Welcome to the North American Subaru Impreza Owners Club Friday April 24, 2015
Old 04-16-2014, 09:48 PM   #21201
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by USAFAndrei View Post
do you have a straight on shot and is that corners only?
Old 04-16-2014, 09:52 PM   #21202
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by flyboy1100 View Post
Here is a better pic of the new stance. In the pic I had 2 propane tanks in the hatch so +75lbs, gas is almost full. It is still sitting with a slight rake, without the tanks in the back the wheel well gap is pretty even looking
Overall alignment is really far off again, so after spacers you definitely need the alignment
AWB,
here is my pic. w/o the extra weight in the back there is a bit of rake if you look at the bottom of the car vs the ground and the wheel "gap" looks the same. I know it is really close, but it is still slightly more in the front, you can't tell though unless you actually measure, to the naked eye i can't even tell and I know it is different.
i used 3/4" spacer that I made myself, it is all in this thread, circa 11/23/13
Old 04-16-2014, 09:53 PM   #21203
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
The halogens look similar in color, just not as bright.
averagewhiteboy is offline   Reply With Quote
Old 04-16-2014, 09:55 PM   #21204
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
just yellow 194's?
Old 04-16-2014, 10:58 PM   #21205
LGA2011
Member#: 321173
I ditched the Yokohama 17" oem tires & changed for the 4 season Michelin Pilot sport A/S 3 same size as the oem 205/50R17. The car handling is totally different. That mild understeer is totally gone & it still cold outside.
It's feel soft when turning but it sure turn. Even the ride less rough like if I was running on those 15 inch steelies.
LGA2011 is offline   Reply With Quote
Old 04-16-2014, 11:31 PM   #21206
USAFAndrei
Member#: 352158
2012 Impreza
Metallic Grey
just yellow 194's?
Yea yellow 194/168's
USAFAndrei is offline   Reply With Quote
Old 04-16-2014, 11:48 PM   #21207
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Technically amber, but yes. lol
And would you be able to post up a close-ish pic of those 205/50's? Between good 205/50's or going to 225/45's. Currently on some 215/45 snows.
Looking into the Bridgestone 970's.
Old 04-17-2014, 07:07 AM   #21208
LGA2011
Member#: 321173
Michelin Pilot Sport A/S 3 205 50R17(Both bumper have been repainted, thus look a bit off at an angle)
The car look different.
Old 04-17-2014, 11:51 AM   #21209
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
That tire profile looks much better. Looks similar to my 215/45 snows with the wider contact patch. I just hated how round and "bubbly" the stocks were.
Old 04-17-2014, 01:21 PM   #21210
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Do they twist out?I was trying to figure that out but was focused primarily on foglights. Took a lot longer then expected (7 hours total) but the result is totally factory looking. If I wanted to just half ass it I could have been done in about 2, hours
Old 04-17-2014, 02:22 PM   #21211
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
You talking about the eyebrows?
Just take off the fender cover and use a long 1/4" slotted in the back of the socket to twist it off. Reaching in the fender is a little PITA, tho.
Tha Chakal is online now   Reply With Quote
Old 04-17-2014, 02:52 PM   #21212
LGA2011
Member#: 321173
Indeed, the sidewall look smaller with the Pilot Sport due to how it is made to protect the rim from the scratches with the extra rubber sticking out.
Since the rubber stick out, it come flush with the fender. In my province, I cannot have the tires sticking out of the fender even if it doesn't rub.
EDIT:
it look round because it is 205, at 215 it should look more square, but at the cost of fuel economy with more contact patch.
The Motegi MR119 make the tire profile much larger than it look. it looked very weird with the stock tire that I had to change it. My friend suggest me to lower the car, but would be unpractical for daily use.
Old 04-20-2014, 05:01 PM   #21213
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Similarly to how my 215/45/17 Conti snows are "wider" than the 215/45/17 tires that came on my FRS wheels.
Old 04-21-2014, 04:02 AM   #21214
MrLebreen
Member#: 344816
2012 Impreza 2.0i
What's the info on the front strut brace? Or any other suspension/handling setup
MrLebreen is offline   Reply With Quote
Old 04-21-2014, 06:14 AM   #21215
mini lan
Member#: 373776
MY14 Impreza GP7
Satin White Pearl
Default AVO DBW Throttle Controller
today i installed the AVO DBW Throttle Controller in my impreza 2.0i and noticed results for a cheap mod well worth it it gives you a more low end response when accelerating its suited for most subaru models with electronic throttle bodys and installation was easy took me about 20mins no drilling holes stripping wires etc just unplug and plug in and instructions were easy to read and setup the controller was easy to read from the instructions it has 3 Map options
Standard - if you want to leave it how it was
Power - has 9 selectable steps with increasingly aggressive throttle mapping
Ec mode has 7 selectable steps with increasingly milder throttle mapping. When the throttle pedal is below 30% operation, Ec mode provide a far more precise throttle map from 0%-30% throttle opening. However, if the throttle goes above 30%, it will switch over to Nor mode for safety reasons.
