Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 02-10-2011, 03:43 AM   #1
AVANTI R5
Member#: 73805
Default VW R models' new ESP system
Volkswagen has equipped its most potent Golf GTI and R models and its entire Scirocco range with a new ESP system that allows the driver to fully disable electronic aids.
VW has responded to criticism from media and customers that said the models were not adjustable or sporting enough, were too sensible compared with rivals and did not allow the driver full control of the vehicle.
All 2012 model year Sciroccos and Golf GTIs and Rs built from May will be fitted with the new system and will reach showrooms from July. The new ESP set-up is a two-stage system that controls traction control and braking. Pressing the ESP off button once will disable the traction control, while holding it in for more than three seconds will fully disable both traction control and electronic braking systems.
The system will only cut back in should the driver press the brake pedal in the middle of an ‘emergency’, be it if control of the vehicle is lost by the driver or if they want the car to straighten up by itself. If the brake pedal is not depressed by the driver the ESP system will remain inactive.
The new ESP system is a standard fit to all Scirocco models, plus the Golf GTI and R, and is available for no extra cost over the standard car. There are no plans to fit to the Polo GTI at this stage however.
http://www.autocar.co.uk/News/NewsAr...llCars/255389/
Old 02-10-2011, 03:45 AM   #2
AVANTI R5
Member#: 73805
So while driving with anger it does not work..pff. Come to turn hit brake and your back where you started..
Old 02-10-2011, 11:00 AM   #3
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
Germans have no sense of humor.
Derbagger is offline   Reply With Quote
Old 02-10-2011, 11:47 AM   #4
arghx7
Member#: 232940
So you can turn it off... except you can't.
arghx7 is offline   Reply With Quote
Old 02-10-2011, 12:22 PM   #5
thestig2284
Member#: 200517
09 Subaru WRX
Sounds legit.
thestig2284 is offline   Reply With Quote
Old 02-10-2011, 12:41 PM   #6
justincredible
Member#: 83633
2012 bright green
box
I want a Scirocco.
That is all.
justincredible is offline   Reply With Quote
Old 02-10-2011, 12:53 PM   #7
KC
Member#: 442
13 Crosstrek XV
00 S2000
I think the question is how far the brake pedal has to travel while the car is being 'upset', as it's a really bad thing to be hitting it HARD while on the edge of traction anyways.
I don't think just tapping it, or left foot braking, will really turn it back on. And also, I bet if you're going straight and nail the brakes, I bet it won't turn back on either, as you're not really upsetting the car.
However, using the brake to turn it back on in the 1st place is not a great idea, and can cause more problems on track than just having it stay off in the 1st place, mid corner.
--kC
KC is offline   Reply With Quote
Old 02-10-2011, 01:26 PM   #8
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
--kC
I think this is good regardless... you just have to trace back how the brake turns it off and disconnect that sensor/ switch. Someone will figure it out either via a mechanical or electrical bypass.
-Mike.
mpaone is offline   Reply With Quote
Old 02-10-2011, 08:05 PM   #9
KoalaSlim
Member#: 94002
Hmm I like they added the option of disabling traction control and ABS.
I seriously am warming up to the new Golf R.
KoalaSlim is offline   Reply With Quote
Old 02-12-2011, 04:07 PM   #10
DivineStrike
Member#: 162037
2007 VW GTI Black
2007 CBR600rr White
the esp was the the reason i was thinking of not getting the Golf R, i now may change my mind but i am worried on how much brake is required to turn it back on. some bigger autox's require some trail braking on the sweepers to square the corner especially with ones that are decreasing radius' but I am also going to have to wait and see if the wrx will change face again.
DivineStrike is offline   Reply With Quote
Old 02-12-2011, 04:16 PM   #11
A-Wags
Member#: 255669
2015 WRX Premium
Lightning Red
So basically you can put it in a sort of sport mode, but you press the brake and it's back to traction control etc mode? It sounds like a "safe" sport mode to me where you can't fully get into the fun of it.
A-Wags is offline   Reply With Quote
VW Launch of New "Jetta" Diesel Delayed NYCshopper Non-Subaru News & Rumors 1 11-09-2007 11:20 AM
VW Offers Building New Audi to Threatened Brussels Workers NYCshopper Non-Subaru News & Rumors 0 11-28-2006 04:37 PM
VW researchers unveil new high-temperature fuel cell NYCshopper Non-Subaru News & Rumors 1 11-22-2006 05:20 AM
FS: NY 1973 VW beetle, modded, new stuff, new paint, cheap StatiK Private Vehicle 'For Sale' Classifieds 5 11-03-2005 01:19 PM
New B6 VW Passat gets Dynaudio audio system!! Siper2 Off-Topic 13 03-08-2005 05:35 PM
