Old 02-11-2011, 01:55 PM   #1
jlangv2
Member#: 235375
1996 impreza brightn
Default help with a light 2.5l build
i have a 98 2.5l dohc that i want to do a light build on for my impreza. what would be the best way to build the motor to ~200hp at the engine?
thanks, john
jlangv2 is offline   Reply With Quote
Old 02-15-2011, 12:44 PM   #2
PA-Outback2000
Member#: 161832
2000 Outback Limited
intake, pulley, header, high-flow cat or track pipe depending on emissions,, catback, cams - maybe head work, and a tune should do it. you could do a turbo kit or just swap in WRX/STI engine.
PA-Outback2000 is offline   Reply With Quote
Old 02-15-2011, 12:50 PM   #3
GEE-OTTO
Member#: 201277
2009 Legacy GT
thanks, john
You can't via a light build n a Ej25D. You could look into boost but that is outside your realm in which you want to remain
GEE-OTTO is offline   Reply With Quote
My STI 2.5L build... jays05 Built Motor Discussion 34 08-30-2007 04:48 PM
need help with tire selection 2.5l 01 RS JazzyJake Tire & Wheel 2 07-09-2007 08:26 PM
2.5l build. what would you do if you could start over. kinada423 Built Motor Discussion 39 01-19-2007 04:35 AM
This is a thread about my 2.5L build. t3hWIT Normally Aspirated Powertrain 3 10-28-2006 12:48 AM
New tranny pix to accompany 2.5L build up IA Performance Transmission (AT/MT) & Driveline 21 10-26-2003 12:59 PM
