Old 07-11-2002, 02:18 PM   #1
Austin
Member#: 7089
2016 STi
Default Tranny swap
My sparkly new GDA 5mt tranny and drivetrain should be here w/in a week. I'd like to do the swap (into a MY01 RS-T) in my garage, which means I need to get the car up on jackstands.
How high should I get it? (Measuring from any easy place... say the side skirt.) 24in? 30in?
What kind of jackstands are big enough? I have many jackstands, but none even come close to being tall enough...
Any helpful hints to make the swap go easier?
Austin is offline   Reply With Quote
Old 07-11-2002, 03:34 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
intesting choice of trannys
although i suppose that the 3.90 final ration should be easier on the gears...(not sure about the previous statement)
did the rs tranny already blow?
Old 07-13-2002, 12:59 PM   #3
kaos200
Member#: 2692
ok so you'll need the trans, clutch, fly, driveshaft and rear diff from a WRX (duh, just going through this for future search purposes)
BUT what about the shift linkage? and the interior part of the shift linkage too?
Do you replace the rear pumpkin or just the diff? What about front and rear axles?
Dont forget about the slave cylinder, its a different type than ours, and sits differently so I dont know if there is enough slack in the line to make it to the new cylinder?
kaos200 is offline   Reply With Quote
Old 07-13-2002, 03:59 PM   #4
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
I would say from doing many clutch tranny pulls (non subie) that measure the length from your elbo to finger tips, then if you are going to be on a creeper add about 6 inches. This way you have full movement of your arms but it is not out of the comfort and best arm leverage zone.
It also depends on what you are going to support the tranny on when you pull it out. If you plan on putting on a roll away jack that is fine but if you plan on ballancing it on you belly you will need it higher at the time of removal. I would use the jack method.
david2z4 is offline   Reply With Quote
Old 07-15-2002, 05:10 AM   #5
kaos200
Member#: 2692
Default anyone?
Old 07-15-2002, 08:41 AM   #6
Austin
Member#: 7089
2016 STi
Got all that.
I'll get back to you on that.
Everything, including the axles.
Old 07-15-2002, 09:59 AM   #7
XT6Wagon
Member#: 524
04 STi
Uh, subaru shifters have been virtualy the same since god only knows when. My 88 GL-10 shifter is the "same" as the WRX shifter, just very small details change, like the width of the front bushing for the support bar, and style of rear support bar mount.
I'd bet that the stock RS shifter bolts up w/o ANY problems.
Driveshaft should be from your car.
and yes you will need to swap the slave cyl. I hope you don't have to swap the line too. ( I would guess there is enough slack or extra room for the different route).
XT6Wagon is offline   Reply With Quote
Old 07-15-2002, 11:53 AM   #8
RS_NW
Member#: 2301
This isn't something you could do at the MWR Autohobby shop?
RS_NW is offline   Reply With Quote
Old 07-15-2002, 05:20 PM   #9
Austin
Member#: 7089
2016 STi
It does, and I was 99% sure that it would... but I wanted to go out and look one last time before I said yes... didn't want to talk out my @ss...
Old 07-15-2002, 11:42 PM   #10
XT6Wagon
Member#: 524
04 STi
RS_NW,
I'm putting in a 94 STi V1 driveline in a 88 wagon in my driveway so anything is possible as far as doing this kind of thing.
Old 07-16-2002, 11:58 AM   #11
RS_NW
Member#: 2301
I said that because I used to live on Navy bases and if my memory serves me correct Austin is a Navy boy and has access to their Hobby shop. They basically allow you to use their lifts, tools, and store your car there for certain projects for a small cost. I think that would be easier than crawling under the car. I for one don't like to be on my back when I work on my car. Lifts rule! I want one in my garage.
2005 Sti Tranny Swap into 05 Wrx---Posted this in the Tranny Section too Needsacar General Community 2 11-10-2009 01:39 AM
1999 RS tranny swap for 2001 RS tranny cjfike Transmission (AT/MT) & Driveline 5 11-04-2005 09:13 AM
6-Speed Tranny Swap HuRyde Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 54 08-03-2005 01:16 AM
02 wrx tranny to sti tranny swap bjonga Transmission (AT/MT) & Driveline 3 04-26-2005 06:29 AM
Tranny swap Avenger Normally Aspirated Powertrain 6 05-30-2001 07:37 PM
