Old 02-09-2011, 11:10 AM   #1
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Question Starting/stalling and rough idle issues
2003 Baja 2.5SOHC Manual Transmission 195k miles. Head gaskets, oil seals, spark plugs, timing belt, fuel filter, water pump, engine oil, oil filter all replaced about 5k miles ago.
This week I started experiencing problems starting the engine. The first day, teh car sat at work for 8 hours. Drove to work just fine and started up just fine that morning. After work, cold start, engine cranks but does not start. Gave it 30 seconds between each attempt. Lights and acc. all working and bright, so not a battery problem, and the engine cranks/turns over. After about 5 minutes, it starts up as if nothing is wrong. No CEL, no codes.
The next day, starts up perfectly first thing in the morning, starts up again that evening after work no problem. Got home, ate dinner, went to leave for my second job, engine not hot but still warm, engine feels like its going to stall but stays running and drives fine. Noticing on my way to work that the idle is fluctuating at stoplights but otherwise runs and drives fine. No CEL, no codes.
Next day starts up fine in the morning, but after picking up my son at daycare and then restarting the engine (still hot) it stalls completely, but starts up on the second attempt but will only stay running if I keep my foot on the gas. Once I get on the road it runs fine and doesnt need intervention to keep running at idle. Again, no CEL, no codes.
From the research I have done, I am thinking its the coil pack, fuel pump, or IACV. I recently cleaned the IACV (5k miles ago) and the plug wires were replaced last year.
I am out of ideas, and I know without a CEL or codes a mechanic is just going to be able to take guesses and throw parts at it. I'd rather try to diagnose it myself.
Thanks!!
Samirr76 is offline   Reply With Quote
Old 02-09-2011, 11:11 AM   #2
Samirr76
Member#: 4835
2003 Baja 5MT
Oh yeah it did it again this morning on a cold start. Stalled on the first attempt but was fine after restarting.
Old 02-09-2011, 11:53 AM   #3
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
I have a hunch, cheap part to replace. Camshaft posistion sensor.
T Wrex--OH is offline   Reply With Quote
Old 02-09-2011, 11:55 AM   #4
Samirr76
Member#: 4835
2003 Baja 5MT
I thought of that too...but why wouldnt it throw a CEL/DTC?
Old 02-09-2011, 09:02 PM   #5
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
I read it again and retract my previous statement. ha ha
Could be a vacuum leak.
Old 02-09-2011, 09:43 PM   #6
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Thanks!!
Then your mechanic sucks.
Kind of sounds like a fueling problem. Intermittently stuck injector maybe. Maybe a fuel pump. Things like this are tricky, especially when you don't have the car in front of you. Any shop worth its salt should be able to run some tests and figure it out. At the very least start heading in the right direction.
Wrencher86 is offline   Reply With Quote
Old 02-09-2011, 10:52 PM   #7
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
Here's straight out of the FSM for engine stalling during idling:
1) Idle air control solenoid valve
2) Mass air flow sensor
3) Intake manifold pressure sensor
4) Intake air temperature sensor
5) Ignition parts
6) Engine coolant temperature sensor
7) Crankshaft position sensor
8) Camshaft position sensor
9) Fuel injection parts
With #1 being the most likely, #9 being the least likely.
Hope this helps you!
Old 02-09-2011, 11:00 PM   #8
Samirr76
Member#: 4835
2003 Baja 5MT
Yeah im tired of guessing.....and im not a fan of throwing parts at a problem either. I'll swing by the repair shop. I am leaning towards some type of fueling problem too though. I thought a bad fuel pump would affect the engine at all times not just when starting. And a bad injector I would think would most certainly throw a misfire code/CEL.
Old 02-09-2011, 11:03 PM   #9
Samirr76
Member#: 4835
2003 Baja 5MT
Thanks T!
Old 02-11-2011, 11:38 AM   #10
Samirr76
Member#: 4835
2003 Baja 5MT
One thing I did not mention is that right before this issue began, I had filled up on gas about 30-40 miles prior, Sunoco 87 octane. Could a bad tank of gas cause stalling issues without and driveability issues or loss in MPG? So far the MPG has not changed, and currently at about 300 miles on the same tank.
stalling and rough idling issue nJDMmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-20-2008 12:46 PM
Rough idle issue solved via TSB sticky!!! Gregmatic Baja Forum 0 03-08-2006 12:49 AM
stumble on cold start with CIL rough idle Deity Normally Aspirated Powertrain 7 11-05-2004 03:44 PM
Hard starts and rough idle Brooke Legacy Forum 3 12-12-2003 08:00 PM
help/comments w/rough idle issues? Benjamin Tang Legacy Forum 14 10-01-2003 06:55 AM
