Old 02-09-2011, 12:53 AM   #1
rallyvovo
Member#: 167738
Default Clutch Issue - Help!
I believe my throwout bearing has been making noise - a little rattle with clutch out and then silence when in. Also, the other day the little clutch pedal helper spring broke (dont know that this is related)
Tonight I go to drive and it is VERY hard to select gears. They go but with some force, more than normal. Then comes a point where the car acts as if the clutch is engaged when the pedal is pressed. Turn car off. 15min later i go to hobble home in ghetto mode and start it in reverse and some gas. Then when i put clutch in to select 1st it seems like its back to fine. Drives home as it did before problem arose.
Once at home it did seem a little hard to select the gears again. Obviously there is an issue, but why would it go away briefly?
rallyvovo is offline   Reply With Quote
Old 02-09-2011, 12:03 PM   #2
rallyvovo
Member#: 167738
Nobody?
Old 02-09-2011, 12:20 PM   #3
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Yes I would say you need a clutch. The noise when the peddle is out is usually the throw-out bearing. Sounds like the bearing is on it's way out so the clutch is never fully released. The clutch plate will heat up and expand causing the whole system to react different. Let it cool and it will react different. Either way, fix it before you start taking out the synchros.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 02-09-2011, 02:08 PM   #4
rallyvovo
Member#: 167738
I appreciate it, thanks.
Need help with clutch issues notraceready Transmission (AT/MT) & Driveline 8 04-24-2008 12:34 AM
Need help with clutch issues notraceready Transmission (AT/MT) & Driveline 0 03-26-2008 08:46 AM
clutch engagement issue...help quick please 6lug Transmission (AT/MT) & Driveline 1 11-13-2006 04:20 AM
Help! Clutch issues on a 285hp 2003 WRX Balantz Transmission (AT/MT) & Driveline 24 12-25-2005 08:00 AM
HELP!!! more clutch issues...soooo mad! IMPREZAmike New England Impreza Club Forum -- NESIC 1 01-15-2001 12:58 AM