http://s1295.photobucket.com/user/on...tml?sort=3&o=3
for more information
http://www.avoturbo.com/index.php?op...ucts&Itemid=26
mini lan is online now   Reply With Quote
Old 04-21-2014, 08:23 AM   #21216
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by mini lan View Post
today i installed the AVO DBW Throttle Controller in my impreza 2.0i and noticed results for a cheap mod well worth it it gives you a more low end response when accelerating its suited for most subaru models with electronic throttle bodys and installation was easy took me about 20mins no drilling holes stripping wires etc just unplug and plug in and instructions were easy to read and setup the controller was easy to read from the instructions it has 3 Map options Standard - if you want to leave it how it was Power - has 9 selectable steps with increasingly aggressive throttle mapping Ec mode has 7 selectable steps with increasingly milder throttle mapping. When the throttle pedal is below 30% operation, Ec mode provide a far more precise throttle map from 0%-30% throttle opening. However, if the throttle goes above 30%, it will switch over to Nor mode for safety reasons. http://s1295.photobucket.com/user/on...tml?sort=3&o=3 for more information http://www.avoturbo.com/index.php?op...ucts&Itemid=26
Whew!! Reading that made me out of breath!!
jsteg is offline   Reply With Quote
Old 04-21-2014, 08:40 AM   #21217
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
How much did the throttle controller cost?
ronjr8102 is offline   Reply With Quote
Old 04-21-2014, 08:45 AM   #21218
emiliobadillio
Member#: 376596
2012 Impreza 2.0i
SWP Hatch 5MT
I don't know if I would consider this a "cheap mod" at $200 US, but I have been curious about the throttle improvements. I've seen many posts of people installing them in their 2011 and under imprezas and WRX's, but none of the new Impreza 2.0i vehicles. Could you please describe the differences a little more?
emiliobadillio is online now   Reply With Quote
Old 04-21-2014, 08:52 AM   #21219
mini lan
Member#: 373776
MY14 Impreza GP7
Satin White Pearl
its about 200usd and about the same in aus plus gst
Old 04-21-2014, 09:01 AM   #21220
mini lan
Member#: 373776
MY14 Impreza GP7
Satin White Pearl
when im saying "cheap mod" i should of said easy to 'DIY' mod for value for money like installing a pod filter/exhaust just like minor mods but easy to do and for differnces in the vehical cause ive only put it in today but having it on "standard" it was really sluggish on take off and low gear low revs around turns after working my way through the settings and putting it on Power = P09 which is the max setting it will go it was alot more throttle sensitive and around corners in a low gear it was quicker to rev out to the next gear the pic below is off the instructions i got of the % of the acceleration the middle line on the angle going upwards is the standard line the p09 is the power each line is differnt maps on the controller from p01 > p09 and the of3 is the lines from 0f1-0f3
Old 04-21-2014, 09:51 AM   #21221
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
My Impreza is a 2012 with a manual tranny and 26k miles. My observations are anecdotal, but here they are.
When I first bought the Impreza, I thought it was pretty weak and lacking in power. I've since decided that it's not nearly as weak as I thought it was. I'm not sure if it's because I've learned how to wring power out of the engine better (I did have to change my driving style after getting used to the low-end torque of my 2010 VW TDI), or if the engine is more punchy now that it's broken in (or, more likely, both).
Regardless, I don't have issues with the power like I did when the car was brand new.
I mention this only because I see that Mini Lan installed this mod on his brand new 2014 Impreza, and I'm wondering if he would have found this necessary had he given the engine more time to break in, and for him to learn the characteristics of the engine.
All I'm suggesting is that if you're unhappy with your Impreza's power when the car is brand new, perhaps you should give it some time before looking to modifications.
sgoldste01 is offline   Reply With Quote
Old 04-21-2014, 10:13 AM   #21222
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Yeah its a completely different engine above 4000 rpm.
foghelmut is offline   Reply With Quote
Old 04-21-2014, 10:25 AM   #21223
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
It looks like all this mod does is make the throttle more sensitive and less controllable. The last 60% of pedal travel on the Po9 curve controls the last 24% of throttle angle, and probably the last 10% of power delivery.
I'd rather have more control at lower power levels for smooth shifting and easy rev matching, but to each his own.
Commander Keen is offline   Reply With Quote
Old 04-21-2014, 12:22 PM   #21224
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I am glad you found this. I wont be able to get one for a couple months but this is something that would help me alot. I encounter alot of Traffic and the stop and go after 30k+ miles i still struggle getting a smooth start without slipping to clutch too much in the first gear.
Looking at the installation: does this plug into the OBD-II port?
auskip07 is offline   Reply With Quote
Old 04-21-2014, 12:26 PM   #21225
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I would guess that this mod might make it harder for you to get a smooth start, not easier. But I don't know for sure.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
