Old 02-09-2011, 02:39 PM   #1
si07
Member#: 269969
03 Forester 2.5x
Default hybrid intake for 07 2.5i
Im trying to install a hybrid intake for my 2.5i.
I found this intake but not sure if it will work?
http://cgi.ebay.com/ebaymotors/00-01...essories#rpdId
what else would i need to get this installed?
can i get a link on how to install it?
an how do it tune it, log or whatever for it to be correctly working?
Thanks in advance
si07 is offline   Reply With Quote
Old 02-09-2011, 07:54 PM   #2
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
yes that will work. You will need to visit your local plumbing store for a piece to couple the tube to the MAF sensor.
It looks like it comes with the coupler to mate the tube to the throttle body. You just need to run the hoses (that should also be included in your kit) to each valve cover vent, and the PCV valve. Do a search on here... there is a TON of photos and step by steppers in the DIY section.
Rudgers73 is offline   Reply With Quote
Old 02-09-2011, 09:53 PM   #3
si07
Member#: 269969
03 Forester 2.5x
cool man thanks alot!
Old 02-23-2011, 10:45 PM   #4
RichInOrlando
Member#: 274640
2007 Impreza 2.5i
Urban Grey Metallic
Did you ever get this thing installed?
RichInOrlando is offline   Reply With Quote
Old 02-26-2011, 01:01 PM   #5
bmobs06
Member#: 252783
i'm using a similar one on my 06; went to autozone bought a maf adapter and injen filter and bam, you got yourself a intake.
bmobs06 is offline   Reply With Quote
Old 02-26-2011, 10:53 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
An MAF adapter or change in the location of the MAF sensor requires a tune to have fueling be anywhere close to good. You could just shovel some dirt in your engine and save yourself the cost of that filter, too.
Old 02-27-2011, 01:55 AM   #7
bmobs06
Member#: 252783
i've got it done, so dont worry about it. works great and no problems to report after one year.
Old 02-27-2011, 09:57 AM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i've got it done, so dont worry about it. works great and no problems to report after one year that I am aware of.
There I fixed it for you. And I am not worried, my 07 with an intake is tuned and verified with data.
DIY Hybrid Intake for 2008 2.5i cthomasset Normally Aspirated Powertrain 672 04-06-2015 11:15 AM
Hybrid intakes for the 2.5i '08+ Rotten Tomato Normally Aspirated Powertrain 2 03-10-2010 09:57 PM
Looking for catback exhuast system for 07 2.5i sunspot.2.5i Private 'Wanted' Classifieds 1 11-19-2009 08:51 PM
best intake for '06 2.5i Squeakywaffle Normally Aspirated Powertrain 28 02-09-2009 03:59 PM
intakes for my 2.5i bsikora Normally Aspirated Powertrain 9 10-09-2006 01:02 AM
