Old 02-08-2011, 06:03 PM   #1
nstm44
Member#: 255449
2002 Impreza TS 2.5
Default Mass state inspection... FAIL
so i have currently on my car an intake, uel headers, and axel back exhaust...
and i failed mass state inspection not for the exhaust, that was fine, but the "OBD readiness monitor" wasn't.......... ready i guess. and the reason is cuz me being me got a scan tool (not a cheap on either) and erased a code that i keep getting... cylinder 1234 misfire. how can i make it so that those codes dont come up and further more how do i get my car "ready"
btw its a 2002 Impreza 2.5TS, and i have gotten spark plugs, wires, headgaskets, timing belt, valve adjustment, battery, alternator, and full tune up and i still get the codes
thanks in advance guys
nstm44 is offline   Reply With Quote
Old 02-08-2011, 06:30 PM   #2
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
if it has a MAF, clean it. run better fuel, and try seafoam
ruckus racing is offline   Reply With Quote
Old 02-08-2011, 06:37 PM   #3
StarsofPleiades
Member#: 262258
1998 Legacy GT
Red
Also to reset the obd 2 drive monitor you need to drive like 300 miles of mixed highway and city driving after clearing the codes. At least thats what I was told when my moms car failed after I cleared the codes. That's why I got my car registered in Michigan, no inspection here. Yay college.
StarsofPleiades is offline   Reply With Quote
Old 02-08-2011, 06:37 PM   #4
nstm44
Member#: 255449
2002 Impreza TS 2.5
has a MAP sensor and i've tried the seafoam
Old 02-08-2011, 06:52 PM   #5
pheonix991
Member#: 154173
2006 STI
Your timing may be off if you have misfires.
pheonix991 is offline   Reply With Quote
Old 02-08-2011, 07:10 PM   #6
ascott13
Member#: 234966
2004 Baja Turbo
black/gunmetal
get a tactrix cable and use rom raider to force the readiness monitors to always be ready...
ascott13 is offline   Reply With Quote
Old 02-08-2011, 07:13 PM   #7
pheonix991
Member#: 154173
2006 STI
Or, fix the misfires...
Old 02-08-2011, 08:53 PM   #8
Ron89
Member#: 161671
2005 STi VF39
304/320 mustang dyno
My guess also..we get a ton of cars in that had T-Belts done with the cams a tooth off.
Ron89 is offline   Reply With Quote
Old 02-08-2011, 10:25 PM   #9
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Oh em gee, how many people actually read that it's a 2002? Tactrix doesn't work on anything older than 2005.
formula91 is offline   Reply With Quote
Old 02-08-2011, 11:11 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
If it has misfires, fix the damned misfires. That's not something you want to dick around with.
Old 02-08-2011, 11:14 PM   #11
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
EJ251 misfires are almost always ignition related when you don't have a lightweight flywheel. Change your plugs (use NGK coppers) and maybe your wires too. Odds are that will solve it.
BAN SUVS is offline   Reply With Quote
Old 02-09-2011, 12:08 AM   #12
nstm44
Member#: 255449
2002 Impreza TS 2.5
Timing is perfect on the dot 10 degrees which the ideal is 10 +- 8 and I changed the spark plugs and wires to NGK like 8 months ago...
Old 02-09-2011, 12:38 AM   #13
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Ron was asking about the timing belt, not ignition timing. Has that been changed recently?
Old 02-09-2011, 03:09 AM   #14
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
go somewhere more po-dunk, middle of nowhere
Old 02-09-2011, 06:04 AM   #15
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Does the 02 still have the head gasket problems?
KOJAK-02-WRX is offline   Reply With Quote
Old 02-09-2011, 11:13 AM   #16
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Misfires can be cause by a number of things, sounds like you've checked most of the easy ones. the only one i haven't heard yet was to check your Valve lash. Are you getting any other codes? I always have issues passing emissions, i have cams and a light weight flywheel so it's always battle. Here is the drive cycle you need to do to get all areas to be ready. I have yet to find a road where i can get this done in 12 mins but usually i just follow the basic idea and can get it in under 30 miles and it takes about 80 miles for my CEL to turn on. Also here in Utah we are allowed to have on area not ready and still pass. My cat and evap system sometimes take a while to go to ready so I'll drive around until one does and then hurry and get the test done.
aclver1 is offline   Reply With Quote
Old 02-10-2011, 05:52 PM   #17
nstm44
Member#: 255449
2002 Impreza TS 2.5
update today no codes but there was a p1137 that is still there but no light on...? head gaskets have been done 8 months ago and also t belt has been done the same time as well
Old 02-11-2011, 01:16 AM   #18
nstm44
Member#: 255449
2002 Impreza TS 2.5
Bump
Old 02-11-2011, 01:25 AM   #19
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Stored codes (code in memory, no CEL) usually won't fail you. Go go go!
Old 02-11-2011, 01:49 PM   #20
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Yes...
Mass State Inspection ami2fst4u New England Impreza Club Forum -- NESIC 5 09-03-2010 02:01 AM
Need help: NY state inspection failed ttatsumi Legacy Forum 21 09-14-2008 12:02 AM
Need help: NY state inspection Failed. ttatsumi Tri-State Area Forum 24 08-16-2008 07:34 PM
Mass State Inspection STiSURFER72 New England Impreza Club Forum -- NESIC 7 02-06-2007 06:50 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
