Welcome to the North American Subaru Impreza Owners Club Monday October 20, 2014
Old 02-09-2011, 12:00 PM   #1
gmullin
Member#: 271800
Default well i fail
i went to take my heads off my ej22 and the drivers side is stuck, the rear upper bolt broke just below the bolt head thats the good thing but it got corroed to the head so bad that it wont budge,i can get the othe side of the head halfway off the dowel pin and the bolt just flexes and dosent let go any ideas would be great
ive tried using a punch to shock the bolt loose,prying and broke 3 chissels now its soking in penerating oil.
gmullin is offline   Reply With Quote
Old 02-09-2011, 01:57 PM   #2
GEE-OTTO
Member#: 201277
2009 Legacy GT
LOOOOOONG pipe on the ratchet handle and let whatever happens happen
GEE-OTTO is offline   Reply With Quote
Old 02-09-2011, 02:44 PM   #3
gmullin
Member#: 271800
the head all ready broke off and the shank of the bolt is corroed on to the head, i live in ne so i think it welded it self togeather.
Old 02-09-2011, 03:19 PM   #4
biodude
Member#: 271720
attach a lift to the head and see if you can pull it off. let the weight of the engine do some work for you
biodude is offline   Reply With Quote
Old 02-09-2011, 03:31 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Is the engine out of the car? If so, I think biodude's idea is a pretty good one (although attaching the lift to the head might be a challenge).
If the engine's in the car it's going to be tough for the penetrating oil to really penetrate since the bolt is horizontal.
I'm not familiar with the head design on the EJ22 - any chance there's enough of the bolt shank exposed that you could put some bigass vice grips on there?
Patrick Olsen is online now   Reply With Quote
Old 02-09-2011, 04:17 PM   #6
biodude
Member#: 271720
Id assume the block has to be out of the car
as far as attaching, use two outter most exhaust studs and two outter intake bolt holes, you can attach a chain or whatever to 4 points and that way you should be able to pull up on the head pretty evenly,
Old 02-09-2011, 06:16 PM   #7
gmullin
Member#: 271800
motors on a motor stand and ill try with the lift when i get home from work
Old 02-09-2011, 06:39 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yeah, that should work pretty well.
Old 02-09-2011, 06:40 PM   #9
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
A little bit of weight pulling the block down, soaking in PB Blaster or whatever, and tapping on the exposed bolt shank is likely to do the trick. Remember you don't have to elevate the block, just get the bottom of the stand a fraction of an inch off the ground and all the weight will be on the corroded surfaces.
BAN SUVS is offline   Reply With Quote
Old 02-09-2011, 07:21 PM   #10
gmullin
Member#: 271800
ill go try this tonight the motor dosent weigh that mutch so ive enlisted my grandfather and my brother too help combined they weigh about 600lbs thats the most weight i could find hahah ill let you know how it goes
Old 02-09-2011, 09:34 PM   #11
gmullin
Member#: 271800
anyone have a stronger stand? 600+lbs bouncing while hammering with a punch, stand exploded head is still on just as tight wtf god dam heads are dam strong
Old 02-09-2011, 09:49 PM   #12
biodude
Member#: 271720
stand exploded!?!? wow
keep soaking it add heat. get a new stand too I guess
Old 02-09-2011, 09:57 PM   #13
gmullin
Member#: 271800
yea next is heat then i also can drill to the side the bolt is corroed to an hit it with a punch then weld it back togeather after i get the head off
Old 02-09-2011, 11:21 PM   #14
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Heat
PB Blaster
Heat
PB Blaster
Heat
PB Blaster
Heat
PB Blaster
Heat
PB Blaster
Heat
PB Blaster
Heat
PB Blaster
Heat
PB Blaster
See where I'm going with this? If you've got the time, stretch this process out for a couple of days. If you can leave it hanging by the head while doing this then all the better. Otherwise I suppose you could try drilling out the remaining bolt shank at least down to the block.
You do have all the other bolts out, right? I've done that once or twice on a water pump. "Why won't this stupid thing come off!?! Wait... Oh.. whoops."
Wrencher86 is offline   Reply With Quote
Old 02-09-2011, 11:40 PM   #15
davewilson
Member#: 269045
I agree with wrencher86... there isn't much that cycles of heat and penetrating oil can't take care of! Good luck!
davewilson is offline   Reply With Quote
Old 02-10-2011, 11:46 AM   #16
gmullin
Member#: 271800
o yea i have the head able to move on the dawles but cant lift it off them and the bolt just flexes with the head
Is this guy serious? Fail Inside JokerDMX Rocky Mountains Impreza Club Forum -- RMIC 39 02-18-2011 12:31 AM
Uneven, weak and jerky acceleration. Tried and failed to fix Kalgoorlie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-14-2011 09:35 PM
SoCal: Morette + DMV Inspection=Fail/No Fail? Midn8Run Southern California Impreza Club Forum -- SCIC 10 02-06-2005 03:58 AM
The official "verify this", possibly failing/failed thread. overdose Service & Maintenance 4 12-09-2003 11:43 AM
Withdrawl/Fail or Fail? Soon2bSubbieowner Off-Topic 10 11-20-2003 11:16 PM
