cars with auto climate controls?
This discussion is now activating deja vu, as we already discussed the pros and cons of AC, Recirc. and how they work within the defrost mode, or not as the case may be.
Old 11-07-2013, 11:41 PM   #19486
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
true, i guess i will try it tomorrow morning.
like i said though i do plan to wire in a disconnect for the a/c clutch so I can run defrost mode w/o the compressor running. plan to just do a test first to see if it really works well that way or not.
Old 11-08-2013, 12:54 AM   #19487
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
just looked at wiring diagram, from what I can see the wire that goes to the compressor is the only one that goes to it, there is no way for the computer to know if it is actually egaged or not. I will be wiring up a disconnect switch in the near future for it
for my "fun" switch, i ordered a pack of 10 mini rockers for 3.95 total, and I will have 9 left over, so I might as well use one of them for this purpose
Old 11-08-2013, 01:20 AM   #19488
Commander Keen
Member#: 319157
Flyboy, you may want to include a freewheel diode or resistor to absorb the inductive kick of the compressor's clutch. Otherwise you may get some nasty high voltage arcing between the contacts on that switch.
If the computer really wanted to know, I'm sure it could measure draw on the clutch line, or monitor the pressure switches, but I doubt it cares much.
Old 11-08-2013, 02:35 AM   #19489
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I know it's been covered somewhere. Did a "search", and it brought me back to this thread.
Can someone do a quick synopsis of said "fun switch"? An appropriate link would also work..
Old 11-08-2013, 07:18 AM   #19490
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
A diode is a good idea, would I need 2? It is early I might need to think about that after some coffee
Old 11-08-2013, 09:04 AM   #19491
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
Originally Posted by ocellaris View Post
It is way more of a pain in the ass to put on and remove a car cover than it is to scrape windows. Did you just move to the Northeast? Scraping ice off a car is a regular thing
Depends on the thickness of the ice on the windshield. There are some mornings where it rained overnight and then froze as the cold front came through. Those are really sucky scraping mornings.
Car covers will help in that regard. The ice doesn't stick to the cover and breaks as you lift it.
It was about 60* yesterday and then sometime near sunset the rain stopped and a cold front came in. I started this morning finding beaded frozen moisture on the INSIDE of my window. Little droplets from condensation.
near the bottom center of my windshield. (from where my phone holder is attached to the window and down).
--kC
KC is offline   Reply With Quote
Old 11-08-2013, 12:19 PM   #19492
Commander Keen
Member#: 319157
You would need one. Cathode to the clutch line on the compressor side, and anode to ground.
When I get around to this, I think I'm going to attack it from the HVAC panel and free up the recirc function as well.
Old 11-08-2013, 01:53 PM   #19493
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i would like to do it that way, but I'm not sure how with the manual controls that I have. need to check the wiring diagrams more.
Old 11-08-2013, 02:30 PM   #19494
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
1qt spray bottle and put winter washer fluid, a little rubbing or denatured alcohol, a drop or 2 dish soap. Then just use a squeegee to clean off Windows
Always wondered about some kinda concoction. Thanks!
--kC
Old 11-08-2013, 03:26 PM   #19495
Angelus911
Member#: 89967
2012 Impreza Sport
--kC
I've had moisture build up on the inside before, but never had it freeze! I could see that happening if it rains one day, then turns a lot colder overnight
Angelus911 is offline   Reply With Quote
Old 11-08-2013, 05:55 PM   #19496
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Originally Posted by Angelus911 View Post
One question: Is there a way to pre-set the rear defrost so that it comes on with the remote start?
I know with my remote start and auto hvac the car senses the outside temp and turns on rear defrost, mirror and wiper defroster automatically. The light is not light up on knob but you can see the rear defrosting. Don't know if the manual hvac does this too. This is only for oem remote start. Aftermarket remote starts with the option for an extra channel can be programmed to do this too or crack windows in summer.
Old 11-08-2013, 06:47 PM   #19497
wuzin
Member#: 368795
2013 Impreza Premium
Dark Gray Metallic
SIA_worker, does your engine shut down automatically when you open the door?
wuzin is offline   Reply With Quote
Old 11-08-2013, 08:08 PM   #19498
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Yes it does ;(
Old 11-08-2013, 08:47 PM   #19499
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by SIA_worker View Post
Yes it does ;(
Worst part about the OEM remote start!! :/
jsteg is offline   Reply With Quote
Old 11-08-2013, 09:04 PM   #19500
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Yes but with coupon codes and getting it for $285 and $45 to program it's nice to retain factory simplicity. Single button aftermarket allow car to run but have to unlock with key because keyless buttons are disabled while engine is running and with factory you get auto defrost on rear, mirror, and wipers. Plus you get confirming that car started. Sure for price dealer charges go aftermarket, get longer range, added security feature, and ability to do much more but for the price I got I can't be happier.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
